Old 12-18-2014, 04:19 PM   #2577
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Originally Posted by zERoTu View Post
let us/me know when you get an update on this please. i have always wanted to question somoene about this. my valve stays open on partial throttle too. full throttle closes, no throttle opens.
Its suppose to... its the bypass valve. If it didn't open under light/partial throttle you would always be under pressure, increasing drag hurting fuel mileage. Think about it, cruising at 75 mph, you would have 4lbs or so for no reason, creating more drag on the engine hurting fuel mileage..
-Thomas
86SPEED is offline   Reply With Quote
Old 12-18-2014, 04:50 PM   #2578
vgi
Drives: frs
[ame="https://www.youtube.com/watch?v=lI9rJoNzNVc"]How a Blow Off., Recirculating, or Diverter Dump Valve Works - YouTube[/ame]
vgi is offline   Reply With Quote
Old 12-18-2014, 08:22 PM   #2579
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
My best run so far 12.94 @ 110mph, we need to improve the 60ft and im confident that we can do a low 12. I broke an axle after that run so maybe next week ill have better numbers for you guys. C30 E85 high Boost pulley, custom tune and full bolts on. Running Mickey Thompson drag radials. Location El Paso TX very high altitude.
Taino-BRZ is offline   Reply With Quote
Old 12-18-2014, 08:41 PM   #2580
Barbas
Drives: 2013 whiteout Frs
Stuck installing supercharger oil cooler too ac. The mounts don't fit because of the skunk2 radiator. What do I do?
Barbas is offline   Reply With Quote
Old 12-18-2014, 08:44 PM   #2581
86SPEED
86SPEED's Avatar
because its too close to the plastic right?? i trimmed the plastic that was in the way on a BRZ that had aftermarket radiator.. i think i had to slide it a little to one side also.
-Thomas
Old 12-18-2014, 08:45 PM   #2582
captain_jack
captain_jack's Avatar
Contact kraftwerks as they should be made aware of this. Skunk 2 and kraftwerks are same entity different depts....
Old 12-18-2014, 08:58 PM   #2583
Barbas
So up top where the nippl are at there is no brackets right just the lines
Old 12-18-2014, 10:54 PM   #2584
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Disclaimer: I am being lazy as hell, and haven't looked myself yet.
With that out of the way, does anyone have a dyno comparing a C30 on pump gas to a C30 on E85?
Or the same comparison to a C30 with the high boost pulleys on pump gas to E85?
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Freeman is offline   Reply With Quote
Old 12-19-2014, 10:03 AM   #2585
xDanger_208x
xDanger_208x's Avatar
Drives:
How do I go about getting the cogged idlers??
Do they make a huge difference??
xDanger_208x is offline   Reply With Quote
Old 12-19-2014, 12:11 PM   #2586
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
@Barbas - shoot me an email with some pictures; cjweidl@group-a-eng.com
You can PM them here as well if that is more convenient for you. That way I can see what is going on with regards to your specific setup.
KraftWerks is offline   Reply With Quote
Old 12-19-2014, 12:12 PM   #2587
KraftWerks
KraftWerks's Avatar
@xDanger_208x - They help quiet down the drive system noise. You SHOULD already have these. If not, please PM me and I can get these going out to you.
Old 12-19-2014, 12:17 PM   #2588
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
You broke your rear axle???!! How much tq you running?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 12-19-2014, 01:53 PM   #2589
xDanger_208x
Drives:
@KraftWerks
I'm almost certain mine are smooth. The belt whine is crazy loud so if mine are cogged I'd hate/love to hear the smooth idlers.
I'll check in a bit and let you know.
Old 12-19-2014, 02:01 PM   #2590
CSG Mike
CSG Mike's Avatar
Drag radials are awesome for 60' times, but also put a lot more stress on the drivetrain. I wouldn't be surprised if a NA car also broke axles with DRs.
Lowered and track cars regularly snap axles, even NA.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
