#155 | |
Drives: 2005 Toyota Camry
Raceseng with stock springs/shocks Stock uppers with aftermarket springs/shocks Raceseng with aftermarket springs/shocks Stock uppers with aftermarket coilovers Raceseng with aftermarket coilovers Pillowball uppers with aftermarket coilovers Aftermarket uppers with rubber mounts with aftermarket coilovers "Similar to stock" is a hard reference to compare against if you don't have a reference point to compare with. -alex |
#156 | |
Drives: 2014 FR-S
#157 |
Drives: '13 Whiteout FR-S (M/T)
Does anyone know what the max negative camber is on stock suspension? I'm considering whether I should go back to OEM bolts or leave my camber bolt in when I install the plates. Thanks!
#158 |
Drives: for the sake of driving
From what I've read, it's recommended to get most of your negative camber from the bolts, and dial in the rest using the plates.better SAI and lower roll center.
'13 Argento FR-S
#159 | |
If you haven't bought the plates yet, we have them in stock and ready to go
#160 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Just splurged and ordered a set...will update thread when it arrives north of the border
| The Following User Says Thank You to drewbot For This Useful Post: | Raceseng (09-26-2014) |
#161 |
Do you have a measurement available for stack height? I would like to compare to stock coilovers and adjust strut height to compensate for difference so I can still hit the recommended ride height. Thanks!
#162 |
There isn't a "measurement" for stack height because everything needs to be referenced from a common point on the chassis.
#163 |
Makes sense - I was referring to the image you guys have on your product page. Looks like top of perch to top of plate.
| Tags |
| billet, billet aluminum, caster adjustment, caster camber plate, raceseng |
| Tein Flex Z Coilovers | Evasive Motorsports | Brakes, Suspension, Chassis | 54 | 07-16-2017 01:21 AM |
| Raceseng | Billet Aluminum Engine Pulleys | Raceseng | Engine, Exhaust, Transmission | 174 | 07-24-2014 12:24 AM |
| Raceseng | Lightweight Billet Aluminum Tow Hook | Raceseng | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 08-27-2013 01:48 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
| SRP Billet Aluminum Door Sills | pedalpusher | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-20-2012 06:44 PM |
