Old 09-30-2014, 01:18 PM   #1
Powered By Jay
Drives: Asphalt FR-S MT
TOMs & turn signal issue
This morning I noticed my right turn signal arrow was constantly lit after my first time signaling on the drive. I tried signaling left and right but no changes.The light stayed on even when I pulled over and turned the car off. I walked around the car and my left turn signals around the car were also constantly lit. I then turned on the hazards and they worked and temporarily fixed the problem.
I then continued my drive and was signaling left when suddenly the signaling stopped and the right arrow stayed lit again. I pulled over again and tried the hazard trick but this time it took me about 5 minutes of messing with the hazards and starting and shutting off the engine until if finally worked. At that point I was late to work so I just finished my drive without signaling.
Anyone run into an issue like this? I have the JDM TOM's tail lights and used the relay that was included.
Powered By Jay is offline   Reply With Quote
Old 10-01-2014, 02:16 AM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
You could try fitting the factory relay back on, and if the signals flash (albeit very fast) at least you can rule out whether the tail lights are faulty.
If the relay is faulty, get a new TapTurn relay (vendor is on this forum).
Fizz is offline   Reply With Quote
Old 10-01-2014, 12:41 PM   #3
slowstang
Drives: '14 Whiteout
Coincidentally, this exact issue popped up on me two days ago, except it was always my right turn signals staying lit. Turning the car off and unlocking/locking with the key fob always cleared mine up.
It is the flasher relay that is bad, and I picked up a replacement at autozone, it's part number LM449, which gets it back to working right, however it flashes a wee bit faster than normal (but not hyperblink), and it's mechanical (maybe the wrong term?) so you get an extra little clicking when the turn signal is activated.
After a bunch of cross referencing, I decided to order part number 81980-50030 (only available through some online vendors it seems) which I think is the equivalent to what was shipped with the taillights, and should get it back to the way I liked it.
slowstang is offline   Reply With Quote
Old 10-01-2014, 06:52 PM   #4
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
As stated above its the flasher relay. You can smack it to get it unstuck as a short term fix. I had this with my toms as well, got the tap turn relay and no more issues. It has a lot of abilities built in if you have f1 style flashers, etc.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Old 10-03-2014, 01:37 AM   #5
Inextirpable
Awesome
Inextirpable's Avatar
Drives: World Rally Blue Subaru BRZ
Wow, this exact problem happened to me at the beginning of the week minus the fact that it was with my left turn signals. I did some troubleshooting and figured out it was due to the flasher, I already have a new one on the way. I will update once I install it.
Inextirpable is offline   Reply With Quote
Old 10-03-2014, 02:42 PM   #6
Apeks
Drives: bananaphone
I had this happen a few months back as well, I took out the relay and noticed that the housing for the relay was cracked. i just ended up ordering a tapturn relay since it got rid of the pause on the first blink
Apeks is offline   Reply With Quote
Old 10-03-2014, 10:16 PM   #7
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
I had the same issue, just pulled out the relay and reseated everything. It's working fine now.
ScottDRFT is offline   Reply With Quote
Old 10-08-2014, 10:27 AM   #8
slowstang
An update for those that care: Flasher part number 81980-50030 does seem to be an identical part to the one that was shipped with the tail lights.
I did smack my origanl part around and tried reseating it but it never cleared itself up, so I'm assuming it was defective.
The Following User Says Thank You to slowstang For This Useful Post:
mokinbird87 (11-21-2014)
Old 01-13-2015, 10:17 AM   #9
Tenament05
Drives: fast
-- EDIT solved it.. switchback led installed with polarity reversed. Refer --> http://www.ft86club.com/forums/showp...1&postcount=20
reporting the same exact issue- right side indicator stays lit and the right side blinker in the back as well.
- Brand new Tap Turn relay (Tom's relay did the same thing)
- Diode Dynamics switchbacks
- Tom's Red JDM lights
Did the new relay solve it?
Tenament05 is offline   Reply With Quote
Old 01-13-2015, 10:16 PM   #10
fx35s
Drives: 2013 Subaru BRZ
Originally Posted by Tenament05 View Post
+1, reporting the same exact issue- right side indicator stays lit and the right side blinker in the back as well.
Hmm.. that's really interesting.
Could flash relay that came with TOM's and TapTurn both be bad?
Chances look slim but you never know.. but then again that'd suck to wait for a new TapTurn Flash relay if it was indeed the relay's problem.
And how long have you had your TOM's installed and when did the problem occur if you don't mind sharing with us? (I ordered TOM's tailights + tapturn as well and am waiting for those...)
Keep us posted on your finding man!
fx35s is offline   Reply With Quote
Old 01-14-2015, 01:19 AM   #11
Tenament05
Drives: fast
confirmed with three different relays- stock, Tom's, and TapTurn, that the problem persists.
Here's a complete description of the problem:
1. With the key off or turned to 'accessory on', in any light mode (auto, DRL, lights on) the right turn signal indicator turns on (dim). However the right turn signal LEDs themselves do not light up with the key off or turned on to 'accessory on'.
2. When I start the vehicle, the rear LEDs light up in every mode (auto, DRL, and lights on). The right turn signal indicator continues to stay lit (dim).
Two additional things I've noticed:
- When I turn the vehicle off, but keep the lights on in any mode, the right turn signal LEDs stay lit, but are BARELY LIT. When I turn the lights off and back on to any mode w/o starting the car again, the turn signal behavior acts as described above in #1.
- When I turn the lights on, I've noticed that the LEFT switchback flickers amber briefly before both turn on white. I just noticed this because my office has a glass door that I'm parked right in front of. This is the first time I've noticed this and am very suspect that the switchbacks may be the culprit. I will report more tonight.
Last edited by Tenament05; 01-14-2015 at 02:28 PM. Reason: added detailed description of problem and additional observations
The Following User Says Thank You to Tenament05 For This Useful Post:
fx35s (01-14-2015)
Old 01-14-2015, 01:24 AM   #12
fx35s
confirmed with three different relays- stock, Tom's, and TapTurn, that the problem persists. The turn signal only illuminates when the key is in the 'on' position.
I will take out my switchbacks tomorrow and see if that plays a role.
Does that mean when you have your car on, the problem goes away?
And by Red JDM TOM's, do you have the one that you have to re-pin?
I purchased the TOM's "DOT" version in Red which doesn't require re-pinning. I hope mine will be alright.. and by the way, I have a BRZ.
Thanks and I hope you can find a solution soon!
Old 01-14-2015, 10:56 AM   #13
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
Following everything said in this thread, and especially with this clue ...
I'll wager the issue will be found and corrected on that side of the car front or rear: something to do with the bulb, how it's seated in the socket, the socket contacts and their wiring, the lens/lamp housing and how that's wired internally, the housing connector and how it's connecting with the car harness, the car harness, or wiring near the harness. Looking for breaks in wiring, loose pins, non-contact of mating surfaces, poor grounding... etc. Of course, you won't be able to spot these things inside an LED bulb... but can happen in there too.
It appears the power for corner marker lamps (on when key is on) is crossing, leaking, or shorting over to the signaling circuit on that side of the car. When this happens, that whole side signaling circuit would light up because it's all connected on the same wire, front, rear and dash indicator. Unplugging the flasher completely would probably not change it...
Your bulb swap idea will rule out bulb issues right away, please get back to us here on progress.
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
The Following User Says Thank You to scottmcphee For This Useful Post:
Tenament05 (01-14-2015)
Old 01-14-2015, 11:07 AM   #14
Tenament05
Drives: fast
Originally Posted by scottmcphee View Post
Following everything said this thread, and especially with this clue ...
I'll wager the issue will be found and corrected in that corner of the car.
absolutely love my tapturn, so I'm thankful it's not that.
I recently changed to LED DRLs and switchbacks. Let's hope it is that.
OLM turn signal switchback issue Scavanger Scion FR-S / Toyota 86 GT86 General Forum 5 09-17-2014 12:42 PM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 03:13 PM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 01:47 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 07:06 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 04:32 AM
