Old 12-17-2014, 05:42 PM   #8037
fenton
Originally Posted by Robftss View Post
Attachment 98414
ETX16, simplified (no pre-fab/tape) and ~4lbs lighter than 1.5 powersonic dump, better 6mm bosses (PC680) for starter.
Attachment 98425
Recent log (Bu-Tang) quicker spool time... 0 - 4.7psi(3200 rpm) in ~500ms. Near NA slope/responds. Light wheel & software mod.
Latest install instr on website including new partial/WOT switch :frs-brz4a.pdf
http://www.phantomsuperchargers.com/...ubaru-brz.html
Thanks to Fenton & Bu-Tang for multiple visits and logs!
January looks promising
Ya I get to finally talk
I will post my review of partial boost and my thoughts on this new development for the phantom system later tonight.
Spoiler alert....its awesome!
fenton is offline   Reply With Quote
The Following 4 Users Say Thank You to fenton For This Useful Post:
DAEMANO (12-17-2014), gtfapollo (12-18-2014), Gums (12-18-2014), Sojhinn (12-17-2014)
Old 12-17-2014, 06:43 PM   #8038
WRB5titch
Drives: WRBrz
so...where do I SIGN UP!?!?!?!?!
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 12-17-2014, 06:44 PM   #8039
PantsDants
Drives: Scion FR-S A/T, Whiteout
So for those of us with the old kits, will we be able to buy the new, partial throttle switch as a standalone unit? Same question for the new battery cabling as well.
PantsDants is offline   Reply With Quote
The Following User Says Thank You to PantsDants For This Useful Post:
SloS14 (12-18-2014)
Old 12-17-2014, 07:09 PM   #8040
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Interesting. I was somewhat skeptical of the Bu-Tang log, due to the lack of throttle graph, and measurement going from 0 to full spool instead of from full vacuum to full spool, but after looking at my own logs, even at half throttle, vacuum immediately drops to ~0 psi before the ESC is ever engaged.
After examining three different runs, the instant full throttle is reached/ESC engaged, untill peak stable boost is reached, my logs all show ~.94 seconds. So 500ms is damn close to a 50% reduction in boost lag!
Help me to understand what's up. the new updates include:
1. A lighter compressor wheel (ceramic? I honestly wondered about this earlier) Is this the primary reason for the reduction in lag? Will this be available to existing users and if so, can it be self installed?
2. A new voltmeter/switch harness with 3.5mm plugs (should make instillation even easier)
3. A new 2 stage switch, which will provide partial boost at ~50 throttle. Will this be controlled through motor pulse like drag reduction? Speaking of drag reduction, has it become obsolete? As we see very little to no flow obstruction at below 50% throttle, With partial boost at above 50% throttle, there doesn't seem to be any reason to have drag reduction right?
4. A software mod. I assume this is to the control module, so if this is purely software change, will it be available to existing users, and if so, I could only imagine that it would require shipping the controller back to Rob?
5. The new batteries, so better starter battery, and the new dump pack option provides approximately the same? better? performance than the 1.5 pack? 4.7psi at 3200 rpm is on average almost exactly what I am getting on my setup with dump 2.0. With my peak being a rare 5.08psi at 2700rpm. How is the cold vs warm performance of the new dump pack? does it require the same amount of warmup for peak performance as the old?
I do not believe any new cabling will be necessary. You should be able to do what I did, which is, cap off/cover/heatshrink the two .5 dump connectors, and then zip tie them to the harness to keep them out of the way.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 12-17-2014, 07:29 PM   #8041
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
I can answer a lot of this:
1) new compressor wheel. It is lighter. I don't think this can be a self install as it needs to be balanced.
2) the new 3.5 mm jacks make it easier for rob to replace parts.
3) drag reduction: gone
Partial boost: 60% pedal full: 85% - 95%
4) I'm assuming the motor controller was updated to handle the new speeds.
5) dumps: better performance and can handle more amperage. By better I mean they warm up faster.
Starter: it's an odyssey
I got new wires.
Installed Mods:
The Following 5 Users Say Thank You to Sojhinn For This Useful Post:
Fareast auto part (12-31-2014), gtfapollo (12-18-2014), Gums (12-18-2014), PantsDants (12-17-2014), Target70 (12-18-2014)
Old 12-17-2014, 08:08 PM   #8042
PantsDants
I got new wires.
Sooo... what DOESN'T get changed out?
Old 12-17-2014, 08:10 PM   #8043
Sojhinn
Sojhinn's Avatar
The compressor housing. The controller housing. Aux charger. Motor.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (12-17-2014), Gums (12-18-2014)
Old 12-17-2014, 08:22 PM   #8044
PantsDants
@fenton, @Robftss: I realize it's still really early and this was just announced, but is there a plan in place for upgrading existing retail kits? It seems like a lot of parts to have to potentially re-buy to get to the latest and greatest. Or is the intention that this is just the next iteration of the kit and not meant as an upgrade?
Old 12-17-2014, 09:08 PM   #8045
Sojhinn
Sojhinn's Avatar
I'm sure there is an upgrade plan in place and don't forget we are in the early stages of this. No one else really has this and so there will be growing pains.
Installed Mods:
Old 12-17-2014, 09:08 PM   #8046
Sojhinn
Sojhinn's Avatar
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 12-17-2014, 09:31 PM   #8047
Urmyson
I'm still running the original dump pack. I'm assuming I can just buy new batteries and it would be similar to upgrading to the 1.5 dump pack correct? Also can I wire the new batteries without any additional hardware?
Urmyson is offline   Reply With Quote
Old 12-17-2014, 09:52 PM   #8048
Sojhinn
Sojhinn's Avatar
Sweet mother of Nikolai tesla (yes I know he helped push ac power) this is so fricking smooth.
Installed Mods:
Old 12-17-2014, 10:38 PM   #8049
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Thumbs up for partial throttle. This is exactly What this rig needs. Even a small amount of boost for this car is significant. Hope it works out.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
raven1231 (12-18-2014)
Old 12-17-2014, 10:52 PM   #8050
Sojhinn
Sojhinn's Avatar
Hmm... You would have to ask rob.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
