Drives: Scion FRS Firestorm MT
Center console heated seats switch place cover
Saturday - is the day i ussualy spend working on my car - so it was up to make something once again
Was really hating empty place in the center console - so as i had some left overs from CF plates - decided i will do a quick cover plate...I had some 86 logo cut from vinil before (did some airbrushing) so i used one of these to get template: ![]() Glued vinyl template on CF - and cut it over with dremel, drilled some holes with drill: ![]() Using some really thin files sanded down in letter openings: ![]() ![]() Removed vinyl, and oversanded everything with 800 wet grit: ![]() As you saw in the earlyer photos i cut template for the center console opening from cardboard before - so i used this one to mark on CF exact shape. Use some masking tape - it will be easyer to mark shape on CF - and it will serve as protection while sanding: ![]() After you get the right shape - oversand everything with 800grit wer also. After both shapes done - i used some glue to glue 86 logo on the plate. ![]() To fill up lower space- i airbrushed my Logo on - and clearcoated everything. Will get pictures later how it looks installed in place ![]()
Drives: Subaru BRZ Limited
That's a really nice piece! Good work!
Here are quick pics i took once clear dryed. Will get a proper pics once im done with interior
Drives: Audi A3
That's really neat! Good stuff
Black? |
Drives: Firestorm FR-S (MT)
Nice work. I want to do something similar with that area. Would you mind sharing the measurements of the bigger piece?
Drives: FRS
I want to do all the silver trim in CF this is exactly what I was looking to do wish I was that talented with this stuff looking real good
_____________________________________________
http://genometuning.com http://www.BlackHandGaming.com |
| heated seats | debs0712 | Cosmetic Modification (Interior/Exterior/Lighting) | 47 | 04-08-2018 09:06 PM |
| Help Removing Rear Seats and Rear Part of Center Console | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-27-2012 03:11 PM |
| Switch to Subaru center caps? | SkitterSkotter | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 08-26-2012 10:21 PM |
| Center Console | encity5 | Electronics | Audio | NAV | Infotainment | 1 | 06-10-2012 09:22 AM |
| Retrofit heated seats to Premium? | blalor | BRZ First-Gen (2012+) — General Topics | 4 | 05-31-2012 07:50 AM |
