Old 12-19-2014, 12:20 PM   #15
Drakelee117
Drives: Subaru BRZ 2015
Originally Posted by boogle View Post
My 6th gear sychro broke too. Shifting into 6th without a perfect rev match resulted in much grinding. Even a double clutching barely made a difference.
Dealer replaced the synchro and all is well!
Only problem now is it's colder so 2nd is a bit hit & miss for a while.
How come my dealer said they are going to replace the tranny entirely? Replacing synchro seems easier? Now I have to worry is it worth it. Replacing tranny could be a lot, could it mess something else up? I mean, right now 4th gear is fine as long as I don't go past 5000, what if the operation makes car underivable with all kinds of small problems?
Drakelee117 is offline   Reply With Quote
Old 12-19-2014, 01:17 PM   #16
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
For warranty work, its much easier to just replace an entire transmission.
Its easier to order complete transmissions, its less shop time to just swap a suspect unit for a new one, and since its all on Subaru's dime the dealership doesn't really care. They just make a decent amount of money and minimize service time.
Regarding your concerns of swapping transmissions - its not a difficult job for a dealership to do. Certainly, you'll have to endure breaking in a new transmission and clutch, but if they're a remotely competent shop, they'd be hard pressed to ruin anything else while they're at it.
GotMunchies? is offline   Reply With Quote
Old 12-19-2014, 02:09 PM   #17
jdp530
Drives: 2014 BRZ
i tracked my car last weekend and ran in 3rd and 4th gears all day. Trans worked great, especially with a throttle blip when downshifting. Shifting into 3rd and powering out of the corners was a blast.
Second gear is a little notchy on my car, especially when its cold. So I take it pretty easy until it warms up.
jdp530 is offline   Reply With Quote
Old 12-19-2014, 05:15 PM   #18
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Maybe an oil switch might alleviate some of these problems?
Old 12-19-2014, 05:42 PM   #19
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Mine is at the dealer right now getting it change too i'm at 54000km, FI and I track everyweek in summer.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 12-19-2014, 06:33 PM   #20
themadscientist
Hotlink Terrorist
So all you folks are getting the trannys swapped because of ate up synchros, right?
Old 12-19-2014, 06:34 PM   #21
Pkush
I feel like I don't drive my car the way it should be driven. I've gone into 5th at 5k+ rpms maybe 2-3 times
Pkush is offline   Reply With Quote
Old 12-19-2014, 06:44 PM   #22
themadscientist
Hotlink Terrorist
Nothing wrong with that. It's your car. If the way you drive it brings you enjoyment then that's how you should drive it. I usually drive my cars like I stole them, but I know I'll have to pay the piper in the form of mechanical failures and more intensive preventative maintenance.
Old 12-19-2014, 07:51 PM   #23
chas3wba0
chas3wba0's Avatar
Drives: Yes
Mine does it too. High-RPM shifts into 4th will make a noisy card-flipping sound and also feels a bit crunchy for a second on the shifter. Not really a functional issue though, and I'm at 16k already so I'm debating on just swapping out the fluid to see if it helps...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 12-21-2014, 01:53 AM   #24
Drakelee117
With the forced induction the dealership still acknowledge the warranty and agree to change the tranny? I almost went FI a couple of weeks ago but then I had the 4th gear issue and chickened out.
Old 12-23-2014, 06:40 PM   #25
WatchmaN
WatchmaN's Avatar
Yes they did, but the advisor said that it will probably the last time lol, cause of my mods.
Old 12-24-2014, 06:45 AM   #26
boogle
Drives: White GT86
Originally Posted by carma143 View Post
You must of been pretty rough to her in the cockpit.
Nah, it went at just 2k miles and the first 1k were break-in. Since the re-build I've done another 2.5k, including some Autobahn (top of 5th into 6th) and it's been absolutely solid. Tech at the dealer reckons it was just an assembly issue.
Personally I think the tolerances are too wide. If you get one component at one end of the tolerance range, and another at the opposite end - they aren't working together. Just like the AF tolerance in some lenses and bodies causing the AF to always be out with the wrong combination.
The fluid is also clearly not great at low temps...
boogle is offline   Reply With Quote
FRS Tranny C130NAV Want-To-Buy Requests 4 10-30-2014 10:01 AM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 09:10 AM
Confirm Tranny Oil Mac1235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-31-2012 02:37 PM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 09:25 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
