Old 01-12-2015, 12:26 PM   #57
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
Originally Posted by FastWhite View Post
Ok, I finally got this installed.
First thing is, I was dreading taking off the bumper cover. It is an intimidating , seemingly, endeavor. It's not.
It was actually very simple. Pop off the push on retainers, undo the bolts, carefully pull off the cover. Done.
Only thing to stress is "take your time". If your car has some mileage on it the retainers may be brittle. So take it easy and just work them out. You will end up with a few spare larger ones from inside the air diverter, so built in spares.
Install is very simple and well designed.
If you have no tune then remember to install the small internal thingy inside where the MAF sits. Can't recall the exact name of it but it is well documented. Very good instructions.
Performance gains: well like every one says the stock system is very good. I had an aFe oiled air filter installed before this. I noticed no difference in sound, I did notice a seat of the pants improvement at 4500 rpm. Previously I'd get the surge at 4800 rpm. Now I get it at 4500/4600 rpm. More pull at the higher rpm's.
The big plus for this CAI is that you do not have to remove the bumper cover every time you need to clean the filter.
Overall I like it and recommend it, especially for those staying NA or getting a SC that retains the stock air filter locations.
The air scoop is HUGE. For NA, every little bit helps.
I have a 2013 BRZ limited A/T
Do u think u would get a better 0-60 time with this intake?
mizzta21 is offline   Reply With Quote
Old 01-12-2015, 12:44 PM   #58
FastWhite
Drives: Subaru BRZ Limited M/T
Maybe. I don't think it would would that much of drop in time. The gearing comes into play as well as the power mods.
Anybody on here have some times for various mods. 0-60, 1/4 miles and such.
FastWhite is offline   Reply With Quote
Old 01-12-2015, 02:04 PM   #59
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Thank you! Great initial thoughts of the feel and installation! Any pictures?
KraftWerks is offline   Reply With Quote
Old 01-12-2015, 04:00 PM   #60
FastWhite
No pics. The pics are exactly like what is already posted.
Old 01-15-2015, 08:43 AM   #61
xDanger_208x
xDanger_208x's Avatar
Drives:
To all who have this piece, did you leave the black radiator shroud in place?? The one that sits between the upper rad support and crash beam.
xDanger_208x is offline   Reply With Quote
Old 01-15-2015, 08:44 AM   #62
FastWhite
No. It gets removed per the instructions.
Old 01-15-2015, 08:45 AM   #63
xDanger_208x
Drives:
Hmmm I must have overlooked that part.
Old 01-15-2015, 09:12 AM   #64
xDanger_208x
Drives:
Instructions say nothing about it. Only part it shows to remove is the factory snorkel.
Old 01-15-2015, 09:59 AM   #65
FastWhite
I'm trying to find my instructions now.
Old 01-15-2015, 10:04 AM   #66
xDanger_208x
Drives:
It fits fine with it still on. I'm just wondering from a performance standpoint.
Old 01-15-2015, 10:08 AM   #67
FastWhite
Don't know about that, the performance with or without.
But you are correct in that the instruction don't mention to actually remove the shroud. I think it's referred to as an air diverter. But the pictures show it as being removed. Step 12 specifically.
We'll need to ask @kraftworks I guess.
Old 01-16-2015, 08:40 PM   #68
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
So I understand correctly, you use to the insert if you have no tune (presumably to keep AFR's in check) but if you are tuning you leave if out for a bit more flow and better performance with a tune?
F1fletch is offline   Reply With Quote
Old 01-17-2015, 06:28 AM   #69
FastWhite
Correct. That is per my tuner as well as in the manual.
Old 01-17-2015, 06:06 PM   #70
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I have scaled the MAF with the insert in. I got STFT's up to 20 before I scaled it. It flows a lot more air than stock, even with the insert in. I haven't scaled the MAF with the insert out yet, that's next on my list. If you do get a tune with the insert out, could you share the MAF scale spreadsheet with the rest of us?
KoolBRZ is offline   Reply With Quote
Skunk2 Pro-C Coilovers for FRS, BRZ, FT86 KraftWerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-04-2015 04:06 PM
Skunk2 Garage Sale: 06.28.14 KraftWerks Southern California 4 06-24-2014 08:53 PM
FS: Skunk2 Racing 1.3 kg/cm Rad Cap ***SOLD*** JPxM0Dz Canada Classifieds 0 10-01-2013 01:25 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
FS: afe DRY intake system Laika Engine, Exhaust, Bolt-Ons 2 02-28-2013 10:37 AM
