Old 09-23-2014, 02:37 AM   #155
PantsDants
Drives: Scion FR-S A/T, Whiteout
So I've noticed I have some corrosive stuff forming on one of my battery terminals (front negative on the standard dump pack, not the big, main terminal). This was one of the batteries I had the arcing mishap on during my install. I haven't taken the cover off to inspect any other terminals just yet.
With this knowledge, should I just clean off the crud, apply corrosion inhibitor and keep an eye on it? Or should I be considering battery replacement at this point? I'm concerned because I thought these were supposed to be sealed batteries. Input is appreciated, thanks.
PantsDants is offline   Reply With Quote
Old 09-23-2014, 03:15 AM   #156
DAEMANO
Time Traveller
Sounds like a reasonable thing to do. OR you could just replace the battery. They're pretty darn cheap so no harm no foul if you just have to get another one.
The Following User Says Thank You to DAEMANO For This Useful Post:
PantsDants (09-23-2014)
Old 09-23-2014, 07:54 AM   #157
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
To play it safe I would snag a new battery. An arced battery may have exceeded its limits of discharge and you are now seeing it's after effects.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 09-23-2014, 11:30 AM   #158
TM
TM's Avatar
Drives: DGM BRZ 6MT
I would replace the battery. Is it covered under warranty?
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
Old 09-23-2014, 02:37 PM   #159
PantsDants
I'm going to buy a replacement, thanks guys. I bought nlowell's kit/batteries so I'm pretty sure the battery warranty doesn't apply to me now anyway.
The Following User Says Thank You to PantsDants For This Useful Post:
DAEMANO (09-23-2014)
Old 10-24-2014, 10:48 PM   #160
07jazzrs5gt86
Drives: Firestorm 86
After 5+months wait finally got my esc 250 1.5 kit installed this past sunday and it's totally worth the wait and $$$.
Been running it every chance i get and its been a real pleasure and so addictive.
I wonder what you guys use to cover up that hole in the passenger hole that you run the wires to the engine bay?
I'm thinking of getting a rubber cap then cut a small hole in the middle then cut it half way to slide the 2 wires to the middle.
Also if anyone one using a light weight pulley kit with the system? Planning on installing my nst pulley kit with the gates belt either this sunday or next weekend.
07jazzrs5gt86 is offline   Reply With Quote
The Following User Says Thank You to 07jazzrs5gt86 For This Useful Post:
DAEMANO (10-24-2014)
Old 10-24-2014, 11:14 PM   #161
DAEMANO
Time Traveller
Since I live in SoCal there's almost no rain (sad face) so I didnt do anything more with the hole. You could get an appropriately sized rubber grommet from any hardware store that would seal it nicely around the wires for about a buck.
Congratulations on your kit. The smiles per dollar ratio can't be beat.
07jazzrs5gt86 (10-25-2014)
Old 10-24-2014, 11:53 PM   #162
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I just took some dense foam, cut it into a cylinder to fit in the existing grommet, cut a split half way through down the length (think pacman) and sandwitched the ESC wires in the slit and pushed it through into the hole. Probably isn't completely waterproof, but It knocked down the engine compartment noise, and should help keep bugs out.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following 2 Users Say Thank You to Target70 For This Useful Post:
07jazzrs5gt86 (10-25-2014), DAEMANO (10-25-2014)
Old 10-25-2014, 11:37 AM   #163
07jazzrs5gt86
Got that firwall hole plug by a rubber cap i found laying around
Just order this as well
[ame="http://www.amazon.com/gp/product/B0039Z5TRC/ref=cm_wl_fci_cancel"]Amazon.com: DEI 010392 Reflect-A-GOLD 12"x 24" Sheet: Automotive[/ame]
Been wanting to do this for a long time as i notice the stock intake box do get pretty hot after driving and i notice it got even hotter after i install the header. So i plan on wrap it with this foil hope to help keep it at at a lower temp.
Few other have done it also here's a link
http://www.ft86club.com/forums/showthread.php?t=49277
Even if the temp don't change much but sure make the stock box looks much better
Old 10-25-2014, 03:11 PM   #164
DAEMANO
Time Traveller
This is a GREAT idea. You'll notice that the ESC is quite responsive to cold air along with warm batteries. This could definitely help create this seemingly mutually exclusive condition.
Old 10-25-2014, 05:09 PM   #165
07jazzrs5gt86
I was thinking of the same thing
Using this to keep the temps more stable
Also i did some googling and found out some people actually use on various supercharger setups to keep the supercharger at better operating temps
So i was wondering if i would to cover this onto the esc would it void any warrant?
Something like this
http://www.scionlife.com/forums/scio...harger-202806/
Old 10-25-2014, 06:36 PM   #166
Target70
Target70's Avatar
Something like this
I doubt Rob would void the warranty over the foil. Theoretically it should have no effect on the operation of the ESC, and only reflect radiant heat away and keep it from heating up the compressor housing. Honestly any close fitting thermally resistant material should work.
You gave me the crazy idea of putting the ESC in a cardboard box, then filling the box up with spray foam insulation. Cut the cardboard box off, and you would have a square/rectangular block of foam that you could paint black to make the ESC look like a resonator box . You would have to keep the motor from getting covered and cover the compressor openings, but It should work quite well.
anyway if you want warm batteries + cold air, you might want to also invest in something like this:
about $30 on amazon
The Following User Says Thank You to Target70 For This Useful Post:
DAEMANO (10-26-2014)
Old 01-05-2015, 04:06 AM   #167
dtek
Drives: 86 A00I
Has anyone had any issues with the voltmeter display unit? Mine has apparently ceased functioning properly, but it still works as an on/off switch for the system and the overall system itself appears to be working as usual. Just the red numerals don't light up or display in any way. This is with the most recent batch of kits (the last of the drag reduction equipped ones).
dtek is offline   Reply With Quote
Old 01-06-2015, 05:34 AM   #168
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
About to join the club . Just wondering has anyone been running e85 with the ESC? Also what are the latest dyno numbers for petrol and e85? Oh and if I have an aftermarket sound system hooked up to my current battery, to put it on the new batteries I would just connect it the same way to the starter one correct?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 04:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 10:51 AM
