Old 02-23-2014, 09:27 PM   #99
JR007
JR007's Avatar
Drives: Ultramarine FR-S
Originally Posted by vtmike View Post
I don't have any more photos at the moment. Ill take some more tomorrow. Not a big fan of the OEM tires but they still have lots of tread left and want to use them up before getting another set of summer tires. Hopefully they'll be spent after this summer.
Sent from my Nexus 7 using Tapatalk
I couldn't agree more. I hate to dispose of my tires too when they only have 5,000 miles on them and the OEM rims could definitely use an upgrade. Hmm, decisions, decisions.
Btw, where did you order your rims from? Thank you again.
JR007 is offline   Reply With Quote
Old 02-23-2014, 09:45 PM   #100
vtmike
vtmike's Avatar
Drives: Scion FR-S
Oakos. Nothing but good things to say about them, good price, good customer service, and quick shipping.
vtmike is offline   Reply With Quote
Old 02-23-2014, 10:06 PM   #101
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I have the same setup in bronze.
raul is offline   Reply With Quote
Old 02-24-2014, 07:53 AM   #102
vtmike
vtmike's Avatar
Drives: Scion FR-S
Size:  112.5 KBName:  uploadfromtaptalk1393246399001.jpg
Sent from my XT1060 using Tapatalk
Old 02-24-2014, 01:12 PM   #103
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Originally Posted by Khyron686 View Post
Can you post more well lit pictures from a little further back? I think a bit more meat on the sidewall looks great and 235/45 PSS is in the top choice for me as well.
Here you go, enjoy!
enouf is offline   Reply With Quote
Old 03-07-2014, 09:00 PM   #104
THEWAKLER
USMC
THEWAKLER's Avatar
Drives: DGM BRZ LMT
225/45 PSS on ST coils
THEWAKLER is offline   Reply With Quote
Old 03-08-2014, 12:08 AM   #105
Venator
Venator's Avatar
Drives: Asphalt FR-S
Probably a stupid question..
I just got my 17x8 RPF1's installed and was wondering what the air pressure should be.. They feel like they need air but I don't know if that is because they are grippier than stock or what. Any help would be awesome!!!
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 03-08-2014, 12:15 AM   #106
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You listed what the wheels are, what are the tires on them?
Old 03-08-2014, 12:21 AM   #107
Venator
Venator's Avatar
Cheapie: Sumitomo 235/40ZR17
Old 03-08-2014, 12:21 AM   #108
Squishy86
Squishy86's Avatar
Drives: Your Car
Standard pressure is 36psi. For every day driving it works for me. For any performance related driving you're going to want to alter them accordingly.
Squishy86 is offline   Reply With Quote
Old 03-08-2014, 12:25 AM   #109
Venator
Venator's Avatar
Wow, max PSI on those tires is 51... yikes
Old 03-08-2014, 12:26 AM   #110
Venator
Venator's Avatar
So this is my first set of non-standard rims.. is 36psi (stock tire psi) ok to run on larger tires?
Old 03-08-2014, 01:29 AM   #111
Porsche
Drives: 2013 BRZ Ltd. MT
Heh.
Almost all of our tires for years have had a max pressure of 51 PSI. In fact, it's a rare tire that does not. Don't the OEM Primacy tires have a 51 PSI max?
That's not a recommended running pressure, just the max pressure without risking blowing the tire off the rim. Actually, most tires can probably safely take even more.
Subaru BRZ recommended regular pressure is 35 PSI front/rear. I don't know whether Toyota is different.
I say "regular pressure" because tire pressures are an involved issue, and one cannot say that there is only one "correct" pressure. It depends...
If you're running even bigger tires with even lower profiles, i.e. shorter sidewalls, you might want to run even higher pressures (if you can stand it) to protect your rims against dents that could cause an air leak. Today's decaying roads are a menace to our wheels.
It's worth doing some research about tires and pressures. I'll bet you'll find it interesting, and you'll learn how you can alter the handling balance for instance by changing the relative pressures a bit front to rear. I might like a little more in the front, for instance, to mitigate too much understeer.
I check my tire pressures by eye (yes, just looking at them) each time I get into my car. You'll quickly learn to spot a 5 PSI low tire with practice.
You need a tire gauge, of course.
Set your tire pressures when the tires are at ambient temperature. That means when the air inside the tire is the same temperature as the air outside the tire. When you drive your car, the air inside your tires gets hotter and expands, raising the pressures. Do not drop the pressures back to 35 PSI when your tires are hot.
For each 10 degree change in air temp, a tire will gain or lose 1 PSI pressure. In the spring and fall when temps fluctuate wildly, day to day, I may fiddle my tire pressures daily.
I could go on for pages, but I'll stop with just this little bit.
Hope this has been helpful.
Porsche is offline   Reply With Quote
Old 03-08-2014, 01:34 AM   #112
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Have fun reading:
http://www.tirerack.com/tires/tiretech/tiretech.jsp
.... or just follow OEM spec. ~35 is usually a good number.
You under- or over-inflate based on need.
-alex
17x8 +45 with 235/45/17, full lock, whatwasthatfrigginsound, wheel pop, wheel rub
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei RSM9 17x8.0 +48 AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-17-2014 06:50 AM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 04:26 PM
