Old 12-20-2014, 09:26 AM   #15
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
on my way to install these in a bit...
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 12-20-2014, 10:15 AM   #16
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Im $570 into my front brembos. New pads, resurfaced rotors, and refreshed calipers
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-20-2014, 10:45 AM   #17
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Wow, must have got a good deal on them?
Joe-G is offline   Reply With Quote
Old 12-20-2014, 10:50 AM   #18
wootwoot
Drives: FRS
This seems to be a great upgrade in terms of weight savings but won't this disrupt the brake bias in a very negative way?
Old 12-20-2014, 10:51 AM   #19
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
if I shoot you a parasolid or step of a similar bracket, can you run that same FEA on it?
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 12-20-2014, 11:01 AM   #20
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
How are those calipers so cheap?
Jesse36m3 is offline   Reply With Quote
Old 12-20-2014, 11:08 AM   #21
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Panman View Post
Stopping performance vs Std Brakes?
That should be mostly about the pads chosen; pedal feel may change (typically does) and bias can change which is the thing to watch out for (not sure that changes stopping distance much, but if it does on its own, you'll have other things to sort out...)
Looks like a fun project. Got weights on the package?
Old 12-20-2014, 11:17 AM   #22
wootwoot
Drives: FRS
Why not use the 120-11782-bk? This is the caliper used for the FRS BBK...
The Following User Says Thank You to wootwoot For This Useful Post:
SomeoneWhoIsntMe (12-20-2014)
Old 12-20-2014, 12:12 PM   #23
wparsons
wparsons's Avatar
There's a substantial difference in piston diameter between those calipers and the ones the OP picked (1.620 vs 1.120). Given that the AP kit keeps bias very close to stock, I would imagine the calipers chosen by the OP the bias is changed quite a bit.
flickr
Old 12-20-2014, 12:16 PM   #24
SomeoneWhoIsntMe
@wparsons luckily wilwood has a large enough line of calipers that we can find a set with an appropriate piston area that fits his bracket design
Old 12-20-2014, 12:17 PM   #25
200hp/tonne
Drives: Raven Fr-S
Check out Swift996's brake kit post and his build thread. He reports significant weight savings and much improved street brake experience with essentially the same caliper and rotors.
Here is the link again
120-11782-bk costs 300$ PER CALIPER. These are essentially the same as the WRX calipers in terms of pistons, piston area and pads, and only cost 125 per piece. Brake bias seems to be a concern for a lot of us including me, but i am confident that similar rotor diameters and piston areas as the Wilwood FRS kit will provide a similar net result.
Old 12-20-2014, 12:24 PM   #26
200hp/tonne
Drives: Raven Fr-S
Sure. Send me a STEP please.
The FEA assumes a lot, plus my caliper is not radial mount, which makes the whole study simpler, as i can safely assume Caliper to be a rigid body (only for the confines of the FEA, i.e. direct force transfer from caliper to its bracket). Plus there are no bending moments as there is inherent assumption that the rotor pulls the caliper and thus loads the bracket in a plane parallel to its own.
I think i might have stopped making sense there...
All normal mount Wilwood Forged dynalites and maybe Dynalites should fit.
Old 12-20-2014, 12:29 PM   #27
200hp/tonne
Drives: Raven Fr-S
Fitting attached and ready to go...
The Following User Says Thank You to 200hp/tonne For This Useful Post:
DAEMANO (12-21-2014)
Old 12-20-2014, 12:33 PM   #28
SomeoneWhoIsntMe
Oh, well never mind then. I was going to draw up some brackets for radial mount Porsche calipers, but if the FEA wouldn't tell us much anyway, I guess there's not a lot of point. I'd probably cut them out of 4130 anyhow, which I'm SURE would be strong enough.
Inexpensive Exhaust! Squido3J Engine, Exhaust, Transmission 26 12-29-2014 12:39 AM
Inexpensive shocks dyno'd... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 03-09-2014 06:59 PM
Inexpensive wheel to fit Sprint Kit. Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 05-30-2013 10:04 AM
Inexpensive spare wheel Captain Snooze Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-05-2012 06:36 AM
Inexpensive NA power increase; how much? rice_classic Engine, Exhaust, Transmission 4 06-18-2012 07:19 PM
