#15 | |
Drives: FR-S Whiteout
I'm sure a nice bead of RTV around the boarder can only help prevent it from leaking. My car only has about 20,000 miles BTW. This leak started quite a while ago. |
#16 |
Drives: 2013 Subaru BRZ
you might try replacing the VC gaskets, and applying a bead of ultra grey RTV all the way around the gasket area to reinforce the gasket.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
#18 |
Drives: 2013 Scion FRS
Roughly 10 ft pounds. Use your own judgement though.
| The Following User Says Thank You to Dnace03 For This Useful Post: | Astroboy (12-23-2014) |
#21 |
Nah man I'm a mechanic. I don't work on my own car haha. Even though I might have a head leak.... 40k on 13 frs. Completely stock. Gonna pull it into the shop tomorrow to clean off the head gasket area and drive it for a bit. See if it is leaking or not.
#22 |
An update on my warranty claim. The dealer techs traced the leak to the cam chain cover seal, so it will require Subaru sealant to reseal which the scion/toyota dealer had to special order. It will also require a new crankshaft seal gasket as well. Which they did not have in stock either. Good thing the dealer service department offered a complimentary rental car for my troubles billed to Toyota.
| The Following User Says Thank You to solidONE For This Useful Post: | Astroboy (12-26-2014) |
#23 | |
Drives: 13 Subaru BRZ
Timing cover... long story short, under boost your internal pressure is increasing. As it increases youre blowing the seal and forcing oil out. External pcv and a reseal of timing cover and potentially maincap.... @ptuning just fixed this on my car Last edited by ybotspawn; 12-28-2014 at 11:05 PM. |
| The Following User Says Thank You to ybotspawn For This Useful Post: | Astroboy (01-06-2015) |
#24 |
Got my ride back this past saturday. Reflashed tune, and everything is peachy keen. Will check back after 3000 miles and see if it starts to leak again.
#26 |
Drives: 86
use oil cooler >>
#27 |
Drives: Moped
#28 | |
Drives: None
| Oil Leak on driver side | EINSTEIN562 | Issues | Warranty | Recalls / TSB | 3 | 08-09-2020 12:16 PM |
| Water Leak inside passenger side floorboard | AtlasMick | Issues | Warranty | Recalls / TSB | 30 | 03-28-2019 04:43 PM |
| oil leak, drivers side, front of engine | carbonBLUE | Issues | Warranty | Recalls / TSB | 41 | 10-02-2015 11:51 PM |
| oil leak at timing cover | choi0706 | Issues | Warranty | Recalls / TSB | 8 | 09-10-2014 06:25 PM |
| Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 09:42 PM |
