Old 12-23-2014, 09:34 PM   #15
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by benlaz88 View Post
I found a local tuner that will tune my OFT. I will let you know whats the result going to be.
Yes please ...looking forward to your results.
Old 12-31-2014, 02:30 PM   #16
benlaz88
Drives: 2013 Asphalt FRS
At the local shop right now. Will post results later today
benlaz88 is offline   Reply With Quote
Old 12-31-2014, 05:10 PM   #17
benlaz88
Here are my verdict.
Mods:
Perrin 2.5 resonated, AEM intake, JDL UEL header, JDL Overpipe, and Motiv Test pipe.
Pump gas 91
Stock tune result: 154.515 WHP and 121.758LBFT torque
OFT OTS tune: 170WHP and didn't keep track on the torque
OFT Custom tune: 180.040WHP and 144.970LBFT torque
if any of you want to see the actual print out let me know. I will post it when get the pic loaded onto my computer.
The Following 2 Users Say Thank You to benlaz88 For This Useful Post:
limitedblkwrx (01-04-2015), tennisfreak (01-05-2015)
Old 12-31-2014, 05:29 PM   #18
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
nice improvement. i was thinking of trying to do the same thing and find a tuner
malubawla is offline   Reply With Quote
Old 12-31-2014, 07:01 PM   #19
benlaz88
Here are my dyno sheet.
[IMG][/IMG]
Old 12-31-2014, 07:05 PM   #20
OmarYasin
OmarYasin's Avatar
Mods:
Pump gas or ethanol?
OmarYasin is offline   Reply With Quote
Old 12-31-2014, 07:06 PM   #21
benlaz88
Pump gas 91
Old 12-31-2014, 07:29 PM   #22
NyC Zn6
NyC Zn6's Avatar
I have similar mods as you but i am running Stg 2 uel e85...hopefully its close to 200whp lol.
Old 01-03-2015, 07:43 PM   #23
benlaz88
I was expecting 190WHP with gas. According to my tuner, the only changes are the base timing b table and knock correction advance max A table.
Old 01-03-2015, 08:03 PM   #24
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Why where you expecting 190whp? The Dyno you used (Dynopack) is calibrated to read quite a bit lower than the typical Dynojet that most people use. You can by the stock baseline run of 154whp instead of the 170-175whp most usually see on a Dynojet. So I'd say going from 154whp to 180whp is a pretty big improvement. If you want to see a larger number, go to a different dyno
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
benlaz88 (01-03-2015)
Old 01-03-2015, 08:05 PM   #25
steve99
Drives: FT86
All dyno's read different so many variables.
The dynos where guys hit 190+whp with those mods on 91 and a tune generally measure a stock car at about 165 to 170 whp
so on one of those dyno's you would probably measure around 190
Shiv beat me :-)
just shows of the shelf maps are not to bad at all.
Old 01-03-2015, 08:05 PM   #26
benlaz88
Thanks for the info!! I didn't know dynapack read lower than other. Also my tuner told me you guys did a good job on the OTS .
The Following User Says Thank You to benlaz88 For This Useful Post:
Shiv@Openflash (01-03-2015)
Old 01-05-2015, 04:05 PM   #27
tennisfreak
Drives: 2018 BMW M240i
How much did your tuner charge you for the custom tune?
Old 01-05-2015, 04:52 PM   #28
benlaz88
he only charged me $300
tennisfreak (01-06-2015)
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
Local Tuning Solutions? Adeel Mid-Atlantic 1 05-20-2014 10:34 AM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
