#29 |
Drives: FAT H8R Hot Lava FRS
Track days in Arizona showed other wise, I do have and upgraded radiator, stock fan shroud, tuned the fans to come in sooner, designed the intercooler to allow airflow to the radiator, accounted for an oil cooling system, and havent had any issues or any showing signs of melting, even thrown a code for running cooler than oem cruising down the highway and some of the cooler nights, everything is tidy, managed well, and accounted for even in the az heat in traffic
#30 | |
Drives: 2013 Black FR-S
Do you have a stock bumper beam crash bar?
#31 |
Its a retrofitted oil/water cooler been working fine not sure if I will supplement with an additional when it gets further turned up and pushed harder. Also I do still have the stock crash beam that has trimmed and modified but still in there
#32 | |
If you can make it to the Chuckwalla 86CUP event, I'll cover your entry. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Hyper4mance2k (03-06-2015), OmarGC (01-25-2015) |
#33 | |
I havent come up with a % figure but when is this event? Link or info? I'd be down to go to chuckwalla! |
#34 | |
#35 |
Drives: 400whp Scion tC
#36 | |
Engineering Student
Drives: Scion FR-S 2015
Twin turbo on a horizantal oposed engine does not perform well. Bigger turbo is a less laggy set-up than twin. Twin turbo is not a performance oriented set-up for our car
There’s no time to stop for gas, we’re already late
| The Following User Says Thank You to Mikeez For This Useful Post: | Freeman (01-25-2015) |
#37 | |
Drives: 2013 Ultramarine FR-S
Which is why it seems it was done more for the "whoa bro!" Factor. Sent from my SAMSUNG-SGH-I317 using Tapatalk |
#38 | |
Junior
Drives: a car
Not to mention every post 2000 Porsche turbo is a 3.8L H6 TT setup... Twin turbos actually produce less lag than a single turbo, depending on configuration. If the single turbo is a gtx2867 and the twin turbo setup is a dual 3076 then yes the single would spool better.
#39 | |
Engineering Student
3.8 and 2.0 is different. 4cl, 6cl is also different. For our cars, twin turbo is not a recommendation but you know better
#40 |
Junior
Drives: a car
the EJ20T (subaru never quoted it being a TT) in the JDM spec Legacy's are still a 2.o 4 cyl sequential turbo setup... they have done it before .
#41 |
FAT is known for making more exotic one-off setups. They built other twin-turbo Subarus before and built a twin-charged STI a long time ago. Not really entirely practical but definitely cool setups.
| The Following User Says Thank You to xwd For This Useful Post: | fst86frs (01-26-2015) |
#42 | |
Engineering Student
I was just saying that there is no benefit for a twin turbo. Though, one turbo is a more benefit gain. The way I think of it is that, the flow will difract. I might be wrong.
| Twin Turbo Kit ? | SalM | Forced Induction | 77 | 07-03-2016 02:16 PM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| Twin Turbo BRZ | xn7485 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 10 | 08-23-2013 07:13 PM |
| Twin Turbo kit? | enjoi23 | Forced Induction | 15 | 12-03-2012 07:53 PM |
