Old 12-12-2014, 10:51 PM   #2521
MidnightRunner
MidnightRunner's Avatar
Originally Posted by xDanger_208x View Post
I think you could. There's quite a bit of room over there.
Awesome. I want super short lines on my cooler. Thanks
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 12-13-2014, 02:07 AM   #2522
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
A friend did a video for me and the run..
[ame]http://youtu.be/A4uPtvBhdgY[/ame]
Gixxersixxerman is offline   Reply With Quote
Old 12-13-2014, 02:07 AM   #2523
Gixxersixxerman
Old 12-13-2014, 10:49 AM   #2524
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Does this kit delete/modify whatever the car was using for a oil temp sensor? I Can no longer see oil temp from my OBD2 bluetooth connector.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 12-13-2014, 12:02 PM   #2525
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Not on mine... Are you using custom PID'S? Assuming your using torque, try an update and use the built in temp settings in torque.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 12-13-2014, 12:31 PM   #2526
BRZZZZZZZZZZ
Car Nut
PIDs? How do you force update torque?
Old 12-13-2014, 03:31 PM   #2527
BRZZZZZZZZZZ
Car Nut
NVM did some research and it is now working!
Old 12-13-2014, 03:31 PM   #2528
myd_lyf_crysys
myd_lyf_crysys's Avatar
Drives: 2013 Asphalt FR-S
Need a replacement belt, and would like to get a spare as well... Should I the sales or support email address?
Less than 2000 miles on the belt. Is that normal?
myd_lyf_crysys is offline   Reply With Quote
Old 12-13-2014, 05:12 PM   #2529
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
It's not. Contact CJ or you can call the Kraftwerks sales line.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
myd_lyf_crysys (12-14-2014)
Old 12-13-2014, 05:21 PM   #2530
zoth
zoth's Avatar
Wow that's to soon for the belt. 9,000 plus miles SC'ed and going strong. I relate a very un-tolerable loud whine with the belt being to tight.
The Following 2 Users Say Thank You to zoth For This Useful Post:
Freeman (12-13-2014), myd_lyf_crysys (12-14-2014)
Old 12-13-2014, 08:41 PM   #2531
captain_jack
captain_jack's Avatar
Hey question for you guys, at what psi does the diverter valve close? I'm told at 3psi but not sure.just curious...
Old 12-14-2014, 08:38 AM   #2532
xDanger_208x
xDanger_208x's Avatar
Drives:
I followed the instructions suggestion of keeping the tensioner bolt away from the plate 21mm, but I'm now realizing that is probably for the smaller c30.
I can wiggle my belt up and down approx. 1/2 inch.
Is that ideal, or should I go a bit tighter? @KraftWerks @moto-mike
xDanger_208x is offline   Reply With Quote
The Following User Says Thank You to xDanger_208x For This Useful Post:
Old 12-14-2014, 10:45 AM   #2533
John92
Drives: White scion frs
@xDanger_208x this is where you want to have it. The belt should not be as tight as your serpentine belt. If it moves half an inch this is where you want it. I had asked the same question to @moto-mike when I had belt dust all over my engine bay.
John92 is offline   Reply With Quote
The Following User Says Thank You to John92 For This Useful Post:
Old 12-14-2014, 10:49 AM   #2534
xDanger_208x
Drives:
I snugged it up a bit. The .5" I was getting wasn't stretching or stressing the belt at all. That was the amount it could move freely.
Also, that was the measurement in and out from where it rested. So in reality I had an easy 1" of loose movement.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
