Old 01-06-2015, 10:13 AM   #29
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
My ark pipe is just awesome
I don't use it, if u local to az and want it lmk
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
RobertPaulson (01-07-2015)
Old 01-06-2015, 06:06 PM   #30
BRZ.PTY
Drives: BRZ limited 2013
Originally Posted by mid_life_crisis View Post
As long as it doesn't involve calculus, which has completely purged itself from my memory, that would be appreciated.
How much of a range is one effective for? For example, I'm most concerned about cruising through the neighborhood in the morning, which centers around 2000 rpm or so, but highway cruising at 2600 would be nice to have a little quieter too. If I tuned for 2300 would it be effective for all of that range?
Hahaha don't worry it involves some math but nothing too complicated.
I did mine to kill drone from 2600 to 3000, it kills the drone in that range pretty good. I aimed for the lowest rpm since it will require the longest pipe. The exhaust is a a lot quiter at low rpm but still very loud at higher rpm, this is what I was looking for. Now I can sit in the car during a cold start.
One of the most important parts is to have the pipe welded at 90 degrees angle in order to avoid flow issues.
BRZ.PTY is offline   Reply With Quote
Old 01-07-2015, 08:21 AM   #31
plucas
plucas's Avatar
Drives: Subaru
You need to know your exhaust temperature to properly calculate for a Helmholtz resonator. I just built an excel calculator in no time that calculates the frequency of resonance targeted using exhaust temperature, volume of resonator, connector tube length, and connector tube ID. The temperature would be used as a constant and the others can be changed to target whatever rpm needed. Maybe I can upload it...
plucas is offline   Reply With Quote
Old 01-07-2015, 09:37 AM   #32
BRZ.PTY
@mid_life_crisis
I posted a somewhat detailed DIY guide in the DIY section on how to build the resonator.
Feel free to contact me if you have any question
Stock resonator removal? jm1681 Engine, Exhaust, Transmission 33 10-11-2019 06:58 PM
Intake resonator?? DIE1000DEATHS Engine, Exhaust, Transmission 16 12-03-2014 08:17 PM
Glasspack or Resonator Delete or ? Yruyur Engine, Exhaust, Transmission 6 02-02-2013 01:13 AM
Ordering Nameless Exhaust - Helmholtz Resonator?? Umbie Engine, Exhaust, Transmission 16 12-03-2012 01:48 PM
Perrin Catback w/ Resonator Minetious Engine, Exhaust, Transmission 10 09-08-2012 11:24 AM
