Old 01-10-2015, 12:00 AM   #211
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm going to be changing my diff fluid every 15k, and tranny every 20-30k. I don't believe in "lifetime" fluid on parts that are going through that much stress and operation constantly. I care about my car too much to not do proactive maintenance.
JB86'd is offline   Reply With Quote
Old 01-10-2015, 01:45 PM   #212
Tenament05
Drives: fast
Originally Posted by Decay107 View Post
Nope, coolant is listed at an 11 year 137K mile interval, trans and diff are only listed as "inspect" with no change interval. If you get every service done by the dealer, you will NEVER get new trans or diff fluid, hence it is considered a "lifetime fluid".
I totally agree though that one should change both as a maintenance item.
I know super blue is not considered lifetime, but the VW/Audi/Porsche G13 coolant is considered "lifetime"... thought perhaps that's where you got the term lifetime from, or from the Mini Cooper farse
I don't know where you got that they'll never change your trans or diff fluid but that inspection is to determine when to change the fluids. It's not touted as lifetime fluid is what I'm getting at.
If your service department is not competent enough to recognize fluid needing change or skimps on their fiduciary responsibility to take care of your vehicle, find a new dealer.
Tenament05 is offline   Reply With Quote
Old 01-10-2015, 03:39 PM   #213
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Originally Posted by GT86FI View Post
Any others using Motorcraft fluid?
I'm considering to try this.
Let me know if you try it or where you purchase it. Interested in the results.
n8dog11914 is offline   Reply With Quote
Old 01-10-2015, 04:00 PM   #214
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
There is no inspection called out for transmission fluid which means the techs will only touch it if there is a problem. No preventative maintenance will be performed at the dealer and level inspections are no even called for.
As for the diff, the "inspection" is fluid level only, not quality.
For me, I'll be changing both out biennially as a preventative measure. I don't personally trust the service department to make my car last much longer than the warranty period as they have already demonstrated their alarming lack of knowledge regarding this platform. My Toyota dealer mistakenly filled my coolant reservoir with washer fluid, and my local Subaru dealer gave me a bottle of STI GL-5 transmission fluid for my car and insisted that "it's what the techs use when BRZ owners request a transmission fluid change"
Decay107 is offline   Reply With Quote
Old 01-10-2015, 07:11 PM   #215
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
If you want it done right always better to do it yourself :p
Young_makaveli is offline   Reply With Quote
The Following User Says Thank You to Young_makaveli For This Useful Post:
Marx (01-12-2015)
Old 01-10-2015, 08:48 PM   #216
Tenament05
Drives: fast
amen ^
I don't know why I'm splitting hairs over this.. motul 300 is in mine and will be there to stay, ha
Old 01-10-2015, 08:56 PM   #217
yaguphire
Drives: white-out FR-S
Motul 300 how is it when cold shifting?
yaguphire is offline   Reply With Quote
Old 01-11-2015, 02:31 AM   #218
chas3wba0
chas3wba0's Avatar
Drives: Yes
Sometimes doesn't want to go into 1st or R if it's very cold. No issues once you get moving though
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 01-11-2015, 02:45 AM   #219
Young_makaveli
Drives: 2013 frs
Stock fluid and shifts fine -30 degrees Celsius :p
Old 01-11-2015, 06:24 PM   #220
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Funny. Mine wouldn't shift AT ALL with the stock fluid at anything less than 60 F.
Sellout is offline   Reply With Quote
Old 01-14-2015, 08:19 AM   #221
GT86FI
Drives: GT86
I have had the Motorcraft fluid XT-M5-QS (Ford 75W-90 BO here in Europe) in the gearbox for 4000 miles now.
Impressions compared to stock fluid:
-shifts are less crunchy (2nd gear)
-2nd gear still refuses to go in when cold (below 0°C), even more than with the stock fluid
-slight resistance in all gears during shifting after fully warmed up
Overall conclusion: Gearbox feels marginally better than with the stock fluid...search for the perfect transmission fluid for 86/fr-s/brz still continues...
Motorcraft fluid should be available at least from Ford dealers.
GT86FI is offline   Reply With Quote
The Following User Says Thank You to GT86FI For This Useful Post:
n8dog11914 (01-14-2015)
Old 01-14-2015, 09:33 AM   #222
Sellout
Mr. Cranky Pants
Sellout's Avatar
Try redline MT90 or Motul Gear300. I really like the Gear300 in mine.
Old 01-14-2015, 03:12 PM   #223
n8dog11914
n8dog11914's Avatar
Also interested in where you guys are purchasing OE manual trans fluid GL3/4 as I went to both my local Subaru and Scion dealership neither of them could sell me individual quart sizes. They said no one purchases it from the dealer. When a customer brings in the car they just apparently order a gallon size... That was quite surprising.
I did find the GL5 Subaru diff oil on Amazon but not the trans GL3/4.
Old 01-14-2015, 08:05 PM   #224
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Motul Gear 300 75w90 for the tranny and Diff
Alltezza is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 11:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
