Old 12-21-2014, 09:48 PM   #15
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by ATL BRZ View Post
I have taken it to the dealership for it once. They couldn't find the source of the leak and just cleaned it up and sent me in my way after telling me to keep an eye on it.
My dealer service department added some oil dye to the oil to try to locate the source of the leak. I've put a couple thousand miles on it since, although the leak showed up almost immediately after I brought it in. I'm dropping it off tomorrow morning. I'll keep you guys posted.
I'm sure a nice bead of RTV around the boarder can only help prevent it from leaking. My car only has about 20,000 miles BTW. This leak started quite a while ago.
Old 12-22-2014, 11:18 AM   #16
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
you might try replacing the VC gaskets, and applying a bead of ultra grey RTV all the way around the gasket area to reinforce the gasket.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 12-22-2014, 12:37 PM   #17
Astroboy
Astroboy's Avatar
Drives: None
Anyone know the torque spec for reinstalling an oil pan?
Astroboy is offline   Reply With Quote
Old 12-22-2014, 02:58 PM   #18
Dnace03
Drives: 2013 Scion FRS
Roughly 10 ft pounds. Use your own judgement though.
Dnace03 is offline   Reply With Quote
The Following User Says Thank You to Dnace03 For This Useful Post:
Astroboy (12-23-2014)
Old 12-23-2014, 07:41 PM   #19
Astroboy
Astroboy's Avatar
Drives: None
Thanks a lot. Have you swapped yours?
Old 12-23-2014, 08:01 PM   #20
Astroboy
Astroboy's Avatar
Drives: None
Here's my encounter. I'm boosted btw. I am not blaming the turbo kit for this issue, just bad luck
Old 12-23-2014, 09:22 PM   #21
Dnace03
Nah man I'm a mechanic. I don't work on my own car haha. Even though I might have a head leak.... 40k on 13 frs. Completely stock. Gonna pull it into the shop tomorrow to clean off the head gasket area and drive it for a bit. See if it is leaking or not.
Old 12-24-2014, 09:42 PM   #22
solidONE
solidONE's Avatar
An update on my warranty claim. The dealer techs traced the leak to the cam chain cover seal, so it will require Subaru sealant to reseal which the scion/toyota dealer had to special order. It will also require a new crankshaft seal gasket as well. Which they did not have in stock either. Good thing the dealer service department offered a complimentary rental car for my troubles billed to Toyota.
The Following User Says Thank You to solidONE For This Useful Post:
Astroboy (12-26-2014)
Old 12-28-2014, 10:44 PM   #23
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Timing cover... long story short, under boost your internal pressure is increasing. As it increases youre blowing the seal and forcing oil out. External pcv and a reseal of timing cover and potentially maincap.... @ptuning just fixed this on my car
ybotspawn is offline   Reply With Quote
The Following User Says Thank You to ybotspawn For This Useful Post:
Astroboy (01-06-2015)
Old 12-30-2014, 02:49 AM   #24
solidONE
solidONE's Avatar
Got my ride back this past saturday. Reflashed tune, and everything is peachy keen. Will check back after 3000 miles and see if it starts to leak again.
Old 12-30-2014, 01:07 PM   #25
Astroboy
Astroboy's Avatar
Drives: None
I'm just going to sell my car ,
Any recommendations on what I should get?
Old 12-30-2014, 03:13 PM   #26
aagun
Drives: 86
use oil cooler >>
aagun is offline   Reply With Quote
Old 12-30-2014, 06:32 PM   #27
Lonewolf
Lonewolf's Avatar
Drives: Moped
Why take so much of a financial hit over a leak? Wouldn't it be cheaper just to fix the leak?
Old 12-31-2014, 11:19 PM   #28
Astroboy
Astroboy's Avatar
Drives: None
I'm in school, people I'm staying with aren't Supportive, and I simply don't have time to deal with it at the moment. Idk, I'll fix it one more time, and if something fails, bye bye frs
Oil Leak on driver side EINSTEIN562 Issues | Warranty | Recalls / TSB 3 08-09-2020 12:16 PM
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 04:43 PM
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-02-2015 11:51 PM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
