#169 |
Drives: None
yeah I noticed that and I could manually change it by that much too I just didn't knowing I should go ahead and do that
#170 | |
Drives: FT86
That tune has had the maf scaling manipulated a bit i think to accommodate variations in E% from E60 to E90 so you need to be carefull if you adjust it. In Oz we have a pump E85 thats guaranteed 85% ethanol , so I have rescaled my maf scaling on E85 tune to use this particular fuel. I now run fuel trims of 1 or 2% over entire rpm range and use that brand E85 all the time. Leaned out the lower rpm/load cruise area a bit to get a bit better economy and my afr follows the OL fuel tables nicely now. But I have the consistent E85 mix to use. |
#171 |
Codename: Stitch
I have been using these cold start cranking values for a while and had very good results, at least here in the very moderate Northern California. Always starts on the first crank for me. Some of the tables in this shot I believe are unchanged from the 2.06 E85 map but I include them for completeness.
![]() these values were developed by @Malt and then further tweaked by @mkivsoopra so this is not my work, but since I have had good results with these I thought I would share.
#172 |
Drives: '13 SSM BRZ Limited 6MT
as this method doesn't use a flex fuel kit, how would we know how much ethanol is in each fill up? are we to monitor the LTFT values and adjust by adding regular gas? or do we just take it easy for a few miles as mentioned and hope the quality of the ethanol is too large a range?
EDIT: also, are there any differences from buying the OFT directly from Vishnu or from FT86speedfactory aside from earning the "OFT dollars"? Since i'm in CA, buying from FT86SpeedFactory would save me about $60 in shipping and taxes and I wouldn't plan on a header as I'd like the car to not get any louder. |
#173 | |
Drives: FT86
read shiv's post here its linked in first post of this thread. basicly the inbuilt fuel trim compensation in the ecu will adjust for variations in pump E85 content http://www.ft86club.com/forums/showthread.php?t=53477 second question don't know but pretty sure local shipping of oft from openflash by USPS is only $60 instead of courier. |
#174 |
Drives: Asphalt Scion FR-S
Switched to corn juice. Big mistake. Never going back.
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
#175 |
Also. My ST hasn't been past 5% not LT been past 3% for last 15 miles. But both peg negative values.
Am I safe yet
#176 | |
Drives: FT86
stft will vary a lot with throttle application thats normal. |
#177 |
I'm trying to figure out to post my log like you guys do but no luck thus far. I can honestly feel a difference in the butt dyno either
#178 | |
Drives: FT86
download log from ot then upload it to www.datazap.me accounts free have a read of the logging link below |
#179 |
Ah that's how you guys do that. Also I totally meant CANT feel difference in the butt dyno
#180 | |
Drives: FT86
Need to recalibrate butt dyno :-) E85 adds more power and torque throught rpm range and smooths power delivery through torque dip, so you dont feel the surge at 5000 as much. find a mate on petrol and test against that. |
#181 |
the log i pulled when i first switched over to the eb5 is a 25 mile journey, its way too long. im gonna do another one shortly thats shorter, what parameters should i be watching besides STFT LTFT and KC?
#182 | |
Drives: FT86
knock flkc and knock correction IAM afr and commanded afr |
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
