Old 01-14-2015, 05:30 PM   #8191
TM
TM's Avatar
Drives: DGM BRZ 6MT
New owners: add your names to the spreadsheet! http://www.ft86club.com/forums/showthread.php?p=1765486
Those with the upgraded rev1 kits, update your info on the sheet as well!
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
DAEMANO (01-14-2015)
Old 01-14-2015, 05:33 PM   #8192
raven1231
Originally Posted by l0aded View Post
Regarding the map tuning with OFT, do I use the one on the website "Off-The-Shelf (OTS Maps for ESC+OFH with 1.5 Dump Pack Upgrade [USDM only]" even if I do not have aftermarket headers?
Yes that's the one.
l0aded (01-14-2015)
Old 01-14-2015, 07:52 PM   #8193
godzuki
godzuki's Avatar
Drives: frs
Installed the partial boost ESC over the weekend and other than the nice on-demand boost it provides I noticed another thing... There is no longer a "plastic burning" smell that would normally have occured after "spirited" driving. I had been bothered with that issue for about a year. Dealer had no clue what was causing it, and couldn't determine where in the engine bay it was coming from. Considering I removed quite a bit of plastic/rubber parts for the install, (resonator, intake tube, and sound tube) I'm guessing one of those parts must have been the culprit. Car smells great now.
godzuki is offline   Reply With Quote
The Following 3 Users Say Thank You to godzuki For This Useful Post:
DAEMANO (01-15-2015), fenton (01-14-2015), Sojhinn (01-14-2015)
Old 01-14-2015, 08:07 PM   #8194
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Do you have a manual or auto?
Installed Mods:
Old 01-14-2015, 08:32 PM   #8195
godzuki
godzuki's Avatar
Drives: frs
Auto and your install video was referenced numerous times. Owe you a beer next time i'm in SD.
Old 01-14-2015, 08:34 PM   #8196
Sojhinn
Sojhinn's Avatar
Thanks buddy. Then yes probably the resonator or some random plastic crap. If it was a manual I was going to have you check something else. I'm curious what do you think of the system thus far?
Installed Mods:
Old 01-14-2015, 08:55 PM   #8197
godzuki
godzuki's Avatar
Drives: frs
Loving it. Just wish i had more opportunity to run it for more than a few seconds (lots of cops where i live). Will post video of the dashcommander boost gauge with it armed and not.
Install was super easy (esp. with the vid). Came with a mini fuse soldered on the LED display wire, ended up getting a low profile one so it would sit flush in the fuze box so I could snap the fuze cover back on. Has a some issues with the pedal switch engaging randomly which a bead of hot glue seems to have fixed.
The most time consuming part for me was getting the OFT software updated to flash the proper tune. Could not get that working in an OS X Fusion VM. Now I have an old toshiba laptop whose sole purpose in life is to run the OFT manager in windows.
The Following 2 Users Say Thank You to godzuki For This Useful Post:
DAEMANO (01-15-2015), Robftss (01-15-2015)
Old 01-14-2015, 09:00 PM   #8198
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Yeah I had a bitch of a time with Mac OS X with parallels but I eventually got it working.
On the fuse cover it actually bends a lot. I still use it without the lower profile fuses. I am curious about the issue with the engagement switch... Was it the headphone connection?
Installed Mods:
Old 01-14-2015, 09:11 PM   #8199
godzuki
godzuki's Avatar
Drives: frs
On the fuse cover it actually bends a lot I still use it without the lower profile fuses. I am curious about the issue with the engagement switch... Was it the headphone connection?
Yes, and Rob did offer to send a replacement but the hot glue is doing it's job so far, and i'd probably hot glue a new one too anyway. A 1/8" jack probably isn't one of the most robust connectors to use for such a critical component. But other than that I'm pleased at how well everything fit together.
DAEMANO (01-15-2015), raven1231 (01-15-2015), Robftss (01-15-2015)
Old 01-15-2015, 03:50 AM   #8200
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
So I just finished installing. Did a few test laps and I was almost certain there was absolutely no differnce vs stock... then I went back to my hood and realized the blue wire had disconnected (looked a little burned?) and I was like eh ok. Reconnect it. Go for another test lap. HOLY SHIT lol. The difference in speed and torque is massive. My tires slipped on first gear even though I didn't launch it at all.
This is all on 91 map with 91 octane too, can't imagine e85. I am pretty satisfied . It's hard to stop smiling lol.
Regarding the burn, I messed up my install and had to go back and accidently shorted a connection. That may be why but I'm not sure.
For those who are installing or going to install, the hardest part for me was actually "drilling" out the rivets to remove the resonator chamber on the intake. Second would probably be aligning the ESC. The rest is a breeze. Took about 3 hours.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following 8 Users Say Thank You to l0aded For This Useful Post:
DAEMANO (01-15-2015), fenton (01-15-2015), Gums (01-15-2015), raven1231 (01-15-2015), Robftss (01-15-2015), Sojhinn (01-15-2015), TM (01-15-2015), Winjr (01-15-2015)
Old 01-15-2015, 07:44 AM   #8201
WNDSRFR
Drives: FR-S,GTI
Originally Posted by DAEMANO View Post
How much negative camber are you running in the rear. Lowering the suspension in the back adds quite a bit of neg camber. This is desirable for grip, but you have to remember to rotate them regularly. Are you tracking or AutoX on your Conti DWs? Please say no.
By saying the car is lowered I mean it has the Eibach Pro Kit. So it's not lowered that much and I never changed the suspension settings. And no the car has never been off the road. I guess I just drive a little aggressively is all.
Old 01-15-2015, 10:57 AM   #8202
fenton
Awesome, thanks for the quick review. As far as the ESC connectors, they have to be pushed in very securely.....they are kind of a Pita on the first connection.
I agree with the drilling out the rivets part, that was my least favorite part of the install as well. Glad to see you are enjoying it, it will only get better as everything breaks in
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
l0aded (01-15-2015), Robftss (01-15-2015)
Old 01-15-2015, 10:59 AM   #8203
DAEMANO
Time Traveller
Pro-kit will drop you about 1" in the rear, that will give you about -1.5ish degrees of natural negative camber in the back. Now depending on your tire and driving style that could definitely cause some premature wear if not rotated. @WRB5titch ran the same setup a while and can probably speak better to it.
Old 01-15-2015, 11:05 AM   #8204
DAEMANO
Time Traveller
Haha congrats man! You stuck it out on the waiting list and now reap the rewards. Its been a good long time since our demo drive. Now you got a nice long break in the rain to just destroy some open road. Super stoked for you. Watch out for O.C.'s finest.
The Following User Says Thank You to DAEMANO For This Useful Post:
l0aded (01-15-2015)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
