Old 01-10-2015, 12:49 PM   #1
bren5279
Drives: series.blurrr
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response
SOLVED!!!
Shoutout to a local car guru friend for figuring it out.
Solution:
It was actually a combination of several things. weirdly enough the stock evap solenoid below the intake (the one you disconnect) was stuck open allowing air to be drawn in acting like a leak, yet when we pressure tested it nothing could be heard. the low pressure caused the high idle but the pressure I guess was compensated for in the tune but also caused vvt lockout on initialization. 2 hours of pressure testing, capping off the intake with a hockey puck, and line rerouting, 5 reflashes later and sucess!!! Hopefully if anyone else ever has this issue this'll help!
Background:
-JDL turbo kit on 2015 manual
-First flash all VVTs worked, second one they didnt, went back to first flash and now they still dont work. All the meanwhile the rpm's are all over the place between 1500-3k when I push the clutch in after cruising.
Symptoms:
-Intake CAM Targets: exactly as expected
-Intake CAM Positions: all hover right around 0 plus or minus 1 degree, no changes regardless of throttle.
-Exhaust CAM Targets: all 0, regardless of throttle change
-Exhaust CAM Positions: all exactly 0
-no CEL's
-no identifiable boost leak
What we've tried:
First flash; all VVT's worked
Second flash; VVT's stopped working and acted as described above
Flashed back to first map; VVT's still not working
Flashed it, idled for 5 minutes, drove for 5 minutes, reflashed it, idled for 5 minutes, then drove and datalogged, still nothing.
What Ive checked:
-All vvt plugs are connected (confirmed several times)
-oil pressure is good
-Solenoids get 12v
-Solenoid ground signal wires are connected to the ecm (confirmed by -voltmeter)
bren5279 is offline   Reply With Quote
The Following User Says Thank You to bren5279 For This Useful Post:
rixter145 (05-18-2021)
Old 01-10-2015, 12:59 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
See here: http://www.ft86club.com/forums/showp...7&postcount=10
Can't account for the RPM fluctuating. Not an SD based issue either?
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-10-2015, 01:20 PM   #3
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Originally Posted by bren5279 View Post
Ok, so for the last week, me, delicious tuning, and a very experienced 86 mechanic have been trying to figure this out unsuccessfully and now we're absolutely stumped, so Im offering100$ reward to anyone who can help us figure this out.
Background:
Symptoms:
-no CEL's
What we've tried:
What Ive checked:
-Solenoids get 12v
We're all completely stumped and out of ideas to even diagnose what it is. So Im offering 100$ to anyone who can help us figure out what it is.
Hopefully you don't have this issue. http://www.ft86club.com/forums/showp...postcount=2970
The Cam Sproket on the exhaust will pop out and will lose oil pressure causing exhaust cam not to work properly.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
Old 01-10-2015, 01:21 PM   #4
DesertFrs
DesertFrs's Avatar
Also because you haven't been driving the car no codes have popped up .
Old 01-10-2015, 01:48 PM   #5
bren5279
Nope, the car doesnt stall out at all, the only thing it does is when cruising then pushing in the clutch and coming to a stop, it rpm hunts between 1500-3000
No, i drove for an hour to make sure, no cel's
we did have a low pressure code and a high idle code but it was due to the map, he changed it and we reflashed it and they went away.
Old 01-10-2015, 02:10 PM   #6
steve99
Drives: FT86
Solve your high idle issue.
the vvt may not become active after an ecu flash/reset untill the car idles at normal speed ie about 750 and speed is zero.
I don't think you need to reflash it just turn it off then start let idle while speed is zero, but idle probably needs to be normal.
As you have no codes its possibly a mechanical problem like air leak or exhaust leak near 02 sensors
Check their is no crap lodged in throttle plate and its closing completely.
check the hoses on intake manifold.
Old 01-10-2015, 02:17 PM   #7
bren5279
Yeah that could possibly be, the idle is almost exactly 1400. Only thing is, when datalogging the start, the vvts dont change at all even on the startup.
Old 01-10-2015, 02:32 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
And my vote goes to cam sprocket!
Old 01-10-2015, 05:40 PM   #9
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
If the TARGET is zero.. that would be the tune, no?
Software/tuning side of things is certainly not my strong point so chances are that I am wrong.. just saying.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 01-11-2015, 04:45 AM   #10
sw20kosh
Drives: 2013 Black FR-S
How could that be a leak? If the solenoid was stuck open it would just allow the evap line to the fuel tank to be open. But the fuel tank is a closed system no?
How did you fix the stuck open solenoid?
Old 03-14-2017, 04:41 AM   #11
CoryCooper
Drives: Toyota 86
So what fixed it exactly? I'm trying to sort this out on mine right now ��
CoryCooper is offline   Reply With Quote
Old 03-14-2017, 05:36 AM   #12
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
More importantly, did you pay the guru the hundred bucks?
geezerbrzeezer is offline   Reply With Quote
Old 03-14-2017, 07:34 AM   #13
Teseo
Drives: frs
Who won the prize?
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 08:36 AM
Cruise control wont set after clutch install? ($$ reward for solution!) bren5279 Issues | Warranty | Recalls / TSB 18 12-05-2014 10:21 AM
EVO 3 exhaust-solution to 3-5k super drone fastseattlegt86 Engine, Exhaust, Transmission 1 10-19-2014 05:03 PM
An alternate solution to Drone problems 86-tundra Engine, Exhaust, Transmission 1 09-26-2013 02:50 AM
My Exhaust solution for the moment Scooby South Engine, Exhaust, Transmission 42 06-18-2012 07:26 PM
