Old 01-22-2015, 10:05 AM   #15
Originally Posted by Koa View Post
I hate you sometimes squidrogue..
My opinion goes back and forth between simply young and naïve or really, really good troll all the time!
I apparently need a more sensitive Torllometer as mine only goes to 10,000 disbelievawatts and Squady may be coming in higher.
carma143 (01-22-2015), Koa (01-22-2015)
Old 01-22-2015, 10:07 AM   #16
Koa
Originally Posted by kiichiro View Post
my biggest problem was not oil & g forces, it was fuel and g forces
DAMN LEFT TURNS
I setup the car to handle like a beast, it did just that
sold the car because the fuel system is crap and no pump any vendor sells you is gonna fix that, it wasnt worth it for me to throw a motor at the car, which was my next and only possible step; tracking the FA20 in stock form has its limits, the weakest link is the tranny, then fuel then motor. fix all three and I would have kept both our brz
Hey look it's everyone's favorite dbag who continues to hang around here to try and prove something
Old 01-22-2015, 10:08 AM   #17
DAMN LEFT TURNS
Wow, the bitter ex owner's are coming out of the woodwork lately!
brandonblt2 (01-22-2015), Koa (01-22-2015)
Old 01-22-2015, 10:34 AM   #18
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
He's like the ex who can't get over her so he keeps trying to talk bad to the other guys who are having fun...
The Following 2 Users Say Thank You to LucidMomentum For This Useful Post:
chas3wba0 (01-22-2015), Ultramaroon (01-22-2015)
Old 01-22-2015, 11:00 AM   #19
And judging by the cars that he lists now he is also the guy that after the divorce hooks up with the high priced, high maintenance slut that looks really good so he must show off even though the other guys may know better.
Old 01-22-2015, 11:03 AM   #20
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by SquadRogue View Post
Yeah, I hope somebody has some facts for the FR-S
Yes, sharp prolonged turning at speeds will suck oil away form the uptake and if you are FI and pulling additional oil to a turbo you will want to install a baffle to help mitigate this.
Old 01-22-2015, 11:06 AM   #21
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by boogle View Post
OK in the purest sense, if you put 'an car' in a centrifuge you'd eventually find the point where n Gs will trigger oil starvation in a cylinder head.
However, in the real world it's not just how many Gs, but the oil pressure (lots of contributing factors) mixed with the Gs (and angle), mixed with the design of the engine that will decide whether you get oil starvation and where it is. OP asked about this particular car, and oil starvation in the heads due to the boxer layout. In this case it just isn't going to happen. If you've got a heavily modified car in extreme circumstances you can get oil starvation... in the crank. Real world is just never as simple as a single force.
So as mentioned earlier by evan, a stock FRS/BRZ isn't going to get oil starvation due to hard banking.
Sorry, but it purely about the Lateral G-force and the RPMs.
It has zero to do with HP, EXCEPT - that High HP engines require more consistent oiling due to greater forces within the engine (which has little to do with lateral G-force)
So High HP engines are more susceptible to oil starvation.
Back on topic: IF you have oil starvation issues (you probably wouldnt know it unless you have an oil pressure sensor and log the data), then the solution for racers is an accusump.
If air is ingested by the sump pickup, the accusump will "burp" extra oil to keep the pressure up until the bubble clears the system.
Of course, the accusump can only do this for a few seconds, so a long sustained curve could still cause starvation.
Of course, the BEST solution is a drysump system with a resivoir & dual oil pumps.
The Following User Says Thank You to stugray For This Useful Post:
Pete156 (01-22-2015)
Old 01-22-2015, 11:06 AM   #22
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
My reaction to Squadrogue threads.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
The Following 5 Users Say Thank You to Defuser For This Useful Post:
1GiantTurtle (01-22-2015), chas3wba0 (01-22-2015), civdaddy (01-22-2015), PandaSPUR (01-27-2015), Ultramaroon (01-22-2015)
Old 01-22-2015, 11:09 AM   #23
stugray
DAMN LEFT TURNS
sold the car because the fuel system is crap and no pump any vendor sells you is gonna fix that, it wasnt worth it for me to throw a motor at the car and a proper return type fuel setup(new custom fuel cell or new fabbed up tanks in oe spot etc), which was my next and only possible step; tracking the FA20 in stock form has its limits, the weakest link is the tranny, then fuel then motor. fix all three and I would have kept both our brz
a vette motor swap was on the table but for that money plus our trade we are making a cayman s into a track car that will easily EAT any frs or brz no matter how buit up...(adding quaife or guard LSD, JRZ coilovers,---> evoms rs350 kit<--- just wow etc etc) all for same money as trackifying a 86, proper
and no left turn fuel starvation, I dont miss that one bit!
If you hate (and SOLD) the car WHY are you still visiting the forum?
Bitter breakup huh?
I'll bet it was repossessed and you just dont want to admit it....
Old 01-22-2015, 12:00 PM   #24
LucidMomentum
Bitter breakup huh?
Because he has a Porsche, so he has to be having more fun than we are. He wants to make sure we understand that.
Pics or it didn't happen, anyways.
Old 01-22-2015, 12:07 PM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
At least kiichiro is claiming some kind of knowledge, the rest of you are armchair quarterbacking about your daily drivers.
And what he says makes sense, in this car you will likely fuel starve before you run into oil issues on stock powertrain.
kiichiro (01-22-2015)
Old 01-22-2015, 12:17 PM   #26
Teseo
Drives: frs
Anyone thought at that speed the car can oversteer?
Old 01-22-2015, 12:20 PM   #27
Nessal
Drives: Exige, Miata, Ghia
The OP is why I have no hope for this country.
Nessal is offline   Reply With Quote
Old 01-22-2015, 12:21 PM   #28
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
People like CSG, Robispec, and Element have cornered faster than you probably ever will without reporting oil starvation from turning. Element has dealt with oil pressure issues, but that's due to engine power, not turning.
The Following User Says Thank You to EAGLE5 For This Useful Post:
strat61caster (01-22-2015)
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 10:42 AM
Dr. Destructo blows a rocker apart Element Tuning Engine, Exhaust, Transmission 82 12-04-2015 03:00 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 12:03 PM
