Old 12-10-2014, 03:13 PM   #869
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by totopo View Post
I vaguely recall interviews about it back when it was JGTC and allowed both FMR and MR. IIRC being MR had a weight penalty associated with it, so all the top cars were FMR, but i'm not sure how much the weight penalty it was. Was it so they were heavier than the FMR cars because they didn't like honda? or just to make the weights equal?
I wish real professional engineers shared their mathematical models and would answer these types of questions.
? There is not much to model. MR moves the center of gravity back for more grip at the rear and decreases the polar moment so the tires have to do less work. I'm pretty sure a race prepped MR2 will outperform a race prepped Miata. Like the F1 cars you mentioned, race cars will often have a huge rear bias.
I'm pretty sure FMR is not inherently heavier than MR, at least with the torque tube setups you find on the higher performance cars. The torque tube only barely adds any mass. Having the engine at the front makes cooling a bit simpler.
The reason why FMR is popular is because the low polar moment of a MR car can bite you in the ass in the form of snap oversteer. A rear engined car like the 911 will also rotate easily because the light front end can change direction much faster than the rear. MR2s and 911s alike are known for losing control easily when pushed past the limit.
The Following User Says Thank You to serialk11r For This Useful Post:
strat61caster (12-10-2014)
Old 12-10-2014, 03:26 PM   #870
totopo
Drives: 370z
what if you made the mr2 and miata have the same weight and same engine and same tires?
why would an MR car have a lower polar moment? a 50/50 transaxle has much lower polar moment compared to the CG. But that's some imaginary CG, not how the car actually turns in most instances. If a car is over-rotating, like at corner entry, it is actually probably rotating more over its front wheels. So an MR car will have MUCH higher polar moment, and that is exactly why they have a tendancy of snap oversteer in corner entry.
i recall hearing an interview with a JGTC engineer saying that actually slight front bias is better for a race car, mostly because on track, when you let go of the brakes, you get on the gas almost immediately. He said basically you want close to 50/50 balance for the driver when you are mid corner, and to do this you actually need slight front weight bias since the driver is on the gas mid corner.
It kind of makes intuitive sense to me too, because to be fast you want to be at the traction circle on all your tires. in a RWD car, if you have extra traction on your front at corner exit, it does nothing for you.
FMR definitely has more weight by packaging.
totopo is offline   Reply With Quote
Old 12-10-2014, 04:00 PM   #871
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
You sure that was JGTC and not Nissan? Because I remember Nissan making this argument about the 350z when it came out... Toyota also tried to spew the same thing about the FRS/BRZ/86, and they say that's why they made it front-biased instead of 50/50.... but, in reality, we all know the reason they did this is the same reason they gave it a quite long wheelbase... the car was made for drifting. They wanted the driver to have more time to control a slide. It doesn't necessarily handle better for racing. It handles better for drifting.
I'll always be on the rear-mid being superior for grip driving side of this argument. There's a reason F1 is the way it is.
Sideways&Smiling is offline   Reply With Quote
Old 12-10-2014, 04:10 PM   #872
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Here was my textbook, might be able to find a pdf from a less than reputable source:
[ame="http://www.amazon.com/Engineering-Applications-Dynamics-Dean-Karnopp/dp/0470112662/ref=sr_1_2?ie=UTF8&qid=1418245441&sr=8-2&keywords=vehicle+dynamics+karnopp"]Engineering Applications of Dynamics: Dean C. Karnopp, Donald L. Margolis: 9780470112663: Amazon.com: Books[/ame]
Yes a true mid-engined layout reduces the vehicles moment of inertia vs. engine up front transaxle in back, think about rotating a long rod around the center vs. a short rod, the short rod will spin faster with the same applied force, quicker response, quicker handling.
Most pure race cars (open wheel, open ruleset: F1, Indy, Karts, Sprint cars) and super cars have rear bias, with a pendulum effect you can get quick rotation, also covered in the book linked above. Front engined is preferred for many other reasons, but pure speed is not one of them, the 911 has been so incredibly successful for a reason.
Ultramaroon (12-10-2014)
Old 12-10-2014, 05:28 PM   #873
Here was my textbook,...
Only one?
[ame="http://www.amazon.com/Engineering-Mechanics-Dynamics-4th-v/dp/0133569160/ref=sr_1_102?s=books&ie=UTF8&qid=1418250665&sr=1-102&keywords=engineering+dynamics"]http://amzn.com/013356916[/ame]
http://amzn.com/0137099819
The problem is none of this stuff is accessible to the casual reader. There's still quite a bit that can be demonstrated and understood intuitively without doing the math. Even just thought experiments with mentally assembling sticks and bricks can help.
Old 12-10-2014, 05:51 PM   #874
strat61caster
Only one?
The problem is none of this stuff is accessible to the casual reader. There's still quite a bit that can be demonstrated and understood intuitively without doing the math. Even just thought experiments with mentally assembling sticks and bricks.
For a ten week class with 3 prerequisite classes (and a dozen prerequisites for those), yes only one textbook
Guy asked for engineering formulas and equations, I delivered where I would get mine. It's not like the book is solely proofs, there is enough background and thought experiments to guide the casual reader, a solid knowledge of algebra should be able to get you through most engineering textbooks as you skip over the calculus and more obtuse dynamics principles.
Old 12-10-2014, 05:55 PM   #875
serialk11r
The NB Miata and MR2 Spyder are very close specs wise. Miata weighs a little more and has a smidge more power I think. Tires is easy to make equal, they have the same wheel sizes. This isn't a discussion, the cars are similar, and the MR2 has more grip if you optimize the suspension because the weight distribution is more favorable. In fact it has more grip stock despite a pretty bad suspension setup that's not adjustable.
The polar moment is lower because the mass is concentrated near the center of gravity. Polar moment is a scalar quantity, center of gravity is a point in space, there's no "compared to" lol. Someone needs to go back to high school physics :P
Snap oversteer happens because the center of gravity is far back and so if the rear breaks loose it'll slide around quickly for the exact same reason an FF car tends to understeer.
The Following 3 Users Say Thank You to serialk11r For This Useful Post:
strat61caster (12-10-2014), totopo (12-10-2014), Ultramaroon (12-10-2014)
Old 12-10-2014, 05:58 PM   #876
I kid! I misinterpreted your response and proceeded to agree with it
I just think his question was misguided altogether.
Old 12-10-2014, 06:26 PM   #877
totopo
Drives: 370z
ops, thanks, brainfart
Old 12-11-2014, 03:16 AM   #878
Noble713
Noble713's Avatar
Drives: MkIV Supra & Evo X
Vengeance Racing 660rwhp with minor mods, 48hrs after delivery of their Z06:
http://www.corvetteforum.com/article...60-hp-new-z06/
It's a shame GM as a corporate conglomerate is such a bureaucratic and inept mess, because they've clearly got some very competent automotive engineers.
1994 Toyota MkIV Supra (project car)
2007 JDM Mitsubishi Exo X GSR-SST (Daily driver)
Noble713 is offline   Reply With Quote
Old 12-11-2014, 02:50 PM   #879
dcreason86
Drives: 2012 Asphalt FR-S
Originally Posted by jsimon7777 View Post
Gods do I hate Jonny Lieberman. That guy writes like me at 16 at acts like Lincoln at Disneyland.
Thought I was the only one. Annoying as hell! They should have Lagos do all his segments.
2012 Asphalt FR-S, Bought 10/6/13
Current Mods: 6k HID, Seibon CF hood, G37 antenna, Perrin pulley, Perrin catback, Enkei RPF1
dcreason86 is offline   Reply With Quote
Old 12-11-2014, 03:26 PM   #880
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Well, he acts 1000 times better than he writes. When he wrote for Autoblog, I wrote them a letter of complaint. When he left for Motor Trend, I figured he'd fit right in with the rest of their bad writers. He actually got a bit better once he went under their editing: from excretory to just plain awful.
Old 12-11-2014, 11:39 PM   #881
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
I like the shape.
I liked it the first time I saw it, when it was a Ferrari.
Old 12-25-2014, 02:18 AM   #882
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
Originally Posted by DarkSunrise View Post
Just saw this video yesterday. Phenomenal car! I don't particularly like the way the C7 looks, but the performance of the C7 Z06 (w/s3 aero package) in Randy Pobst's hands is incredible, especially considering it's a stock street car. The 1:30 laptime at RA matches the Evasive FR-S, which was on better tires and purpose built for the track. Very impressive.
The evasive FR-S also has 200whp less than C7 Z06 lol, so it kind of lessons the impact of the Z06's time. Plus it's apple vs. oranges comparing a race car to road spec track car
But either way is damn impressive that for ~100k, you can have a car that literally nothing short of a P1, Laferrari, 918 or dedicated race car can outrun you on track
...... Except a 25k build LS1/2 powered Miata enging swap
_____________________
You know what they say... pick two: cheap, fast, reliable.
Joakim3 is offline   Reply With Quote
2014 Chevrolet Camaro Z/28: The Trans-Am Racer Returns! JPxM0Dz Other Vehicles & General Automotive Discussions 53 02-24-2016 10:55 AM
OEM Chevrolet Corvette 17x9.5 +56 BII302 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 06-07-2014 01:52 AM
Marc08EX Detailed: 2007 Chevrolet Corvette Z06 - Black Marc08EX Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 07-11-2012 10:57 PM
2011 Chevrolet Corvette Z06 Carbon slots in right below ZR1 vh_supra26 Other Vehicles & General Automotive Discussions 2 03-14-2010 09:09 PM
