Old 05-29-2014, 05:02 PM   #155
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by kbye View Post
how are the NVH levels on the front plates and rear hats? are they similar to stock?
Depends on your frame of reference and comparison point.
Raceseng with stock springs/shocks
Stock uppers with aftermarket springs/shocks
Raceseng with aftermarket springs/shocks
Stock uppers with aftermarket coilovers
Raceseng with aftermarket coilovers
Pillowball uppers with aftermarket coilovers
Aftermarket uppers with rubber mounts with aftermarket coilovers
"Similar to stock" is a hard reference to compare against if you don't have a reference point to compare with.
-alex
Old 05-29-2014, 05:36 PM   #156
kbye
kbye's Avatar
Drives: 2014 FR-S
-alex
i thought it was redundant, but by stock I meant as in stock suspension, as in everything stock.
kbye is offline   Reply With Quote
Old 06-27-2014, 11:20 AM   #157
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Does anyone know what the max negative camber is on stock suspension? I'm considering whether I should go back to OEM bolts or leave my camber bolt in when I install the plates. Thanks!
1Cor10:23 is offline   Reply With Quote
Old 06-27-2014, 02:41 PM   #158
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
From what I've read, it's recommended to get most of your negative camber from the bolts, and dial in the rest using the plates.better SAI and lower roll center.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 06-27-2014, 02:45 PM   #159
CSG Mike
CSG Mike's Avatar
Leave the bolt in, it gives you a larger adjustment range.
If you haven't bought the plates yet, we have them in stock and ready to go
1Cor10:23 (06-27-2014), Raceseng (09-26-2014)
Old 09-25-2014, 08:27 PM   #160
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Just splurged and ordered a set...will update thread when it arrives north of the border
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Old 12-22-2014, 03:37 PM   #161
1Cor10:23
1Cor10:23's Avatar
Originally Posted by Raceseng View Post
These have less stack height then the top plates that come on coil overs. Since the plate extends up into the strut tower, I was able to push the bearing housing further up into the caster/camber plate.
Do you have a measurement available for stack height? I would like to compare to stock coilovers and adjust strut height to compensate for difference so I can still hit the recommended ride height. Thanks!
Old 12-29-2014, 09:34 AM   #162
Raceseng
Raceseng's Avatar
There isn't a "measurement" for stack height because everything needs to be referenced from a common point on the chassis.
Raceseng is offline   Reply With Quote
Old 12-29-2014, 10:32 AM   #163
1Cor10:23
1Cor10:23's Avatar
Makes sense - I was referring to the image you guys have on your product page. Looks like top of perch to top of plate.
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
