Inexpensive DIY Big Brake Kit
So i was inspired by Swift996's wrx brakes to research Wilwood brakes, and I realized i could build a similar kit at maybe a reduced price. As stated in the linked thread, I do not intend for it to be a track monster. I just want a comparatively inexpensive, featherweight setup that would work well on the street.
I began by taking measurements of the wheel carrier and the stock rotors, which gave me a template for brackets that would mount Wilwood calipers at the appropriate location for the 2 piece rotor. Some CAD: http://i.imgur.com/xEMtYmK.jpg?1 Some FEA: Applying 20000N force where caliper mounts to bracket. This corresponds to approximately 1.6g of braking decceleration, assuming 70% weight transfer to the front axle and a coefficient of friction of 1 between the road and tires. http://i.imgur.com/jgoBuqm.jpg Stress profile looks good, Al 6061 has a yeild strength of roughly 275 MPa, so we have a factor of safety of above 3, which is also great... http://i.imgur.com/z3jwklo.jpg?1 |
Wilwood forged dynalite calipers :
http://i.imgur.com/3GJyolZ.jpg |
Failed prototypes:
http://i.imgur.com/u5dtSbI.jpg These had wrong hole placements. The caliper was in such a position that the brake pads ended up 1mm outside the outer edge of the rotor. Lasercut prototypes in wood: http://i.imgur.com/k3wnZch.jpg Perfect. Revised the design a little to go back to the original shape. Final brackets would be cut on a waterjet. |
Final Product:
http://i.imgur.com/kVTIo67.jpg http://i.imgur.com/BWB7w0k.jpg I will install these on the FRS tomorrow, Should be an interesting day... |
I love projects like this!
Forgot to add prices:
Caliper : WIL-120-6811 $125 X2 = $250 Rotor Hats : WIL-170-9206 $125 X2 = $250 Rotor Discs : WIL-160-0277 $33 X2 = $66 Brake pads BP10 : WIL-150-8850K $42 Brake lines : WIL-220-9288 $60 Brackets : $100 TOTAL : $768 |
Cool project! Willing to share your design? I could probably get a bracket like yours cut up at work... Unless you're in the business of selling the bracket/making kits?? Works for me too. :thumbsup: |
I have an ESAB plasma / water jet CNC cutter at work and have been thinking about this for awhile now.
This and license plate relocation kits. Cool Project. If willing to share design I could get literally hundreds of these made next week. Because of the holidays we have a production shutdown and are only doing projects at work. |
Here is a snapshot of my design. Just replace the 8mm holes by 10mm and the 10mm holes by 12mm and you shall have a perfect part.
I am not in the business of making these brackets, not by any means. I had a shop near work make them for me, so i can get them made again for anyone who wants a pair. http://i.imgur.com/BQwSiH6.jpg |
By the way, the piece is 3/4" thick. |
subbed.
Would be interested in some brackets. |
Should be pretty quick and easy to convert and fire off a DXF to the shop. I just wish it wasnt winter around here, otherwise I'd be so much more productive with the car lol... Thanks again! |
Subbed and definitely in for a couple pair of brackets.
Stopping performance vs Std Brakes?
| All times are GMT -4. The time now is 08:09 PM. |
User Alert System provided by
