#351 | |
Drives: Hydra EMS Powered FRS Raven Black
Given we do Rev to 9k rpm with our engine the oem rockers cannot be trusted and we do see the axle pins fail. We do address this as part of our engine builds but people have also had pin failures with oem, NA engines. Search posts started by "Element Tuning" and there is a thread specific to the rocker failures we've encountered. Poor manufacturing quality control is pretty much what you can chalk it up to. |
#352 |
Drives: 04.5 GLI, 01 A4 Avant, RS 1.0
First off, I really like this thread, it has a lot of good info in it.
But, I have a question for you Phil. If using an oil cooler helps but doesn't bring down your temperatures enough to ensure proper viscosity to float the crank and connecting rods, has anyone thought of the idea of using AC to cool the oil? Yes you will lose 5 or so hp when running and tax your AC system, A LOT, but I think you would get the oil away from 260F+ temperatures using AC. |
#353 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#354 |
Drives: 86 GT
I do this also, turn on AC, low rpm but keep speed up and stay off the brakes as much as possible on the cool down. Don't shut the car off until temps are the same. The coolant temps would be quite high also so the cooldown process would benefit that also.
#355 |
I've never been above about 205 water temp on track.
#356 |
Because compromise ®
Drives: Red Herring
What purpose does this serve? I've not seen this procedure before.
#357 |
Running your AC won't cool your oil just your body
![]() They make AC coolers which is what I believe has been suggested. Some are using AC based intercooler and there is some success there. The problem is that running the AC creates a ton of heat in the condenser which is then pumped onto your radiator. |
#358 | |
Drives: Toyota 86 GTS
People might run their AC on cooldown just because the fan activation temp is lower than AC off. Even then it will only come on while stationary and overheating. Better solution is just to modify the fan temps in tune so they come on when going slower than 40mph. |
#359 | |
#360 |
#361 |
Drives: Red Herring
Let me get this straight. You are heating the air blowing into the radiator to cool your engine?
#362 |
Drives: 86 GT
#363 |
Both fans kick on regardless if the ac is on when the engine reaches a certain temp anyways. Turing the ac on then heats up the condensor which it next to the rad causing the fans to draw warmer than ambient air across the rad not ideal.
#364 |
Stig's dark passenger
I thought I was being anal by turning on the heater on my cooldown lap...???...
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
