Old 05-09-2012, 10:34 PM   #1
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
HID Yellow Fog Lights and Rear Halogen Fog Light
Alrighty, I searched for any threads pertaining to the front fogs, but did not find much, so here goes:
One of the first things I am going to do with the BRZ is dump the factory fog light bulbs (since they are usually crap), and replace them with yellow HID units. I also want to install an actual fog light in the rear. I am thinking an intensity level somewhere along the lines of what MINI uses for the rear.
I am the type of guy who only uses his fog lights in rain, fog, and other reduced visibility scenarios. Be that the case, I would not mind if the rear fog lights were activated by the switch, which runs the front lights. I will more than likely have to run a larger relay, but it's fine by me since I will have the functionality I am looking for along with a clean interior with no aftermarket switch for the rear fog light. Then again, if happen across and OEM switch for the rear light, who am I to complain?
Do any of you gents. know of a reputable HID vendor? Are any of you guys knowledgable on this subject and/or have (or currently do) run yellow HID front fogs? Any input would be appreciated, and thanks in advance.
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
Old 05-11-2012, 09:34 AM   #2
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Many HID yellow bulbs are just a regular hid bulb dipped in a yellow coating. It makes them not as bright and they're not that yellow. I usually recommend to customers PIAA plasma ion yellow bulbs along with lumin-x yellow over the fog housing. That also aids in protecting it from rock chips and fading.
Heres a pic of my old car with this set up
PrimeMotoring is offline   Reply With Quote
Old 05-11-2012, 08:05 PM   #3
Godzilla35
Drives: Nissan GT-R
Friend had HIDs from DDM Tuning... I believe yellow is 3K? I could be wrong, but they were very cheap and still work. Compact mounting size too. I'd get a warranty package if they have one though... lights, bulbs and other HID related things tend to have bad "batches"
Godzilla35 is offline   Reply With Quote
Old 05-11-2012, 10:00 PM   #4
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I always thought hid in foods were a bad idea? Melting from heat or not really fogs so they don't work well when in actual fog
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 05-12-2012, 12:42 AM   #5
Lighting Red
Finally, some feed-back! Great picture as your Audi is representing pretty much what I am looking for. I previously poked around Tire Rack to learn up on yellow HID bulbs and ballasts. That said, I won't hesitate to check your site out
I will check out your solution - all I am looking for is some good, long wave length light at sufficient intensity to cut through fog and rain.
Old 05-12-2012, 12:54 AM   #6
Lighting Red
As I understand it, longer wavelength light in the visible spectrum (such as yellow and amber) does not scatter as readily as white light. The effect to the driver is that there is reduced back-scatter, which is perceived as glare in fog using yellow light vs. white light. That is why people are generally told not to use their high beams in fog. Lots of bright, white light in a fog = lots of backs-scatter.
Fog light color, and placement - i.e. well below driver's line of sight - reduces back-scatter, allows the driver to see in foggy conditions, and allows other drivers to see you without being blinded.
Old 05-12-2012, 01:01 AM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
most HIDs now are manufactured in the same factory in china. then privately labeled and branded
just make sure choose a seller that has lifetime warranty on their bulbs
yellow is 3000k (kelvin)
if you plan to put HIDs on the fogs you will need to drill a hole on the housing for the wirings
86_ZN6 is offline   Reply With Quote
Old 05-14-2012, 12:50 AM   #8
Nate219BRZ
Nate219BRZ's Avatar
Drives: Rip 04 golf gti rip 05 scion TC
euroeffects.net is my buddy's shop. People may have seen us at the LA (my trip), Miami, Chicago, Las Vegas, etc Auto shows. CAN-BUS ballasts, not cheap, works for 6 months and its out, 49.99 junk... 35 watt and 55 watt kits are both available. As well as any Interior/Exterior illumination. Also checking the availability of colors for their stock (D4S BRZ) bulb replacements and their DRL replacement colors.
Nate219BRZ is offline   Reply With Quote
Old 05-14-2012, 02:11 AM   #9
dnjshin0bi
dnjshin0bi's Avatar
Drives: 86 GTS (PW) Manual
hey guys what is the foglight bulb size/socket? would it be H11?
dnjshin0bi is offline   Reply With Quote
Old 05-14-2012, 09:35 PM   #10
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
I don't know if this is helpful, but I've had Nokya Hyper Yellow bulbs in my scion tC's fog lights for a few years now and they work perfectly fine for me. You might not need to spend $$$ on HID kits. Here are some old pics from my cell in '07:
Mari0 is offline   Reply With Quote
Old 05-15-2012, 09:07 AM   #11
robotvoice
Drives: 07 STI
You never want to use HID bulbs in your fog light housings. Ever. It's too much light being scattered directly in front of your car and this makes it harder to see down the road in bad weather. This is why there are no cars that come from the factory with HID fog lights, it just doesn't work.
robotvoice is offline   Reply With Quote
Old 05-18-2012, 02:28 PM   #12
jjdrivesajazz
Drives:
here's a picture of a subaru wrx i've done in the past
HID 6000k headlights and HID 3000k fog lights
jjdrivesajazz is offline   Reply With Quote
Old 05-18-2012, 04:29 PM   #13
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Fog Lamps: PSX24W also known as the old H3
Old 05-18-2012, 04:35 PM   #14
StuttterButtter
Yes i have a stutter
StuttterButtter's Avatar
Drives: 94 Acura Integra
Awesome i have some H3's laying around still.
StuttterButtter is offline   Reply With Quote
Rear Fog Light Thread robotvoice Cosmetic Modification (Interior/Exterior/Lighting) 38 03-11-2023 01:32 PM
6000k Halogen bulbs? CyberFormula Cosmetic Modification (Interior/Exterior/Lighting) 8 04-22-2012 03:41 AM
Rear lights difference… gtaqv Scion FR-S / Toyota 86 GT86 General Forum 15 01-26-2012 11:59 AM
why do we assume no hid lights? subaruslow Scion FR-S / Toyota 86 GT86 General Forum 6 12-01-2011 02:39 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
