| Software Tuning Discuss all software tuning topics. |
#841 |
Drives: Subaru BRZ LTD GBS
Just got the same issue as pl1ght installing a Borla uel - comes back after clear. Ill follow up with the shop who installed the exhaust system and see what happened with the 02 sensors
#842 |
Drives: FT86
#843 |
Same codes , 37 and 31.
#844 | |
Thanks! ETA: Every new tune is better than the last, good stuff. I was actually taken by surprise at how hard it pulled above 5-ish. Can't wait to try the E85. Last edited by Tromatic; 01-12-2015 at 06:36 PM. |
#845 |
Curious cat.
Drives: 86 GT base M/T - Red
Are v2.xx Gulf spec (Middle East) maps out yet?
Downloaded the ZIP, didn't see 'em. If not, can the v1.59 files be used instead? Just curious. I like that these maps are based on the factory tune with the DI 'fix'. Had an ecutek tune and an OEM tune earlier that didn't have the fix and kept getting CELs on the track. No issue since the dealer reflash so it's kind of a big deal for me.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#846 |
The 2.063 ROM is sweet!
#847 | |
Drives: FT86
the v2xx tunes supported more rom types thaj v1.5x |
#848 |
Drives: Grey GT
Not to be rude or anything.. but do OFT sales have any support service? Because I'm not getting any replies from these guys..
#849 | |
Drives: FT86
dont use personal message PM to shiv on this forum think he has it turned off as he get to many or if all else fails ring on phone or gmail phone call free to usa |
| The Following User Says Thank You to steve99 For This Useful Post: | luv85 (01-22-2015) |
#850 |
Drives: GT86
I am sorry if this is not in the right thread.
I am a bit confused of this parameter setting. The above A/F Learning is from a tune I am looking at The one below is from the OEM tune. Is this a mistake or is this done for some reason that is not obvious to me. |
#851 | |
Drives: 2013 Asphalt FR-S
That aside I think I have seen those settings vary from stock rom to stock rom (the limits on the left). Could aslo be a fat finger in the def, assuming those two maps your comparing are using two different definitions.
~Namaste~ |
#852 |
Drives: GT86
The tunes are based on the A01I and the definitions used are the same in both
One is the factory A01I the other is also A01I based tune, so the definition files should be the same. Makes no sense to me that one value the upper limit is negative etc. EDIT: Yep that is what it was the definition file..... I was told that the A01 was the same as in 1.5 set, clearly its not Thanks for your help |
#853 |
Drives: GT86
I have updated my definition, but I note that in all of the 2.06 releases that I have, the definition for 700I is not included.
In Aus we have cars with this map, can any one help with a copy please. |
#854 | |
Drives: FT86
just flash the 700I car with A01I its the latest compatable rom for that car. Dont use an E00I its only for latest my2015 cars if the guy has an oft then send the 700I rom to openflash guys and they will do up an oft compatable rom and def. This will actually be an A01I rom calid hacked to look like a 700I and a matching calid adjusted def. |
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
