Old 12-08-2014, 04:55 PM   #1023
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by tigermack View Post
Would additives help? Just wondering...
You can add a dab of TWC-3 two-stroke oil when filling up with gas. In my experience, it takes until the second fill up to notice the decrease in noise.
I used a couple squirts of an eye dropper per tank. After a while, it gets annoying to do this, so it's just a matter of trading one annoyance for another.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
tigermack (12-08-2014)
Old 12-08-2014, 04:56 PM   #1024
2point0
2point0's Avatar
E85 was quieter for me in the beginning, but not with my current pump. Never did try adding the two-stroke oil with E85, though...
Old 01-11-2015, 02:15 AM   #1025
SOLDIER [X]
Drives: 2014 SWP BRZ Limited
3,000 miles without crickets on an MY14, just noticed them today. Well my wife did since I'm half deaf. Still no solution?
SOLDIER [X] is offline   Reply With Quote
Old 01-11-2015, 02:27 AM   #1026
Nothing.
You will get al sorts of "this works for me" comments but nothing works for everybody.
I have had them once for one tank of gas on my 14 but that may be because I got it late in the year and it wasn't that hot out and there is certainly a correlation between temperature and chirps.
Do not bother changing the pump as it will just happen again anyway and our14s already have the latest version of the pump to start with. I don't think they will ever "fix" it as it is not really a problem just an annoyance.
SOLDIER [X] (01-11-2015)
Old 01-11-2015, 07:59 AM   #1027
BRZnut
Drives: BRZ DGM Limited
do a Google search for.. crickets 2 cycle oil...and you'll find your answer
Old 01-11-2015, 02:28 PM   #1028
gravitylover
Is there an aftermarket fuel pump available that doesn't chirp?
Old 01-11-2015, 02:48 PM   #1029
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Try different brand of gas by ur house. I was putting in Shell like ppl suggest, but the crickets were strong with shell. Chevron makes mine quiet. I always like chevron more then any other brand of gas thou. Seem to make my engine run smooth with better power? At least I only put chevron in my CRV so highway merge didn't feel like I need to murder something while doing it.
Old 01-11-2015, 05:45 PM   #1030
gravitylover
I'm not real picky, usually use Shell or Sunoco but I've run all sorts and it doesn't seem to matter.
Next...
Old 01-11-2015, 07:38 PM   #1031
iarefluffy
iarefluffy's Avatar
Drives: CWP series blue brz
I also use chevron, found that it'll reduce the crickets on short drives (around 10-20 minutes of driving until crickets are heard) if im not pushing the car.
must be all that techron they put in their fuel!
iarefluffy is offline   Reply With Quote
Old 01-12-2015, 09:29 AM   #1032
HunterGreene
Hail Magnet
HunterGreene's Avatar
No.
It has priests in it?
Old 01-12-2015, 10:01 AM   #1033
For Grins and Giggles, plus because I'm almost out of the 60K warranty, I took mine in a couple of weeks ago and had the TSB done. Mind you I didn't really think I had crickets.
I ended up with all the new equipment (the TSB bill was $1,600, as they first presented me the wrong copy) but to me the engine sounds exactly the same.
I figure, worse case, I got a new fuel pump.
Tcoat (01-12-2015)
Old 01-12-2015, 10:57 AM   #1034
Oh great now these cars just went up in price .0000000002 cents!
Dadhawk (01-12-2015)
Old 01-12-2015, 12:49 PM   #1035
frslee
Just drive it
Drives: 13' FR-S
The noise is back! At least I have the new pump.. haha
frslee is offline   Reply With Quote
Old 01-12-2015, 02:13 PM   #1036
wrussi
wrussi's Avatar
Drives: 2013 frs
guys i think i solved the issue! the part that you need to replace is the vechicle. when you replace the vehicle for another one the crickets go away!!
on a serious note i think we should just give up on the issue. toyota wont do anything.
wrussi is offline   Reply With Quote
The Following User Says Thank You to wrussi For This Useful Post:
Tcoat (01-12-2015)
Hood & Bumper Gap on BRZ mact Issues | Warranty | Recalls / TSB 17 02-25-2015 12:22 PM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
Dry carbon fiber hood ChrisOkc8 Cosmetic Modification (Interior/Exterior/Lighting) 13 08-26-2012 10:58 AM
vented hood? 75 carrera Cosmetic Modification (Interior/Exterior/Lighting) 2 07-02-2012 09:57 PM
