Old 12-18-2014, 02:41 PM   #1
Drakelee117
Drives: Subaru BRZ 2015
New Tranny after 4500 miles :(
I started to notice the tranny was getting a bit funky a couple of days ago. It happens when I go over 5000 rpm, sometimes even higher, and shift to 4th gear, there is some kind of grinding noise. It comes and go but never at under 4000 rpm. Other gears are all fine.
I went to the dealership today, the technician said it could be the synchro but they wouldn't take it out and see. What they do is just order a new transmission and put it in whenever they get it from the factory.
Does anybody have the same problem? The car is almost new, bought 4 months ago and has done 4500 miles. Haven't been tracked, occasional spirited driving but nothing too crazy.
Drakelee117 is offline   Reply With Quote
Old 12-18-2014, 02:48 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Yes, this is a problem. It is listed in the part of the forum about recalls, TSB, issues etc. It is not a common problem, it is just an issue a small percentage of owners. I am sure it happens across all brands/makes
really sucks tho man. I hope you get a new one quickly.
Old 12-18-2014, 03:17 PM   #3
Mexorcist
Drives: 2013 Subyota GT-86 Casper
I had a similar issue in 4th only and after it warmed up and past 5k (annoying as fuck)
Dealer swapped the tranny ASAP.
Mexorcist is offline   Reply With Quote
Old 12-18-2014, 04:30 PM   #4
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
The rental car I drove had a noticeably munched 2nd gear synchro. I don't think these transmissions are all that strong. When you see pictures of stripped out gears and aftermarket companies rushing upgraded gears to market, something is up.
I'll be watching mine and if it fails I'll take the new one and then I'll take the old home and start building a beefy one in that case.
I beat the crap out of machines, though. People who drive like humans should never have to deal with transmission failures. Sorry you had to mess with something like this.
Old 12-18-2014, 05:07 PM   #5
Fastbrew
Drives: 2014 Pearl White BRZ
I am thankful I am in the crowd that didn't have an issue. After going FI, making other major mods and hammering the snot out of the thing daily - it runs smoothly - so far.
Sorry to hear it!
Fastbrew is offline   Reply With Quote
Old 12-18-2014, 05:17 PM   #6
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
I don't understand this comment. Your gears do get meshed with each other when you change gears, they are always meshed. You are just selecting a different set of gears. The grinding you hear is not the actuall gears teeth. Breaking actual gears would not be a syncro issue, and I don't think anyone with stock power is actually breaking gears.
Also, aftermarket rushes everything to market, regardless of it's usefulness or brokenness.
TheVoiceOfReason is offline   Reply With Quote
Old 12-18-2014, 05:34 PM   #7
Drakelee117
Right! Only after it warmed up! I live in South Florida and the morning here is somewhere around 60 degrees, everything is fine. But when I take my car after school or around noon when it's hot outside, it starts to grind.
Do you think I should be concerned and try not to drive my car as much since the dealership told me there is a good chance they might get the parts after holiday season?
Old 12-18-2014, 07:35 PM   #8
Dominus
Dominus's Avatar
Drives: 2013 BRZ Limited
Mine grinds into 3rd at high RPM. I think I'm going nuts cuz I swear it sounds like my horn is going off
Good luck with the new tranny
Dominus is offline   Reply With Quote
Old 12-18-2014, 10:21 PM   #9
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Does anyone know what MY this affects mostly? I have a Series.Blue and am wondering if I should be worried.
What exactly should I be looking for?
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 12-18-2014, 10:31 PM   #10
Nivaku
Drives: 2015 Blue Series
I'm in the same boat. I have a 2015 Series Blue, is it harder to shift?
Nivaku is offline   Reply With Quote
Old 12-19-2014, 04:01 AM   #11
RacerX
Drives: Subaru BRZ
I've experienced this as well. Shifting into 5th above 5k is really notchy and requires extra force and time to go in properly. All other gears slide in easy. I just trained myself to take a little extra care with that gear.
RacerX is offline   Reply With Quote
Old 12-19-2014, 07:36 AM   #12
themadscientist
Hotlink Terrorist
It wasn't the gears, it was the syncros. Upshifting under a load there was a noticeable crunchiness that was not evident in any others gear so I suggested they check that out. I bet their customers are drag racing the car and tearing up second. I would NEVER do that.
The stripped gear pics appear to be from cars that are making double the power, Rasty and those folks. They are also destroying driveshafts and twisting the muffler around the flopping bit like spaghetti.
Old 12-19-2014, 08:36 AM   #13
boogle
Drives: White GT86
My 6th gear sychro broke too. Shifting into 6th without a perfect rev match resulted in much grinding. Even a double clutching barely made a difference.
Dealer replaced the synchro and all is well!
Only problem now is it's colder so 2nd is a bit hit & miss for a while.
boogle is offline   Reply With Quote
Old 12-19-2014, 10:30 AM   #14
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
You must of been pretty rough to her in the cockpit.
carma143 is offline   Reply With Quote
FRS Tranny C130NAV Want-To-Buy Requests 4 10-30-2014 10:01 AM
2000 honda civic si 33k miles on body 3k miles with turbo kit Anthony7515 Cars for Sale/Trade 3 07-28-2014 09:10 AM
Confirm Tranny Oil Mac1235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-31-2012 02:37 PM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 09:25 PM
MT vs AT tranny... better MPG, 0-60? subatoy BRZ First-Gen (2012+) — General Topics 163 03-26-2012 06:08 PM
