Old 12-18-2014, 09:52 AM   #15
KevinTJH
Drives: Toyota GT86 RED
I had a look underneath my exhaust tips and I can't seem to find any bolts.
This is the exhaust system that I have:
http://www.garage88.com.au/index.php...oducts_id=1917
Are the tips not detachable for some exhaust systems?
Also, could someone give me an example of a good paint to use for the job? I'm thinking of painting the outside of the tips in gloss red and the inside in matte black. The tips don't get too hot so even plastidip would be able to withstand the heat?
The 2 popular brands I found are VHT and Rust-Oleum. Which would be the better choice? Also, is it also necessary to use primer prior to painting?
Thanks.
KevinTJH is offline   Reply With Quote
Old 12-20-2014, 01:14 AM   #16
KevinTJH
Bump.
Old 12-20-2014, 11:07 AM   #17
zooki
Drives: waiting on a 2021...
Just pull the whole axle back assembly off. It's only 2 bolts and 4 hangers. It's maybe a 10 minute job. You can't really go wrong with either paint. I like VHT personally.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Dream20b (12-20-2014)
Old 12-20-2014, 11:20 AM   #18
wootwoot
Drives: FRS
I have seen people use Plasti-dip with good results. Google it.
Old 12-21-2014, 07:01 AM   #19
KevinTJH
I read up on it on another forum, and apparently plasti-dip is only heat resistant up to 148 degrees C, which isn't suitable for exhaust tips.
I'll probably just go with the VHT then. Is the flameproof paint the right one to get?
http://www.ebay.com.au/itm/VHT-HIGH-...item5d4221941f
I'm looking for more of a gloss finish, but since the exhaust tips don't get as hot, would I be able to use Caliper paint instead?
http://www.ebay.com.au/itm/VHT-HIGH-...item5d3bc117bf
Does Primer need to be sprayed on before spraying the VHT paint on?
Thanks!
Old 12-21-2014, 08:40 AM   #20
FirestormFRS
How bout you just paint them and find out what works and report back in about 6 years!
FirestormFRS is offline   Reply With Quote
Old 12-21-2014, 11:26 AM   #21
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Thanks!
But many people have dipped their tips. (giggity) F*** what you read on a stat sheet. This is real life and it has worked in every case I've heard/read of.
And that's 300 degree F by the way. I can touch my exhaust tips after a run...
Old 12-21-2014, 02:20 PM   #22
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
Size:  196.2 KBName:  ImageUploadedByTapatalk1419189602.249765.jpg
Here you go. Powder coated
Liquid6 is offline   Reply With Quote
Old 12-21-2014, 06:22 PM   #23
KevinTJH
Originally Posted by Liquid6 View Post
Attachment 98736Attachment 98737
That looks amazing! Which paint exactly did you use?
Old 12-21-2014, 07:34 PM   #24
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
High heat powder coat. Idk what paint A shop did it.
Old 12-27-2014, 09:54 AM   #25
KevinTJH
Just in case some of you might be interested in knowing I went with painting the exhaust. I used a combination of VHT red caliper paint and clearcoat over it. I also painted the inside of the exhaust with BBQ heatproof blackpaint and a brush.
Old 12-27-2014, 12:02 PM   #26
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
👍looks good
WTS: JDM Exhaust tips babykwiss Canada Classifieds 7 10-02-2014 03:33 PM
WTB: JDM exhaust tips or perrin tips calvinck Canada Classifieds 0 06-01-2014 11:17 PM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 01:51 PM
FS: JDM Exhaust Tips forwallblakmail Exterior Parts (Aero, Lighting, Etc.) 6 09-05-2013 12:42 AM
WTB: DC Exhaust Tips or Other Tips Xdragonxb0i Engine, Exhaust, Bolt-Ons 2 05-10-2013 06:36 AM
