Old 12-15-2014, 10:07 PM   #1
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Intermittent Over Heating
A few weeks ago I noticed my water temp was running near 225 while cruising along on the interstate on a cool night. Temp fluctuated between 220 & 230 for about 15 minutes then suddenly dropped to the normal 190. No issues until this weekend when I noticed the temp was 225 as I pulled into the driveway on a fairly cold night. Additionally there was no warm air coming out the vents even though the knob was on max hot. Drove to work this morning in 45 degree weather and temps were again in the 220's and no hot air from the vents. However on the drive home, the temp was back at the usual 190 and the vents were providing hot air as expected.
I assume the thermostat is sticking and needs to be replaced but I have no idea how this affects the ventilation system ??
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-15-2014, 10:12 PM   #2
Dipstik-sportech
Dipstik-sportech's Avatar
Check the coolant level, sounds like you have an air pocket in the system causing it to spike hot and stop the heater core from functioning.
Old 12-15-2014, 11:07 PM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Your Robispec-Cooler is probably leaking coolant
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Ultramaroon (12-15-2014)
Old 12-16-2014, 12:47 AM   #4
Fastbrew
Drives: 2014 Pearl White BRZ
Have you replaced your coolant with something other than the factory blue supercoolant?
PS: It should be at the very bottom of the range in the reservoir just as it ships from the factory. Did you overfill?
Fastbrew is offline   Reply With Quote
Old 12-16-2014, 02:20 AM   #5
Dipstik-sportech
Originally Posted by JDKane527 View Post
Or your Robispec-Cooler is leaking coolant
Which would cause a low coolant level causing an air pocket........
Old 12-16-2014, 09:04 AM   #6
Deep Six
Deep Six's Avatar
No leaks, coolant in the reservoir is mid way between the marks. My logic is when the thermostat is closed obviously no coolant is sent to the radiator but I'm not sure if that would also cut off circulation to the heater core as well. When it did start working, it was like a switch was thrown and the temp plummeted back to normal. Seems like an air pocket stuck in the system would be a more persistent issue?
[SIGPIC][/SIGPIC]
Old 12-16-2014, 09:22 AM   #7
Dipstik-sportech
It all depends. Crack the bleed screw on the heater hose and see if it's straight coolant.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Deep Six (12-16-2014)
Project Mu 800HC+noise issue after heating up during DD jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-02-2014 02:36 PM
Canadian Intermittent RPM dip? VirUzxZ CANADA 23 06-24-2014 02:16 PM
Acceleration Lag - Intermittent donnyk CANADA 6 07-17-2013 11:53 PM
Anyone getting an intermittent isopropyl odor? FRiSson Issues | Warranty | Recalls / TSB 10 04-29-2013 11:07 AM
Electronic Heating and AC control in FRS cagster Cosmetic Modification (Interior/Exterior/Lighting) 5 04-08-2013 09:09 AM
