#15 |
It won't hurt. It becomes highly recommended with boost, but boost changes the equation.
#16 |
Drives: 2013 Subaru BRZ Limited (WRB)
Thanks Mike. I'll consider the oil cooler as my next mod. Next track day is at Mid America Motorplex on the 29th, then Road America again in mid October. I'll monitor oil temps on the 29th and go from there.
Before I do the track day, I want to change the oil. I've taken it to a dealer before and now want to start doing it myself. What brand/type of oil would you guys recommend I switch to from the OEM oil? What weight? Car is a daily driver at the moment, used for autocross and 4-7 track days per year. |
#17 |
Drives: 2016 FR-S
My philosophy on track mods is to fix issues that I've observed or are well known. The one thing that is an issue with our cars is the high oil temps (which I confirmed for myself). So, after addressing the usuals (tires, pads, brake fluid), I did the oil cooler. I went with the Perrin, but recommend Jackson Racing for its increased capacity.
I also did the OEM crash/camber bolts and highly recommend them. I did brake cooling ducts only after I experienced fade. First try the Porsche brake scoops; $25 and an easy install and will likely be enough.
#18 | |
You'll have a slight reduction in MPG with the 5W30. |
#19 | |
I bought those from my local dealer a couple months back. I plan on installing them and getting an alignment done before my next track day. I believe the idea was to just max out front camber with the bolts, getting maybe 1.5* of camber out of them. The rears have no adjustment available, right? Which Porsche brake scoops? First time I've heard of using them. |
#20 | |
Drives: 2022 BRZ Limited
it seems to be working just fine for me (about 8 track days on the same rotor with the ducting 6 of them are FId)
#21 | |
Drives: 2016 FR-S
See the Brake Cooling Thread. Here is a post in that thread about the brake scoops: http://www.ft86club.com/forums/showp...9&postcount=21 You will need to remove the dust shield or cut it to allow the air to reach the rotor.
#22 |
Definitely looking in the right direction. I'm actually at NJMP with my BRZ today posting up here.
Cooling is going to be an issue, especially the oil. JR Oil Cooler or Custom kit with a bit core. Cosworth AOS Koyo Aluminum Radiator I'm currently running Eibach Prokit springs on stock dampers. SPC Arms in rear to allow for more camber Oil/Coolant gauge we like the P3 Cars vent gauge MachV Awesome Wheels w/Continental Series 225-45-17 Takeoffs Hawk HP+ Pads w/Togue Tuning Brake Ducts Looking to do in the near future: Oil Cooler AST Coilovers Sways/Endlinks Full Exhaust w/tune I can't stress the oil cooler enough, we are seeing crazy high temps on track with the stock setup. -Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#23 |
If I go ahead and put the crash bolts in now for the extra front camber, what are the immediate concerns? I may not be able to get an alignment done for another week.
If I put it in and move it all the way to adjust the camber, what else does it affect? Is the alignment purely to verify that camber is equal each side, since nothing else is changing? |
#24 | |
What you're doing is checking for toe. You'll want to make sure the toe setting is zero. |
#25 |
Ah, so it affects the toe adjustment as well. I understand toe in/out has a big affect on tire wear. Maybe I'll wait...
#26 | |
#27 | |
What would you recommend I do to try and minimize the affects on Toe adjustment while installing these bolts? From what I've read, it doesn't seem like there is anything I can do as Toe is a separate adjustment. |
#28 | |
| The Following User Says Thank You to CSG David For This Useful Post: | Apex_BRZ (08-15-2014) |
| Backup plan when stuck at the track | ayau | Tracking / Autocross / HPDE / Drifting | 39 | 07-26-2014 04:44 PM |
| Keeping track of mods, plans | zinzan | Other Vehicles & General Automotive Discussions | 20 | 03-06-2014 02:27 PM |
| When do you plan to get your BRZ? | switchlanez | BRZ First-Gen (2012+) — General Topics | 33 | 08-16-2013 01:25 PM |
| Do you plan to track your car? | gmookher | Tracking / Autocross / HPDE / Drifting | 28 | 12-13-2012 08:57 PM |
| Maintenance Plan? | ngabdala | BRZ First-Gen (2012+) — General Topics | 11 | 08-11-2012 05:39 PM |
