Old 01-19-2015, 09:44 PM   #1
DFW-FRS
Drives: 2013 Asphalt FR-S
Stock Motor is Toast (Spun Rod Bearing)
I've had my FRS since July of 2013 and after 25,000 miles the rods started knocking and we discovered a spun rod bearing. The Toyota dealership said "they've never seen anything like it" lol. Anyways, they agreed to replace my entire short block for free, updated my ECU, and put me in a 2015 Corolla S, which must have stood for "shit" because that thing has no business being called sporty. Not sure how I feel about my FRS now, but I've already broken in the new block with about 1,500 miles. If I wanted to blow up a boxer engine I would have gotten a WRX, but I digress.
Link to service receipt: http://i.imgur.com/R9kx0OW.jpg
DFW-FRS is offline   Reply With Quote
Old 01-19-2015, 09:57 PM   #2
gravitylover
So does the warranty on the motor now go for another 36k or does it still end when the car hits 36?
Old 01-19-2015, 09:58 PM   #3
DFW-FRS
It ends at 36,000
Old 01-20-2015, 10:33 AM   #4
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
Not much experience w/ 'rods knocking'.. what would you say your symptoms were or what to look for? I push my car pretty hard occasionally with oft e85 tune. Just want to make sure I know what to look for.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 01-20-2015, 10:55 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by DFW-FRS View Post
It ends at 36,000
WTF...
that's not right
replacement part should have another guaranteed warranty again.
Old 01-20-2015, 10:58 AM   #6
Drive train goes to 60K. 32K is bumper to bumper.
Celadrielas (01-25-2015), mav1178 (01-20-2015), raven1231 (02-01-2015)
Old 01-20-2015, 12:01 PM   #7
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Let me just say if you had problems, you'd hear it.
There's nothing to "look for," it just starts happening when the bearing tolerances become larger due to oil starvation mostly. All that extra space between the con rod and crank will cause a metal clanking sound and will get louder and faster with more engine rpm.
That, or just a fluke at the factory.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
mmmcambelsoup (01-20-2015)
Old 01-20-2015, 02:45 PM   #8
tennisfreak
Drives: 2018 BMW M240i
If it were my car I'd be looking to trade it.
Old 01-20-2015, 08:05 PM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
What caused the failure ?
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
hmong337 (01-25-2015)
Old 01-20-2015, 08:54 PM   #10
FirestormFRS
Bottom ends don't fail easily. They're pretty much bullet proof at stock levels unless they are starved for oil.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
mmmcambelsoup (01-30-2015)
Old 01-23-2015, 03:47 AM   #11
marky
marky's Avatar
Drives: 2020 BRZ tS #54
That's what I'm trtrying to figure out also....
They took my motor apart and crank case turned blue do to lack of lubrication and oil starvation.. my car had good oil level also.. no check engine lights btw..
32999..
The Following 3 Users Say Thank You to marky For This Useful Post:
DFW-FRS (02-01-2015), Guff (10-20-2015), ZZT86 (01-28-2015)
Old 01-25-2015, 07:22 PM   #12
BRZnut
Drives: BRZ DGM Limited
Did any of you have a Cam issue/CEL before the engine failure?
Old 01-25-2015, 09:56 PM   #13
marky
marky's Avatar
Nope.. no CEL nothing.. they didn't mention anything about the cams.. forgot to look into it..
Old 02-01-2015, 03:09 PM   #14
DFW-FRS
I was in fourth gear doing about 50 MPH when I downshifted, accelerated, and heard a strange rotating rattling noise coming from the engine bay. I turned down my radio and the rattling turned into loud violent knocking. The car died in motion and I lost power to everything. Luckily it was on an empty Texas highway.
This man speaks the truth.
It's a lease so I'm not worried about it. I do worry that it will happen again though.
Car was somehow starved for oil and spun a rod bearing. The techs blamed it on my old 2012 factory tune. Apparently there was an ECU update that I never received.
True.
None at all. I've only had ignition coil failure in two cylinders prior to this.
STOCK MOTOR 3k Anthony7515 Engine, Exhaust, Bolt-Ons 16 11-25-2014 03:48 PM
Stock Motor Cross Want-To-Buy Requests 2 08-01-2014 06:47 PM
Spun out and hit a curb... JohnAyySays Issues | Warranty | Recalls / TSB 54 12-09-2013 10:59 AM
Avoided deer, spun out, alignment needed? gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 30 07-28-2013 11:14 AM
Spun out now a CEL Noob4Life Issues | Warranty | Recalls / TSB 10 03-30-2013 11:02 PM
