Old 12-11-2014, 08:59 AM   #2493
xDanger_208x
xDanger_208x's Avatar
Drives:
Maybe it's a filter... I'm not sure.
Any clue where this goes?
xDanger_208x is offline   Reply With Quote
Old 12-11-2014, 09:29 AM   #2494
10Stars
Drives: 14 Subaru BRZ Limited WRB
Originally Posted by post_break View Post
Kind of boring but you can at least hear it.
Been a subscriber for a while now.
Car sounds really good.
10Stars is offline   Reply With Quote
Old 12-11-2014, 10:00 AM   #2495
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
If it is a check valve, it will be between the PCV valve and the crankcase with the flow from PCV to crankcase.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 12-11-2014, 10:23 AM   #2496
xDanger_208x
Drives:
I have no clue what it's for. The instructions don't even mention it.
Old 12-11-2014, 11:22 AM   #2497
bagman
isn't that to extend the crank case vent hose to in front of the sc
bagman is offline   Reply With Quote
Old 12-11-2014, 11:31 AM   #2498
xDanger_208x
Drives:
There's a standard barb fitting include for that I believe
Old 12-11-2014, 11:35 AM   #2499
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Borla header, berk HFC, invidia Q300 exhaust.
post_break is offline   Reply With Quote
Old 12-11-2014, 01:30 PM   #2500
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
The check valve is included to use if you see fit. We have yet to see an actual need for this but the demand and requests were there for the added piece of mind so we wanted to just included it with the kits.
This goes in the hose that connects from the manifold to the block. It stops air pressure from going into the block as it only goes one way. There is technically a check valve already in place from the Factory but again, the demand and requests were there so we wanted to make sure we had it included.
KraftWerks is offline   Reply With Quote
Old 12-11-2014, 01:45 PM   #2501
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Is the flutter under decel normal or should I be worried?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 12-11-2014, 02:42 PM   #2502
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Its normal... i have mine vented into the atmosphere so its really noticeable. i ran a 1" hose from the bypass valve to under the car so its loud outside but not as noticeable under the hood like a previous customer, riding down the road you would constantly hear the venting, so i added the hose
-Thomas
86SPEED is offline   Reply With Quote
Old 12-11-2014, 03:36 PM   #2503
BRZZZZZZZZZZ
Car Nut
-Thomas
Thanks, noise doesn't bother me I just don't want to cause damage.
Old 12-11-2014, 07:30 PM   #2504
xDanger_208x
Drives:
Just about finished with the install!!!
I've put a lot of time and effort into making everything look as clean as possible. All couplers, clamps, vacuum lines etc. are tucked away, and all of the hose clamps are rotated to expose the smooth side while still being accessible to tighten/loosen.
I also mounted the oil reservoir where the windshield washer bottle would normally be. I took my time and mocked it all up to insure everything cleared. Checking the oil level is still relatively easy. All I have to do is unplug the headlight bulb harness from the headlight and I have full access to the filler cap. I'll have to use a long funnel to refill for maintenance in 2 years, but I'll manage.
This allows the lines to be very short and makes for an extremely clean looking install.
Once the front end is re-assembled the only part of the oiling system you'll see is the filter... but you really have to look for it.
Well worth the extra time and effort.
Now I'm just waiting on my base tune from @moto-mike so I can prime the oil system and take her out for a drive!
Old 12-11-2014, 07:41 PM   #2505
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
This looks realllly nice! I can definitely see the extra effort you put into it, cause mine doesn't look nearly that clean haha.
Mike is a great tuner and he'll have your car running like it's supposed to in no time!
Congrats man!
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 12-11-2014, 11:42 PM   #2506
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Finally got to the dyno today, 417hp 312 lbft
[ame]http://youtu.be/TdpUiBichik[/ame]
Gixxersixxerman is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
