Old 12-16-2014, 12:57 PM   #1
benlaz88
Drives: 2013 Asphalt FRS
Local OFT tuning
Has anyone here try to let your local tuner to tune your OFT tuning file? If yes , what your thought on that. I'm planning on during this in one of my local shop around town.
benlaz88 is offline   Reply With Quote
Old 12-16-2014, 01:02 PM   #2
phrosty
Feedback I got from a local tuner is that they'd be happy to do it for NA, but are nervous tuning FI without Ecutek.
The OFT tunes aren't anything special, it should give nearly all the options tuners are used to.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 12-16-2014, 01:06 PM   #3
benlaz88
Ok , I Was planning on goig to this route. Do you know how well the outcome for this? Performance wise.
Old 12-16-2014, 01:09 PM   #4
Koa
We're willing to bet the same as any other custom tune. YMMV
Old 12-16-2014, 01:10 PM   #5
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
If you plan on going with any of the FI kits we already support, just run the off the shelf map and you should be happy. You can always take it to a Dyno shop for testing for fine tuning. In that case the tuner (make sure he is competent) will only really need to tweak the primary fuel and ignition advance tables.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (12-16-2014), hmong337 (12-16-2014)
Old 12-16-2014, 01:35 PM   #6
benlaz88
Also he told me e85 was not needed for this car because of no benefit for it due to not enough combustion. Your thoughts on that?
Old 12-16-2014, 03:14 PM   #7
Shiv@Openflash
Drives: 2013 FRS
He is probably thinking that the octane enhancement effects of E85 are lost on an NA car. Compared to a turbo engine that can turn up the boost in response, gains aren't going to be as huge. But still, E85 can pick up good power on the FA20 as we've seen. Some of that comes from being able run more advance through the increased octane. But much of it comes from the higher oxygen content and the bump in volumetric efficiency from the in-cylinder cooling effects.
hmong337 (12-16-2014), steve99 (12-16-2014)
Old 12-16-2014, 08:35 PM   #8
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Which kits do you already support? Do you sell them also?
Jman1759 is offline   Reply With Quote
Old 12-16-2014, 08:40 PM   #9
Shiv@Openflash
Drives: 2013 FRS
Vortech SC, Phantom ESC, SBD turbo and our own kit which we will be releasing in January.
Old 12-16-2014, 08:51 PM   #10
jflogerzi
jflogerzi's Avatar
Any hints on the price, type of turbo, etc...
Old 12-19-2014, 01:34 AM   #11
OmarYasin
OmarYasin's Avatar
Oooo didnt know oft supported phantom esc, whats the power gains on that and e85?
OmarYasin is offline   Reply With Quote
Old 12-19-2014, 01:58 AM   #12
Shiv@Openflash
Drives: 2013 FRS
Mum is the word for now. Pricing will be conceptually similar to our current offering which is to say very reasonable
Old 12-19-2014, 02:00 AM   #13
Shiv@Openflash
Drives: 2013 FRS
I'd say that 99% of all Phantom ESC users run the OFT and our baseline maps. On E85, they can make up to 235whp. On regular pump gas 210-215whp. But with huge torque gains!
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
OmarYasin (12-19-2014)
Old 12-23-2014, 07:30 PM   #14
benlaz88
I found a local tuner that will tune my OFT. I will let you know whats the result going to be.
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 07:53 PM
Local Tuning Solutions? Adeel Mid-Atlantic 1 05-20-2014 10:34 AM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
