Drives:
P3 gauge/wideband integration??
My question is..
Is the P3 pulling it's afr from the front O2? I'm wondering if you could use a wide range O2 in the rear location and view it on the gauge somehow. Sorry if this isn't the proper section. I just figured nobody outside the FI section will have much interest in this topic.
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#2 |
Drives: UK GT86
The P3 has 2 analogue inputs so yes you could wire a wideband to it if it has a 0-5v or similar output.
.: Stealth 86 :.
#3 | |
Super 86
Drives: Red 86 GTS
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#4 |
Drives: 2013 BRZ limited WRB
I replaced my second O2 sensor with a wideband(innovate LC-2) and wired it directly into the ECU.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
#5 |
Drives:
I'm debating if I should just do a wideband gauge on its own, or the p3 with wideband wired in.
The p3 is "neat" but I think it's a gizmo for lack of a better term.
My STX build thread
#6 |
Drives: GT 86
I'm doing a wideband on it's own with extra bung welded in before the cat.
#7 |
Drives: 128i
| The Following User Says Thank You to normancw For This Useful Post: | xDanger_208x (12-23-2014) |
#8 |
I ran the Wiring from the O2 through the firewall just behind the glovebox. Then I used the cigarette lighter behind the glovebox for my power and ground sources. Then you only have one wire you have to wire into the ECU which is also right there behind the glovebox. I'll try and find the link to the thread showing which wire to replace running into the ECU. It was a blue wire with white stripe.
| The Following User Says Thank You to kbogarto For This Useful Post: | normancw (12-27-2014) |
#9 |
Here is the picture showing where to wire in the O2 into the ECU
http://www.ft86club.com/forums/showthread.php?t=57902
| AEM Wideband Failsafe Gauge | Pitman | Forced Induction | 51 | 08-14-2016 11:06 AM |
| WTB: wideband sensor/gauge | SterlingBrz | Want-To-Buy Requests | 0 | 09-13-2014 11:54 AM |
| FA20CLUB Ultimate FR-S/BRZ Gauge Integration | FA20Club.com | Forced Induction | 401 | 11-15-2013 11:40 AM |
| FA20CLUB FR-S/BRZ Gauge Integration- Install other sensors question | mtimney | Electronics | Audio | NAV | Infotainment | 2 | 07-24-2013 03:27 PM |
| AEM Failsafe wideband gauge. | skatery1989 | Interior Parts (Incl. Lighting) | 2 | 04-14-2013 09:12 AM |
