#15 | |
Drives: RX-7 / BRZ
Look forward!
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#16 | |
The other was also tuned by someone of questionable skills, on basically US 91. These two cases represent the worse case scenarios. Surely someone decent at tuning (neither of the above) and has common sense (again, neither of the above) to tune with E85 would do a much better job, especially when it appears he'll be doing it systematically?
| The Following User Says Thank You to s2d4 For This Useful Post: | Xero-Limit (12-04-2014) |
#17 | |
although it comes in 12mpg
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#18 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Today is the big day. I had to run out of town, and the guys were able to finish up the hardware portion so I can come back in tonight and get the base tune in. We started with our base 210 tune, and then obviously turned down the cam timing and ignition timing. To err on the safe side, ethanol was added to get about a 60% mixture. We're running the Deatschwerks 700cc injectors and the DW65c fuel pump with our flex fuel kit.
Starting it up we had some misfire issues on #2 (this car has had it) and after some hard revving we cleared up and went for a drive. Initial impressions: The Sprintex base (210) kit makes the car act like a strong v6. This kit? Strong v8. Having tuned just about every variant of this car, I'm incredibly pleased with the power and response. With the winter tires on the car 1st-3rd is a spin fest at WOT. 4th was loose, at 4,500 RPM. Yup, that potent. It isn't just the tires though, it has a ton of pull before it breaks them loose. But we all know a big blower makes big power. More importantly, we're doing this with timing in the teens, on E60, and very rich AFRs. That means we're at a good baseline with plenty to go. I know most everyone wants to know if this kit will work on pump gas vs e60. I think it will work as well as any other kit. I'd guess we're 12-14 psi or so, but that's 12-14 psi starting at 2500 rpm. Estimated since we don't have a boost source hooked up yet. We'll run down some of the ethanol gradually and watch the knock counts as we dilute it out. Tuning will be 100% the determining factor here IMO, but we've done tons of 14+ psi systems and I don't see any issue with this kit doing it vs another. We'll keep updating as we rack up the miles and get more findings. The car sees about 18k/year and we even put snows on it so it can remain the DD. Until then enjoy the media and the glorious sounds from our shorty intake! [ame="https://www.youtube.com/watch?v=7GY-X11e_nM"]https://www.youtube.com/watch?v=7GY-X11e_nM[/ame] ![]()
| The Following 15 Users Say Thank You to Xero-Limit For This Useful Post: | Chad86 (02-06-2015), Coheed (04-04-2015), Draco_PR23 (12-12-2014), Dream20b (02-21-2016), JonAvalon (12-12-2014), Lawnik (12-12-2014), raven1231 (12-15-2014), rusty959 (12-12-2014), s2d4 (12-14-2014), Stark Performance (12-12-2014), tahdizzle (12-12-2014), Toyota86.ir (03-08-2016), VroomVroom86 (12-12-2014), woode (12-12-2014), wrxgoose (01-17-2015) |
#19 |
Boosted Member
Drives: 2013 Subaru BRZ
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#20 |
Drives: 2013 Firestorm FRS
hell yes!
#21 |
Drives: 2014 FR-S
Glorious sound from intake is indeed glorious.
#22 |
Drives: Flat grey Toyota 86
Awesome news developing here, I like it. Please keep up the good work.
#23 |
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
I'm liking the torque claims, when can we expect to start seeing some graphs of the new unit? PD blowers tend to have lower peak numbers so it'll be hard to steal the limelight from turbos and centris. I'm curious to see how this progresses.
#24 | |
For our car, it pulls plenty strong up top. I'd have to be in 4th or 5th to be able to redline it currently with any sort of traction in the winter, which just ain't happening on public roads ![]() I'm much more interested in seeing how much timing we can run on both e85 and pump. That will have a much more important figure in the commercial viability of the kit and how many Sprintex sends our way on the next boat. |
#25 |
Senior Addict
Drives: 86 GT
I'm liking the sticker on that intake pipe. Does it only come supplied with the 335 kits?
#28 | |
We can get it, but you'd have to pay and wait a couple of months until the parts ship from down under. |
| Tags |
| 500whp or bust, sprintex, sprintex 335 |
| The new sprintex 335 supercharger | jet86 | Forced Induction | 39 | 11-01-2014 11:27 AM |
| Innovate/sprintex SC | rudysaliby | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-28-2014 03:14 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 24 | 04-04-2014 02:38 PM |
| Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 5 | 03-05-2014 07:26 AM |
| TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing | TyperRspec789 | Forced Induction | 63 | 12-31-2013 07:39 PM |
