Old 12-21-2014, 06:51 AM   #1
Itzed
Drives: 2014 BRZ Limited
Floor Jack suggestion?
I usually do all my own work on my cars, and I've only jacked up the BRZ once so far, just to change over to winter wheels/tires. I noticed when I did it that the flange underneath where you jack it is not particularly strong, and was already bending a little. I use a standard two ton floor jack. I've heard of the hockey puck trick where you cut a groove for the flange in the hockey puck and put it on top of the jack, but does anyone know of a good floor Jack that already has that buit into it so it won't bend the underbody flange?
Itzed is offline   Reply With Quote
Old 12-21-2014, 09:40 AM   #2
DAEMANO
Time Traveller
Bought this and love it.
http://www.flyinmiata.com/index.php?...umber=35-70000
Old 12-21-2014, 10:46 AM   #3
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
This is the one I have. It's able to reach any of the jack points and my car was fairly low to the ground. It's expensive and heavy but damn if it isn't the best jack I've used.
[ame="http://www.amazon.com/Arcan-XL2T-Black-Profile-Service/dp/B007G83T16/ref=sr_1_4?s=automotive&ie=UTF8&qid=1419176738&sr= 1-4&keywords=arcan+floor+jack"]Amazon.com: Arcan XL2T Black Low Profile Steel Service Jack - 2 Ton Capacity: Automotive[/ame]
slicktop is offline   Reply With Quote
Old 12-30-2014, 11:19 AM   #4
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Another option is this one:
Harbor Freight 2 Ton, Low Profile and Long Reach
It's basically what @slicktop has. I love using it, and it can reach everything on the car, even when I was lowered substantially. This would allow you to jack up on the front at the radiator core support, and the rear differential. Both of those are better pick up points than the factory pinch welded frame rails.
Invest in a good set of jack stands and just cover them with some rags that have been folded over a couple times, and always use the appropriate pinch weld location to support the car.
This is a great thread to touch on all the correct ways of doing things for this chassis:
GrimmSpeed Guide to Safely Jacking
Travisty75 is offline   Reply With Quote
Old 01-21-2015, 11:20 PM   #5
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I bought the 1.5 ton low profile one on sale ($60) and I am frankly amazed with it. It lifted my dad's silverado without any problems. Just be sure to buy new fluid and make sure it's topped off, they tend to underfill them from the factory and that's where the bad reviews are coming from. Also DON'T TRUST A JACK. Get some jack stands if you're sticking your head under there. I'm pretty impressed with HF's $20 3 ton stands too, though their 6 ton stands are amazing for the price as well, they're often on sale for $40/pair. Not sure i'd trust the aluminum ones though...
http://www.harborfreight.com/15-ton-...ump-60569.html
http://www.harborfreight.com/3-ton-s...nds-61196.html
http://www.harborfreight.com/6-ton-s...nds-61197.html
Whatabouteggs is offline   Reply With Quote
Old 01-22-2015, 12:01 AM   #6
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
that flange is for the stock jack, NOT for a floor jack w/ flat pads. that's why it's bending.
Harbor Freight aluminum 1.5ton jack works great. We used one of those as a shop jack. Wore out in a year or so (shop use mind you), but cheap enough to just replace.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
FLOOR JACK White64Goat Other Vehicles & General Automotive Discussions 9 08-23-2014 12:12 AM
Good Floor Jack Suggestions was385 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 05-23-2014 03:56 PM
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 09:19 AM
suggestion Calidrifter Site Announcements / Questions / Issues 0 03-24-2013 07:12 PM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 01:53 AM
