#2213 | |
Drives: Toyota GTS 86
from australia so summers are about 30-40 degrees celsius and winters are 10-20 degrees one more question: would i be fine running by current 2.5'' motiv fp/op combo with a 3" tomei exhaust with the system, or should i switch out my fp/op to 3'' as well |
#2214 | |
Drift King
Drives: '13 Firestorm FR-S 6MT
Full Blown Turbo Kit Owners Topic
I think fp/op might need to be fbm's due to the turbo manifold, i'm not 100% sure though, My car is in their shop getting completely built, 3" from the turbo back. Flex fuel would definitely be way better, you only need 1 map, and you also wouldnt have to worry about being almost out of fuel before switching back and fueling up, also don't have to worry about remembering to switch maps, which could be deadly for the engine. fullblown sells a plug and play flex fuel kit for 749$ i believe (you'd just need a tune), you'll be okay for temps in the winter, but probably need the upgraded rad in the summer depending how hard you push it, their oil cooler kit is a good thing to consider as well Sent from my iPhone using Tapatalk
'13 6MT Firestorm FR-S
#2215 |
in orbe terrum non visi
Drives: violent
Your fp/op is fine. I would get a bigger oil pan. Either fullblown cast pan or a racerx or map pan. More capacity is nice and you won't have to drill and weld the stock pan.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#2216 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#2217 |
I just recently purchased the base kit with the gt2871r turbo. After talking briefly to FB they recommended upgrading the fans, radiator and clutch. This will be a daily driver and I'm aiming for the typical 300-320hp mark for now. Anything else y'all can suggest to upgrade?
#2218 | |
#2219 | |
Drift King
#2220 | |
Says the guy who ran 360whp on Prius tires, and finally upgraded his brakes @Dipstik-sportech
#2221 | |
Drift King
Pretty sure he ran 430whp on them tires too hahaSent from my iPhone using Tapatalk
| The Following User Says Thank You to Brody602 For This Useful Post: | Dipstik-sportech (12-10-2014) |
#2222 |
Drives: WRB Limited BRZ
Anybody running a catted FBM setup?
#2224 | |
Drives: RX-7 / BRZ
pt#0280158117 IIRC I beleive tut said they were basicly 07-10 Ford GT500 injectors. I'm not sure if these were reworked/rebranded by Injector Dynamics though.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | PolishFrs13 (12-10-2014) |
#2225 | |
building life
Drives: Raven Black, 6MT
Just curious about it, debating on getting a flash and go from @delicoustuning (reason being is for the CEL P0441 and traction control light still going on. i have check and clapped all my lines and still comes up) tired of clearing it.. or a aem failsafe gauge and frontpipe |
#2226 |
Drives: 2015 Scion FR-S
So, has anyone else noticed this about their header?
These first two pictures show that I have one of the flanges lined up the best I can to the factory manifold, which fell off the factory studs/block with NO issues. ![]() ![]() This picture shows how far off this flange/the runners are in comparison to having the other flange clocked correctly. You can also see in this picture how far off each runner is in comparison to the mounting hole it's next to. These runners should be aligned on center, and the flanges appear to be CNC cut so I do not think their mounting holes are incorrect. It appears to be either a sloppy job of initial fixturing/welding, or it was sloppy to begin with and has moved with the heat cycles after being on two cars before mine. ![]() The flanges are obviously twisted. It doesn't look like it was beat up during initial installation or shipping (I bought it second-second hand), and the carbon build up on the flanges themselves show that they're not sitting where they should be. The runners themselves are off compared to the flange too, and you can see that by looking down the runner and seeing how much was filled in by weld. Any ideas on how to correct this? The manifold has absolutely NO spring to it and I can't force it on to the studs, so I'm thinking that I'll either have the guys at FBM throw it back on their jig and repair it, or I can just cut the flanges off and weld new ones on myself. |
| Tags |
| best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
