Old 12-20-2014, 12:53 PM   #29
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Originally Posted by 200hp/tonne View Post
If you end up making money on these hundreds, could you send me a couple? The taper on the water jet cut screwed up the holes on one of my pieces (the guy stacked my 2 work pieces and made 1 cut), so my 10mm holes have to be 11mm on that one piece for everything to line up properly. I haven't done GD&T at all on this thing...
By the way, the piece is 3/4" thick.
We cut up to almost an inch for our processes, somethingg li 14 or 15\16th.
surprised about the water jet screwing up. if time allows we always run the water jet because it will yield a high quality hole but takes longer. holes cut by the plasma need to be touched up with a dye grinder.
ill pm ya and maybe we can work something out
ill be at work for a little bit later today
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
200hp/tonne (12-20-2014)
Old 12-20-2014, 10:35 PM   #30
wparsons
wparsons's Avatar
120-11782-bk costs 300$ PER CALIPER. These are essentially the same as the WRX calipers in terms of pistons, piston area and pads, and only cost 125 per piece. Brake bias seems to be a concern for a lot of us including me, but i am confident that similar rotor diameters and piston areas as the Wilwood FRS kit will provide a similar net result.
The calipers you linked to have pistons 0.5" larger in diameter than the ones AP uses (which is almost 50% larger diameter). There's simply no way the bias is going to be the same.
They also need a thinner rotor (or thinner pads), 0.8" vs 1.1".
flickr
Old 12-20-2014, 10:49 PM   #31
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
i meant the WRX kit from Wilwood, as well as the FRS kit from Wilwood.
It is almost the exact same caliper as the WRX kit from Swift996's post, only difference is radial mount vs normal mount.
I don't have data from AP racing kits.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 12-21-2014, 01:14 PM   #32
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
You could try the 120-11133
It has the same piston area w/ a larger pad for only about $20 more from Amazon. I have these(well I have a set with a larger piston size because I ordered the wrong set, fixing that after the holidays)
These are sitting on a set of DBA STI rotors. They are heavy, but they work well till I get 2 piece set worked out. Trying to use wilwood rotor has and rings.
The Following User Says Thank You to DustinS For This Useful Post:
200hp/tonne (01-19-2017)
Old 12-21-2014, 01:26 PM   #33
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
So would these work on the same bracket that op has proposed?
Canehda is offline   Reply With Quote
Old 12-21-2014, 01:28 PM   #34
DustinS
DustinS's Avatar
No. These have a smaller mounting distance (3.50 off the top of my head, compared to the 5.25 or whatever is on the OP Calipers)
These would need a new bracket, but I imagine He might be able to use the ones he has already made. I haven't checked to see the differences.
Edit: OP Caliper is 5.25" Mount center (distance between center of mounting holes) and 2.03" mount height (distance between center of mounting hole and top of pad). Calipers I am using have a Mount center of 3.50" and Mount height of 2.85"
Old 12-21-2014, 01:37 PM   #35
CSG Mike
CSG Mike's Avatar
There's more to bias than just piston area...
DustinS (12-21-2014)
Old 12-21-2014, 02:32 PM   #36
200hp/tonne
Drives: Raven Fr-S
What else affects brake bias?
On an unrelated note, I drove on my new setup to bed the pads in, so far so good...
The Following 3 Users Say Thank You to 200hp/tonne For This Useful Post:
DAEMANO (12-21-2014), DustinS (12-21-2014), finch1750 (12-21-2014)
Old 12-21-2014, 04:22 PM   #37
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I am no expert so please someone correct me if I am wrong. I took some info from the $600 BBK thread with Z32 calipers and simply replace with the Wilwood specs according to this calculator (Credit to @eikond)
Stock:
front piston size (inches) = 1.685 and 1.685 (42.8mm)
front pad cf I left at .48 (street performance example)
front rotor diameter 11.575
front pad height (I left at 1.875.. not sure how to calc this so I left it at the prefilled value)
rear piston size = 1.49999 (38.1mm)
rear rotor diameter = 11.42
rear pad cf = .48 (same as above)
rear pad height = 1.25 (left at prefilled value)
Result = Front brake bias 0.697 or 69.7% to front.
Wilwood brakes from OP:
front piston size (inches) = 1.620 and 1.620
front rotor diameter 12.190
Result = Front brake bias 0.706 or 70.6% to front.
Edit: Just to clarify this is with stock rear brakes
The Following 5 Users Say Thank You to finch1750 For This Useful Post:
200hp/tonne (12-21-2014), Canehda (12-21-2014), DAEMANO (12-21-2014), Panman (12-21-2014), SomeoneWhoIsntMe (12-22-2014)
Old 12-21-2014, 09:40 PM   #38
Racecomp Engineering
Cool project!
There is not much of a change in bias from stock.
One concern is that the rotor is thinner than stock at 20.6mm vs. 24mm. That combined with a larger rotor diameter would make me nervous at the track if rotor temps got very high.
EDIT: The rear FHI 2 pots shift bias forward. Front FHI 4 pots have no effect on bias.
- Andy
ATL BRZ (12-22-2014), DAEMANO (12-21-2014)
Old 12-21-2014, 09:49 PM   #39
200hp/tonne
Drives: Raven Fr-S
Cool project!
- Andy
Thanks, and my thoughts exactly. I will probably get better rotors for the track if i ever get to visit one, but my main aim is weight reduction and an enjoyable experience on the street.
The Following User Says Thank You to 200hp/tonne For This Useful Post:
Old 12-21-2014, 09:54 PM   #40
200hp/tonne
Drives: Raven Fr-S
it took me forever to clean out and repair my pressure bleeder ( I hate ATE Blue with a passion now) so i have not updated thread with any installation pictures. If i can find the time, i will update later tomorrow. to everyone for all the appreciation, support and even skepticism.
DAEMANO (12-21-2014), DustinS (12-22-2014), wootwoot (12-21-2014)
Old 12-22-2014, 10:10 AM   #41
200hp/tonne
Drives: Raven Fr-S
Ok so i spent all of Sunday on waiting for my bleeder to completely dry out and then bleeding the system and finishing up the install.
The Old setup about to be removed:
Rotor and caliper removed from wheel carrier. If the Rotor is too stubborn, get 2 M8 bolts and tighten them in the 2 small threaded holes on the rotor hub. It will pop out as you tighten them.
Remove Caliper hose by loosening the flare fitting on the fender wall after taking the clip off. I used the Conversion fitting from the wilwood line kit to cap it up. If you have removed the pre-requisite bolts for strut bracket and the ABS sensor wire bracket, the caliper comes off.
The rotor (with assembled Hat) goes up on the wheel hub. Now to install the Caliper.
Attach the Caliper to the bracket using M10 bolts. You will need some combination of shims/spacers to get the caliper in the right AXIAL position.
Its RADIAL position is handled by the bracket.
RADIAL:
To attach it to the Wheel carrier, use M12 bolts. I do not trust threads in Aluminum which is why i decided to have a lock nut on the other side.
As i said before, The Axial position can be adjusted by the use of shims or spacers.
AXIAL:
This is the view of the top of the driver side fitment. The bracket mounts BEHIND the wheel carrier mounts as opposed to Stock Caliper, which mounts to the front. This is because there is no space to create a strong bracket with enough thickness to resist crushing stresses at the bolt holes. The back side had Machined RECESSES on it, which is why we need a shim/spacer between the wheel carrier and the caliper mount bracket. Then we need to adjust the axial position of the caliper by adjusting the thickness of the spacer on the M10 side. My Combination is:
M12 Spacer : 1/8" Thick
M10 Spacers : 2.5mm Thick + 1/8" Thick
This brought the Rotor smack in the middle of the caliper, with pads inserted there was exactly the same air gap between pads and rotors on both sides of the rotor. YMMV
End result:
Now Remove the bracket the was on the fender inner wall and remove the abs sensor wire clip. The large oblong hole in this bracket is just a little too small for the wilwood fitting to pass through. you can file it with a round file if you have one, or you can do it my way, hammer the sucker flat. This also makes it easier to insert the fitting clip later. I forgot to snap a picture of this, sorry.
Stainless line attached and all fittings tightened.
Fitting clip inserted:
The Following 4 Users Say Thank You to 200hp/tonne For This Useful Post:
8686 (12-25-2014), DAEMANO (12-22-2014), DustinS (12-22-2014), shiro (12-22-2014)
Old 12-22-2014, 10:50 AM   #42
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Looks amazing buddy! Love the project! Looking forward to read more.
shiro is offline   Reply With Quote
Inexpensive Exhaust! Squido3J Engine, Exhaust, Transmission 26 12-29-2014 12:39 AM
Inexpensive shocks dyno'd... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 03-09-2014 06:59 PM
Inexpensive wheel to fit Sprint Kit. Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 05-30-2013 10:04 AM
Inexpensive spare wheel Captain Snooze Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-05-2012 06:36 AM
Inexpensive NA power increase; how much? rice_classic Engine, Exhaust, Transmission 4 06-18-2012 07:19 PM
