Old 09-20-2014, 04:25 AM   #43
zooki
Drives: waiting on a 2021...
Hard to tell exactly, but maybe 5-6 HP at the very top end? Probably not enough that you would notice in everyday driving? The more aftermarket intakes that are introduced, the more the factory system looks very well thought out...
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 09-22-2014, 04:55 PM   #44
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by boredom.is.me View Post
Any supporting info to that graph? Were those back to back pulls or in identical conditions? What about MAF info?
Edit:
I meant AFR...
Originally Posted by gramicci101 View Post
What happens to the AFR?
I'll asks the tuners to see if I can't get something up as a visual. We're still targeting 14.5-14.8 just as it should be but again, I will work on getting a visual up on the boards.
We're about 5-8 at the peak figures over the OE.
The graphs were back to back on our Rototest Hubdyno.
When it comes down to it, the intake is a piece of the N/A puzzle. Each item increases the output and efficiency individually but when all pieces come together, they all will work off of each other to net the biggest gains overall.
In my experience (CJ), I've found that the OE Engineers usually have their stuff together. Only when you change items like camshafts, throttle bodies, headers, exhaust, do intakes really shine as you need to be able to move all that extra air through and out of the motor.
KraftWerks is offline   Reply With Quote
Old 10-22-2014, 08:13 PM   #45
KraftWerks
KraftWerks's Avatar
Intakes are Back IN STOCK.
Recently, Mike from Moto-East did a back-to-back comparison OEM vs. Powerbox with impressive results!
Old 10-31-2014, 08:26 AM   #46
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Anymore pictures of that inside air straightener. Does it interfere with oil coolers such as MAPerofrmance or perrin? It looks good, don't mind the nay sayers.. When it comes to NA cars big money doesn't mean big power, most parts are means to an end.
yomny is offline   Reply With Quote
Old 11-04-2014, 07:10 PM   #47
KraftWerks
KraftWerks's Avatar
Added pictures of Flow Straightener Coupler with Insert.
Also added another 3rd Party Comparison via Vittuned.com
Old 12-16-2014, 08:25 PM   #48
FastWhite
Drives: Subaru BRZ Limited M/T
I just pick one up. Should be along shortly and will post up my my thoughts. Also
have a MotoEast tune coming and will see how it does. Was looking at the 3" Perrin intake but did not want to take the bumper off to clean the filter.
Personnel choice that. Mean absolutely nothing by it.
FastWhite is offline   Reply With Quote
Old 12-17-2014, 12:40 PM   #49
KraftWerks
KraftWerks's Avatar
Thank you for the purchase! Feel free to comment here or PM with any questions.
Old 01-05-2015, 11:00 AM   #50
xDanger_208x
xDanger_208x's Avatar
Drives:
Has anyone fitted this intake with the Perrin oil cooler?
Or any other oil cooler for that matter?
It looks like it might interfere. @KraftWerks
xDanger_208x is offline   Reply With Quote
Old 01-07-2015, 12:36 AM   #51
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Looks like you have to take off the bumper cover, is that confirmed?
F1fletch is offline   Reply With Quote
Old 01-07-2015, 01:13 AM   #52
kevin.nguyen
Drives: Ultramarine FRS
Yes
kevin.nguyen is offline   Reply With Quote
Old 01-07-2015, 12:38 PM   #53
KraftWerks
KraftWerks's Avatar
Unless you're a ninja, to make the installation as seamless as possible, you should remove the bumper to make sure you can reach all mounting locations without issue.
Old 01-07-2015, 02:50 PM   #54
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I've been working on a MAF scale for the Skunk2 with insert for a couple weeks now. It's not perfect, but much better than OEM or my first attempt. My car has grown quieter and quicker the closer I get to 0.00 STFT and LTFT trims. It's obvious this intake flows much more air than stock, even with the insert restricting flow. I'm anxious to finish the current MAF scale and remove the insert to scale that too. Anyone who purchased this can PM me with their email address to get a copy of my current MAF scale for the Skunk2 with insert.
KoolBRZ is offline   Reply With Quote
Old 01-07-2015, 05:58 PM   #55
KraftWerks
KraftWerks's Avatar
Thanks @KoolBRZ !
Old 01-12-2015, 08:11 AM   #56
FastWhite
Ok, I finally got this installed.
First thing is, I was dreading taking off the bumper cover. It is an intimidating , seemingly, endeavor. It's not.
It was actually very simple. Pop off the push on retainers, undo the bolts, carefully pull off the cover. Done.
Only thing to stress is "take your time". If your car has some mileage on it the retainers may be brittle. So take it easy and just work them out. You will end up with a few spare larger ones from inside the air diverter, so built in spares.
Install is very simple and well designed.
If you have no tune then remember to install the small internal thingy inside where the MAF sits. Can't recall the exact name of it but it is well documented. Very good instructions.
Performance gains: well like every one says the stock system is very good. I had an aFe oiled air filter installed before this. I noticed no difference in sound, I did notice a seat of the pants improvement at 4500 rpm. Previously I'd get the surge at 4800 rpm. Now I get it at 4500/4600 rpm. More pull at the higher rpm's.
The big plus for this CAI is that you do not have to remove the bumper cover every time you need to clean the filter.
Overall I like it and recommend it, especially for those staying NA or getting a SC that retains the stock air filter locations.
The air scoop is HUGE. For NA, every little bit helps.
I have a 2013 BRZ limited A/T
Skunk2 Pro-C Coilovers for FRS, BRZ, FT86 KraftWerks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-04-2015 04:06 PM
Skunk2 Garage Sale: 06.28.14 KraftWerks Southern California 4 06-24-2014 08:53 PM
FS: Skunk2 Racing 1.3 kg/cm Rad Cap ***SOLD*** JPxM0Dz Canada Classifieds 0 10-01-2013 01:25 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
FS: afe DRY intake system Laika Engine, Exhaust, Bolt-Ons 2 02-28-2013 10:37 AM
