Old 12-24-2014, 05:22 PM   #169
VakaGT
VakaGT's Avatar
Drives: None
looking at the grimspeed maf scaling the oft guys put in their tunes its very close to the stock scaling so it should be ok , but check with shiv at openflash he is the expert on that tune.
the grimspeed scaling was about 4% different in the midrange area.
yeah I noticed that and I could manually change it by that much too I just didn't knowing I should go ahead and do that
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 12-24-2014, 05:51 PM   #170
steve99
Drives: FT86
Best check with shiv on what he thinks.
That tune has had the maf scaling manipulated a bit i think to accommodate variations in E% from E60 to E90 so you need to be carefull if you adjust it.
In Oz we have a pump E85 thats guaranteed 85% ethanol , so I have rescaled my maf scaling on E85 tune to use this particular fuel. I now run fuel trims of 1 or 2% over entire rpm range and use that brand E85 all the time. Leaned out the lower rpm/load cruise area a bit to get a bit better economy and my afr follows the OL fuel tables nicely now. But I have the consistent E85 mix to use.
Old 12-26-2014, 01:15 PM   #171
PMok
Codename: Stitch
PMok's Avatar
I have been using these cold start cranking values for a while and had very good results, at least here in the very moderate Northern California. Always starts on the first crank for me. Some of the tables in this shot I believe are unchanged from the 2.06 E85 map but I include them for completeness.
these values were developed by @Malt and then further tweaked by @mkivsoopra so this is not my work, but since I have had good results with these I thought I would share.
The Following 3 Users Say Thank You to PMok For This Useful Post:
gonzo (01-27-2015), mkivsoopra (12-26-2014), steve99 (12-28-2014)
Old 01-26-2015, 01:02 AM   #172
tracerit
Drives: '13 SSM BRZ Limited 6MT
as this method doesn't use a flex fuel kit, how would we know how much ethanol is in each fill up? are we to monitor the LTFT values and adjust by adding regular gas? or do we just take it easy for a few miles as mentioned and hope the quality of the ethanol is too large a range?
EDIT: also, are there any differences from buying the OFT directly from Vishnu or from FT86speedfactory aside from earning the "OFT dollars"? Since i'm in CA, buying from FT86SpeedFactory would save me about $60 in shipping and taxes and I wouldn't plan on a header as I'd like the car to not get any louder.
tracerit is offline   Reply With Quote
Old 01-26-2015, 01:15 AM   #173
steve99
Drives: FT86
read shiv's post here its linked in first post of this thread. basicly the inbuilt fuel trim compensation in the ecu will adjust for variations in pump E85 content
http://www.ft86club.com/forums/showthread.php?t=53477
second question don't know but pretty sure local shipping of oft from openflash by USPS is only $60 instead of courier.
tracerit (01-26-2015)
Old 01-27-2015, 02:42 PM   #174
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Switched to corn juice. Big mistake. Never going back.
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 01-27-2015, 02:48 PM   #175
itsjustdavep
Also. My ST hasn't been past 5% not LT been past 3% for last 15 miles. But both peg negative values.
Am I safe yet
Old 01-27-2015, 05:03 PM   #176
steve99
Drives: FT86
Am I safe yet
once your ltft is below 10% throughtout the rpm range your good to go, if you folowed proceedure in first post its very quick.
stft will vary a lot with throttle application thats normal.
Old 01-27-2015, 05:06 PM   #177
itsjustdavep
I'm trying to figure out to post my log like you guys do but no luck thus far. I can honestly feel a difference in the butt dyno either
Old 01-27-2015, 05:09 PM   #178
steve99
Drives: FT86
download log from ot then upload it to www.datazap.me accounts free have a read of the logging link below
Old 01-27-2015, 05:11 PM   #179
itsjustdavep
Ah that's how you guys do that. Also I totally meant CANT feel difference in the butt dyno
Old 01-27-2015, 05:21 PM   #180
steve99
Drives: FT86
Need to recalibrate butt dyno :-)
E85 adds more power and torque throught rpm range and smooths power delivery through torque dip, so you dont feel the surge at 5000 as much. find a mate on petrol and test against that.
Old 01-27-2015, 05:25 PM   #181
itsjustdavep
the log i pulled when i first switched over to the eb5 is a 25 mile journey, its way too long. im gonna do another one shortly thats shorter, what parameters should i be watching besides STFT LTFT and KC?
Old 01-27-2015, 05:33 PM   #182
steve99
Drives: FT86
knock flkc and knock correction IAM
afr and commanded afr
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
