Old 01-03-2015, 08:17 PM   #127
Sossman
Sossman's Avatar
Drives: Toyota 86 GTS (MT)
Originally Posted by welllam View Post
+45 too much suck with 3 degree camber Imo. +37 is better for track spec.
Those look like 18's. 18x8?
Sossman is offline   Reply With Quote
Old 01-03-2015, 08:20 PM   #128
Sossman
Sossman's Avatar
Originally Posted by enouf View Post
Here you go, enjoy!
Enouf - Where did you get your wheels from? I've been looking for gunmetal grey RPF1s in Aus but haven't found them anywhere.
Old 01-23-2015, 01:47 PM   #129
rebsinfx
Drives: 86
will 235/45/17 with eibach pro kit experience any issues?
rebsinfx is offline   Reply With Quote
Old 02-02-2015, 01:53 PM   #130
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
who is running spacers?
I know the 17x8 +35 works great, so I was thinking of running a 10mm spacers on my +45, so I end up at +35. However, is there any room to go a touch more?
12mm possibly?
Old 02-03-2015, 12:07 PM   #131
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
12mm possibly?
Do you have extended studs?
Old 02-03-2015, 02:12 PM   #132
continuecrushing
no, but I know I'll need them.
Was gonna swap to arp
Old 02-03-2015, 08:08 PM   #133
BlaineWasHere
Grip>Drift
Drives: FRS
You can run 10-12mm spacers just fine then.
Old 02-03-2015, 08:40 PM   #134
continuecrushing
nice! I figured the 10mm spacer would work since that makes the wheel a 17x8 +35, and those fit just fine. And another 2mm isn't much.
Think I'll have any issues with rubbing? Eventually I'll bump up to a 245/40/17. I'm lowered about 1.25" inches, with -2 camber on all corners.
Just trying to go as flush as possible without rubbing. I just came from an 18x9 +40, so the +45 looks pretty funny/sunk in right now. People at work are giving me crap haha.
Old 02-03-2015, 09:06 PM   #135
dp1
driving smoother faster
Drives: Sold
I'm running rpf1 17x8 +45 on track/ax with AP Racing Sprint BBK, -3f/-2.5r camber, 235/40-17 Toyo RA-1, arp extended studs, Ohlins R&T dampers. They fit both without spacers and with 12mm spacers, no rubbing.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
dsc_pat (12-12-2021)
Old 02-04-2015, 01:47 PM   #136
continuecrushing
sweet. I tried searching through your stuff, but I came up empty handed.
You have any photos of your setup?
Old 02-04-2015, 02:57 PM   #137
dp1
Drives: Sold
I think that this was with the spacers
Old 02-04-2015, 03:00 PM   #138
dp1
Drives: Sold
I have a new set of 17x9 +45 rpf1 with 235/40-17 Nitto NT01 that I will try this season, with 12mm spacers to fit BBK.
Old 03-25-2015, 02:47 PM   #139
continuecrushing
ST Coilovers Dropped 1.25"
Ark Grip Exhaust
Valenti tail Lights
Enkei RPF1 Black 17x8 +45 no spacers with 235/40/17
Trunk Spoiler
Side Skirts
Front Lip
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 06-27-2015, 12:27 AM   #140
smy266
Drives: 2014 BRZ Limited
Just ordered a set of these with star spec tires for my upcoming track day on COTA. Will post pics when I receive them and install them.
smy266 is offline   Reply With Quote
17x8 +45 with 235/45/17, full lock, whatwasthatfrigginsound, wheel pop, wheel rub
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei RSM9 17x8.0 +48 AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-17-2014 06:50 AM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 04:26 PM
