Old 12-26-2014, 10:26 AM   #351
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by Nigelr32 View Post
A little off topic, but I need to know something please.. With the uprated valve springs in place are you experiencing any excessive rocker wear. I checked my stock springs, and they are around 45lbs at fitted height and 135lbs at 11mm.
Kelford springs run at 68lbs and 166lbs respectively. This seems a big jump for those little rocker assemblies??
Love the thread Phil, great video's too!!
We are not seeing wear with the rockers (we use Ferrea in our builds FYI) but the rockers themselves can fail. I'm not going to share specifics about our engine build specs but when we do the big valve heads the install height can effect the seat pressure so you have to double check and adjust that stuff.
Given we do Rev to 9k rpm with our engine the oem rockers cannot be trusted and we do see the axle pins fail. We do address this as part of our engine builds but people have also had pin failures with oem, NA engines. Search posts started by "Element Tuning" and there is a thread specific to the rocker failures we've encountered. Poor manufacturing quality control is pretty much what you can chalk it up to.
Element Tuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
Nigelr32 (12-26-2014), sato (12-26-2014)
Old 02-19-2015, 12:06 PM   #352
Slowmotion
Drives: 04.5 GLI, 01 A4 Avant, RS 1.0
First off, I really like this thread, it has a lot of good info in it.
But, I have a question for you Phil. If using an oil cooler helps but doesn't bring down your temperatures enough to ensure proper viscosity to float the crank and connecting rods, has anyone thought of the idea of using AC to cool the oil? Yes you will lose 5 or so hp when running and tax your AC system, A LOT, but I think you would get the oil away from 260F+ temperatures using AC.
Slowmotion is offline   Reply With Quote
Old 02-19-2015, 12:13 PM   #353
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I know I run the AC on the cooldown lap and when the car is sitting after coming off track until the oil hits below ~200.
Luckrider is offline   Reply With Quote
Old 02-19-2015, 05:47 PM   #354
dave-
Drives: 86 GT
I do this also, turn on AC, low rpm but keep speed up and stay off the brakes as much as possible on the cool down. Don't shut the car off until temps are the same. The coolant temps would be quite high also so the cooldown process would benefit that also.
dave- is offline   Reply With Quote
Old 02-19-2015, 07:34 PM   #355
Luckrider
Luckrider's Avatar
I've never been above about 205 water temp on track.
Old 02-19-2015, 10:25 PM   #356
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What purpose does this serve? I've not seen this procedure before.
Old 02-19-2015, 10:31 PM   #357
Element Tuning
Running your AC won't cool your oil just your body
They make AC coolers which is what I believe has been suggested. Some are using AC based intercooler and there is some success there. The problem is that running the AC creates a ton of heat in the condenser which is then pumped onto your radiator.
Old 02-19-2015, 10:48 PM   #358
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
This makes no sense to me.
People might run their AC on cooldown just because the fan activation temp is lower than AC off. Even then it will only come on while stationary and overheating. Better solution is just to modify the fan temps in tune so they come on when going slower than 40mph.
Old 02-19-2015, 10:48 PM   #359
Koa
so how do they circumvent that paradox? would be interesting to see a working system
Old 02-19-2015, 11:08 PM   #360
Luckrider
Luckrider's Avatar
The AC running turns on the secondary fan. I read somewhere that it also blows over the oil pan incidentally.
Old 02-19-2015, 11:55 PM   #361
Captain Snooze
Drives: Red Herring
Let me get this straight. You are heating the air blowing into the radiator to cool your engine?
Old 02-20-2015, 12:05 AM   #362
dave-
Drives: 86 GT
Correct but once you park the car, the fans run with the a/c on so forces air through the radiator and oil cooler.
Old 02-20-2015, 05:33 AM   #363
Dipstik-sportech
Dipstik-sportech's Avatar
Both fans kick on regardless if the ac is on when the engine reaches a certain temp anyways. Turing the ac on then heats up the condensor which it next to the rad causing the fans to draw warmer than ambient air across the rad not ideal.
Old 02-20-2015, 07:28 AM   #364
D K
Stig's dark passenger
I thought I was being anal by turning on the heater on my cooldown lap...???...
D K is offline   Reply With Quote
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
