#43 |
Drives: 2013 Subaru BRZ Limited (WRB)
Ordered a few more things to add to the track setup. Here is the current list of parts on the car, or waiting to be installed. Decided to try a few things to minimize caliper boot failures and heat. I've also switched from ATE SuperBlue to Motul RBF600. This year, the car visited Mid America twice, Autobahn (full track), and Road America. Car feels great! We are headed to Sebring next in January, so I've ordered the TF Duct Kit, KNS Shims, and GT3 ducts to install before the track days.
Engine/Cooling Stock Brakes Carbotech XP10/XP8 StopTech Braided Lines Touge Factory Front Duct Kit KNS Titanium Brake Pad Shims Porsche GT3 Lower Air Guides GrimSpeed MC Brace Motul RBF600 Suspension/Steering/Tires Perrin Solid Steering Rack Mounts Bridgestone RE-11A Tires (215/45/17) Enkei RPF1 Wheels -1.4* Front Camber Next, I'm getting the Jackson Racing Oil Cooler. Then the BRZ is 100% done, and I'll be focusing on building my other car up to be safe on the track. Possibly considering moving to XP12 pads from the XP10's next time around. Just got another set of XP10's in, so there is some time yet. Any other advice or input on the above setup or anything that I should absolutely consider? Last edited by Apex_BRZ; 12-15-2014 at 03:52 PM. |
#44 |
I've read a handful of people moving to the KNS Titanium Brake Pad Shims, so I decided to give those a shot. However, the more I think about it...the more concerned I am.
I understand the concept of them, attempting to prevent the heat from migrating directly from the pads to the rest of the braking assembly and possibly the fluid. Fair enough. But, what about the brake pad itself? I'm using Carbotech XP10 pads. Will using the Titanium Shims trap the heat in the pad and will there be enough constant high heat to cause problems with the brake pad or greatly accelerate wear? |
#45 |
Drives: 2014 FR-S 6MT Monogram Series
I'll be doing a track event next month and I'm going to be changing my oil before the vent. I want to get 300v but since I don't have a oil cooler you recommend using 5W30? Currently have the Motul Eco-lite 0W20 in there and done 2 track events with that oil and driven total of 2000 miles.
#46 |
I haven't looked, but are the heat transfer properties of Titanium that much better, i.e. transfer less heat, than the standard ones? Most metals are pretty good at transferring heat.
That said, I expect that the heating of the pads from the rotor will probably swamp any effects from the shim. |
#47 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I wrote a little manifesto over in my build thread about why I finally decided to ditch the stock front brakes and significantly lower my long term operating costs while dramatically improving performance: http://www.ft86club.com/forums/showt...84#post1798884 |
#48 |
Your thread is exactly what prompted the question. Just looking into it a bit further, I suppose. I'm just curious how much faster the pads will wear compared to with and without those shims.
From your earlier posts after the TF Ducts, it seemed that you were really happy with the results and felt it was worth it. I'm fairly certain I'm not at your driving ability, and hey...maybe I never will be...but I'm willing to test out the ducting, air guides, and shims to see if it works for me at the moment. If not, I'll probably follow your route and go to the BBK Sprint package I've been eyeing for months. ![]() Excellent posts and reviews by the way, it's quite entertaining and I feel I've learned a lot following your posts around the forum. NO, I'm not a stalker. ![]() I feel the shims may be a step backward. What are your thoughts? |
| The Following User Says Thank You to Apex_BRZ For This Useful Post: | ATL BRZ (12-17-2014) |
#49 | |
I'd recommend running the titanium shims anyways, but possibly experimenting with different pad compounds. You will inevitably "pay more for less" in the oem pad shape when you shop for extremely high MOT endurance pads compared to a BBK pad shape. In my experience the variety in choices for race pads were too slim and the prices too high for me to justify trying out a bunch of different race pads. That said, I've heard from everyone that's used them that the Project Mu 999 and Endless MXRS, while hideously expensive, are among the best race compounds money can buy. Personally I'm running Carbotech XP12's front and rear this season.
#50 |
I'm using the Carbotech XP10 pads now, which match the operating range of the Project Mu 999 pads. What other changes to compound are there, and what are the benefits of moving to those over the XP10's? I'm guessing more intitial bite and even better modulation? Any info on how long they might last compared to XP10's, or is that too tough to call based on variables from car to car?
#51 | |
#52 | |
For example, a 200hp GTI and a 200hp FRS, while similar in both power and weight, accelerate differently, have different throttle response, have different powerbands, etc. The 999 will have more bite and modulation than the XP10. It will also, in actuality, handle more heat than the XP10 as well, and have substantially longer pad life. They also cost like 60% more. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Apex_BRZ (12-18-2014) |
#53 | |
#54 |
Drives: 86
Don't set foot on the track until you got:
Turbos Wing Painted calipers Sponsor stickers Remove all catalytic converters and mufflers Bucket seats 19x10" wheels Mad camber Body kit Vented hood Coils Lots of gauges That's pretty much it Oh and wrap the whole engine bay in reflect-a-gold |
#55 |
Drives: '23 BRZ Limited
#56 | |
However, if you're oil temps are sufficiently low with the oil cooler, there's no actual need to go with the higher weight (although you most certainly can and won't cause any harm by doing so). |
| Backup plan when stuck at the track | ayau | Tracking / Autocross / HPDE / Drifting | 39 | 07-26-2014 04:44 PM |
| Keeping track of mods, plans | zinzan | Other Vehicles & General Automotive Discussions | 20 | 03-06-2014 02:27 PM |
| When do you plan to get your BRZ? | switchlanez | BRZ First-Gen (2012+) — General Topics | 33 | 08-16-2013 01:25 PM |
| Do you plan to track your car? | gmookher | Tracking / Autocross / HPDE / Drifting | 28 | 12-13-2012 08:57 PM |
| Maintenance Plan? | ngabdala | BRZ First-Gen (2012+) — General Topics | 11 | 08-11-2012 05:39 PM |
