#2367 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
I did my car but I'm looking at upgrading my coolant at the end of the month when I swap all my other fluids. What do u recommend for the stock cooling system?
#2368 |
Drives: Toyota GT86. N/A for life
I am chasing some strong, yet light, 16 inch wheels that can take a 225/45 Advan 050. Any suggestions as the all the wheels I am chasing seem to be discontinued.
Cheers, Jeff |
#2369 | |
There is no 1/3 mile road course that track guys drive at... the *smallest* track we drive in SoCal is 1.8 miles. |
#2370 | |
Now if you have to worry about freezing.... not the best idea. |
#2371 | |
Drives: 2013 STI
That makes sense. Seeing as I prefer roadcourses I guess the RS3 is a better choice (even if I am using it on an STI )
#2372 |
Lol I might run that for track days now that I've mentioned it. But we do get snow and ice here in the NW and last year it was the end of February when we got our big snowstorm lol. So probably not the best idea for dd.
#2373 | |
Oil cooler on the other hand is important for tracking.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
#2374 | |
| The Following User Says Thank You to CSG David For This Useful Post: | VADERR (01-09-2015) |
#2375 |
Lol I've been running a mishi oil cooler with temp/pressure gauges for almost 2 years now.
#2376 |
@CSG Mike hey since I dd as well as track I'm thinking about adding water wetter additive with fresh fluids. The engine comes with submarine green but would u recommend swapping to Toyota red?
#2377 |
Drives: 2014 BRZ
I plan to track my car several times this year and I would like to change pads at home. The closest track is about 45-60 minutes away. Would these pads be okay to use at the track and for the commute to track and back?
I also run with the local autox clubs and I am wondering if these pads would be suitable for autoxing also. Thanks, JP |
#2378 | |
About autocross, why do you want to use non-street pads for that? The only real reason I can see if for higher mu, but then you need to be aware that either you have to warm up the brakes before your first run OR that your first run will be substantially degraded thanks to reduced braking capacity when cold. Personally I would use street pads for autocross (I use DS2500 for street and autocross, I still think of them as street pads).
#2379 | |
#2380 |
I am having an issue that I believe is fuel starvation but want to see if anyone else is having similar issues or if it is something else.
The issues always start when I am getting close to 5/8th of a tank left. It is only happening in two places and both are long high G left hand corners. The first set of corners is a three corner assembly that is run at between 75-80mph at 1.1g and the entire section takes about 10 seconds. I start having issues about 3/4 of the way through the following straight and then it starts cutting out. I enter into the next turn, which is another sweeping left hander done at similar speeds but is only about 4-5 seconds. Once I come out of that I have no power for 3 or 4 seconds when it first starts happening and about 10-15 seconds once I get below half a tank. Once the power comes back, I can run the rest of the track fine until I reach that section again. First, is this fuel starvation? Second, if so, what options do we have to handle this? Running E85 the car is burning through 3/8 tank in a 30 minute session and there is no e85 within 20 miles of the track, so I can't easily keep it at a full tank. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
