Old 01-07-2015, 02:47 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by cdrazic93 View Post
be warned, the lower you go without quality coilovers, i.e. on just springs the worse the ride will be
fixed
cdrazic93 (01-07-2015)
Old 01-07-2015, 07:29 AM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
fixed
My bad, you better be "slamming that frame" with those AST 5200's. Yo.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Captain Snooze (01-07-2015)
Old 01-07-2015, 09:45 AM   #17
brianhj
Drives: 2017 Camaro 1SS
be warned, the lower you go without coilovers, i.e. on just springs the worse the ride will be
What if I'm just dropping an inch? On an otherwise stock car would Eibach springs give better or worse ride quality?
brianhj is offline   Reply With Quote
Old 01-07-2015, 10:58 AM   #18
twag4
Drives: frs
I used Eibach pro line with their sway bars, I can honestly say that the 245/40-14 tires were more noticeable than the springs. I ran them a few days before I could install the springs and sway bars. The ride overall is a little bit firmer, but handling is also better. I had camber bolts that the alignment shop was going to put in, but they didn't as the front camber was zero. I wanted a little negative camber (-1 degree) so I'm going to take it back. I'm also going to get SPL rear lower control arms and get my rear -2 degrees to to -1 degree of camber. I'm very happy with the choice I made. Even the low priced coil overs with sway bars would be over $1100. The Eibach pro plus kit can be had for under $500. It comes with springs, bottoming bumpers, rear dust boots, and sway bars. It is a good deal. I researched quite a bit to discover the ride quality was reported to be better with the Eibachs compared to the hotchkis total vehicle system. It was the other non coil over kit I considered.
twag4 is offline   Reply With Quote
The Following 2 Users Say Thank You to twag4 For This Useful Post:
brianhj (01-07-2015), kodyo (01-07-2015)
Old 01-07-2015, 11:40 AM   #19
xRavenFRSx
xRavenFRSx's Avatar
Drives: 2014 Raven FR-S
Originally Posted by Sh944 View Post
If you aren't planning on tracking your car, I'd make a hard case for the TRD lowering springs. I put a set on my FR-S for the same reasons you stated and absolutely love the way they look and even more so, the way the car rides now. Its much better than the original springs, imo. Best of all, you don't have to mess with the camber.
I have the TRD lowering springs and love them. My rear camber was showing -1.7 on left and -2.3 right, everything else was good. I had them installed free at a friends shop and one of his guys checked the alignment. I need to get it checked somewhere else to make sure that's right before I buy anything to correct it.
xRavenFRSx is offline   Reply With Quote
Old 01-07-2015, 03:38 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Usually an inch is questionable if you lose ride quality or not, just shock travel. Meaning youll hit bump stops alot faster from pot holes.
brianhj (01-09-2015)
Old 01-09-2015, 12:46 PM   #21
cycleboy
Drives: 2013 Scion FR-S - Argento
I've got RCR Yellows, camber bolts, and SPL LCA's sitting in my garage waiting for me to decide if I'm confident enough to do the swap or if I pay someone to. It doesn't appear that difficult, I just don't want to get into it and find I'm over my head.
I knew I didn't necessarily need the LCA's and bolts, but I didn't want to put the springs on and find something was out of whack and then have to take it all apart and redo it with those parts. So I just held onto the springs until I had the $ to get the LCA's I wanted.
cycleboy is offline   Reply With Quote
Old 02-18-2015, 08:33 AM   #22
FRStrent
Drives: Scion FRS
I know this thread is old but I need some more advice. I got the Eibach Sportline springs (about 1.5" drop). I also ordered front and rear camber kit.
My question is, will I need a rear toe kit? Just looking at the rear assembly it only makes sense. As the negative camber is corrected it looks like the factory toe arm will start to push the front of the wheel outward (which could be corrected with a toe kit).
Any suggestions on this or first hand experience?
Thank you.
FRStrent is offline   Reply With Quote
Old 02-18-2015, 09:48 AM   #23
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Thank you.
Just read the above post about how dropping more than a inch usually results in negative camber requiring LCA's to correct.
brandonblt2 is offline   Reply With Quote
Old 02-18-2015, 09:57 AM   #24
FRStrent
Drives: Scion FRS
The rear camber kit I bought is the LCA's. The toe arms are completely separate from the LCA's and I am curious if I need to get an adjustable toe arm kit?
Old 02-18-2015, 10:01 AM   #25
brandonblt2
Ohh sorry misunderstood the question then. For that I don't have an answer for.
Old 02-18-2015, 10:04 AM   #26
was385
Drives: MT WRB BRZ Limited, 2007 911s
Thank you.
The car has rear toe adjustment from the factory.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
FRStrent (02-18-2015)
Old 02-18-2015, 10:57 AM   #27
FRStrent
Drives: Scion FRS
Thanks. Did not know that it was adjustable. So I should be good.
Old 02-18-2015, 10:59 AM   #28
FRStrent
Drives: Scion FRS
Does anyone know about how low you can go until you max out the OEM toe arm adjustments? Or does this not happen? I just don't want to get it on the alignment rack and realize that I need to adjust my toe more than the stock toe arms allow. Just thinking ahead is all.
Thanks.
TRD Lowering Springs? Jrryjms07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-03-2014 11:49 PM
WTS H&R Lowering Springs (Never used) g0ast Brakes, Suspension, Chassis 3 05-21-2013 11:34 AM
TRD Lowering Springs? kALMIGHTY Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-29-2013 10:10 AM
For those with lowering springs. wawro569 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-10-2013 01:36 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-10-2012 11:36 PM
