Old 12-11-2014, 01:18 PM   #29
steve99
Drives: FT86
Originally Posted by calmtigers View Post
Are there any tutorials on how to do this?
For romraider usage see www.romraider.com
make sure you use the definitions that come with the V2 tunes for editing V2 oft tunes do not use the V1x definitions.
for logging ect
see links below.
calmtigers (12-11-2014)
Old 12-11-2014, 02:28 PM   #30
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by 200hp/tonne View Post
Are there any plans on a stage 2 version of this?
I just pulled the trigger on a OFH so i will be moving to stage 2 in a few days...
Once we get our hands on a local car with a Grimmspeed intake and OFH, we will certainly create a Stage 2 map. We would have done it on our shop car already but it is now equipped a with a turbo
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
JonAvalon (12-11-2014)
Old 12-11-2014, 02:47 PM   #31
Cop
Cop's Avatar
Drives: 2013 FRS
for logging ect
see links below.
Seems intimidating...not sure I have the requisite knowledge not to blow my car up
Cop is offline   Reply With Quote
Old 12-11-2014, 02:48 PM   #32
Koa
Take your best whack at it, then send to Shiv or Steve for feedback/proofing?
Old 12-11-2014, 02:56 PM   #33
phrosty
It's really not difficult, but better safe than sorry if you're unsure.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Strife26 (11-17-2016)
Old 12-11-2014, 03:40 PM   #34
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Copy the grimspeed maf scale from the stg1 to stg 2 tune.
check your open loop afr follows OL fuel table and for any knock.
I was expecting this answer.
I understand tuning, I just have never played with romraider. I guess i will learn when i buy the intake, if there hasn't been stage 2 published for it by spring....
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 12-11-2014, 03:49 PM   #35
Malt
Drives: 2015 WRX
I emailed Shiv about this very topic and he stated that the differences between the St1 and grimmspeed St1 maps were minor differences in MAF scaling as well as some primary fueling changes. The changes look minimal on both tables. Not sure that simply copying the MAF scale from the grimmspeed map over to the St2 maps will work perfectly as the St2 and St1 maps are already fairly different in regards to the MAF scale.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
200hp/tonne (12-11-2014)
Old 12-11-2014, 06:59 PM   #36
steve99
Drives: FT86
Agree +1
but should be better than doing nothing at all, it will lean out top end as grimspeed maf scale top end is different to the current maf scale , hence the statement to check for afr and knock. If you get knock highr rpm blend in the top Third of the maf scale.
if shiv does a dyntune that going to be much better
Old 12-11-2014, 07:16 PM   #37
Shiv@Openflash
Drives: 2013 FRS
That is correct. MAF scaling for the Stage 1 and Stage 2 maps are different. So copying over the MAF scaling for Grimmspeed Stage 1 to an OTS Stage 2 will probably not get you want you want
Old 12-11-2014, 08:08 PM   #38
j_Zer0
Drives: Asphalt FRS 2014
So happy to hear this! Somebody get Shiv an OFH'd 86 w/ the GS intake!
j_Zer0 is offline   Reply With Quote
Old 12-12-2014, 10:33 AM   #39
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Shiv let me know if you have our intake, otherwise shoot me an email (Chase@GrimmSpeed.com) and I'll send one right over. You know we love using OFT, and we really appreciate what you're doing and all the help you're giving the FT86 community.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 4 Users Say Thank You to GrimmSpeed For This Useful Post:
MysteryMachine (06-10-2015), Strife26 (11-17-2016), Turdinator (12-14-2014), Weasel Soup (01-04-2015)
Old 12-12-2014, 11:21 AM   #40
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
With Shiv's stg 1 GrimmSpeed tune and a JDL UEL tune I picked up I have created FRANKENTUNE. So far no villagers have been harmed.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 12-12-2014, 11:37 AM   #41
phrosty
If you don't mind elaborating, I'm curious -- now that the OL fueling table isn't all whacked out, what prevents a MAF scaling from being transferable between the two?
Old 12-12-2014, 11:57 AM   #42
steve99
Drives: FT86
just watch your high rpm afr and knock as the stage two tunes have higher scale above about 3v compared to the stage 1 tunes
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 10:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 07:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 02:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 10:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 12:19 PM
