Old 01-12-2015, 06:08 PM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by extrashaky View Post
And then he could listen to them while he was waiting two hours for the tow truck to arrive rather than just changing his flat himself.
Or wait a minute. Do Porsche owners actually change their own tires?
While I don't disagree with your reasoning, your logic is flawed.
The same reasoning applies to anyone that has swapped to larger brake calipers that isn't running a full-size replacement spare in our cars.
Case in point:
  • AP Sprint BBK up front
  • some type of aftermarket wheels (square setup) w/ non-OE size tires
  • you blow a front tire or otherwise have a flat in one of your front tires.
Without a full-size spare, you are stuck with a tow truck situation. Why?
- Have to put rear wheel(s) on the front to clear brakes, depending on rotational direction of tires
- Have to put spare on rear axle, which will destroy your differential or otherwise put excessive strain on the Torsen LSD
- See above.
Sometimes it doesn't take a subwoofer to get one in this situation, and I am willing to bet it happens a lot more than most people realize.
-alex
Anyone interested in custom steering wheel cover? RedlineGoods Cosmetic Modification (Interior/Exterior/Lighting) 40 07-31-2014 05:24 PM
Custom Hello Kitty Intake Manifold Cover (seriously?) Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 6 04-01-2013 01:36 PM
BRZ/86 Heated Seats Switch - Full Plaque Cover Trim 86_ZN6 Interior Parts (Incl. Lighting) 0 01-21-2013 11:49 AM
86 centre switch cover Ryan86 AFRICA 47 12-06-2012 12:23 PM
Center console heated seats switch place cover doggy Cosmetic Modification (Interior/Exterior/Lighting) 7 11-17-2012 11:19 AM
