Old 11-26-2014, 10:54 AM   #2199
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by blackfireball5 View Post
I broke the white wire going to the maf sensor giving me a P0102 code. So I'm trying to figure out how to fix that right now. Once I do, I can focus on altering my catch can to vent. And hopefully I'll be good after that.
If you have to modify the OEM MAF sensor wiring, then this is probably a good time to extend the wiring. I would cut off the sensor where you broke the white wire and add some length to each wire. I had to do it for a Vortech install, and just used the same size wire and some butt connectors. Place some black plastic tubing over it and it looks just like OEM.
blackfireball5 (11-26-2014)
Old 11-26-2014, 06:07 PM   #2200
dabocx
dabocx's Avatar
Drives: Scion FRS
Ordered my flex fuel kit from motoeast and ordered a tune from James @ HRI tuning.
Going to see how the gtx2867 does with some more boost!
dabocx is offline   Reply With Quote
Old 11-28-2014, 04:04 PM   #2201
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Has LJ barricaded himself inside and cut all phone lines/interwebz to avoid BF deals?
@FullBlown
We know your in there!
The Following User Says Thank You to Kiske For This Useful Post:
limitedblkwrx (11-28-2014)
Old 11-28-2014, 04:41 PM   #2202
mike the snake
My car's going in for more boost tune. I'm at 10lbs now, we'll be tuning with the 14lb wastegate spring. I've got the gtx2867 and meth injection. Unfortunately all we have is CA 91 gas, but I'm still hoping for decent numbers with the meth.
Old 12-01-2014, 12:42 AM   #2203
FullBlown
FullBlown's Avatar
Drives: Scion FRS
@FullBlown
Haha sorry bud, we are back to work tommrow.
FullBlown is offline   Reply With Quote
Old 12-05-2014, 12:56 AM   #2204
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Alright guys, on the overpipe. I plan to install perrins 2.5 next week or so. I'm wondering if you guys think I could slice (and reweld) the OEM heat and make it work on the aftermarket overpipe? My goal is to take a few moments to help reduce heat and stop the potential melting of the sway bar bushing that some turbo owners have had.
My main reasoning is I'm asking if this would be more effective than using header wrap?
Old 12-05-2014, 01:07 AM   #2205
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Pretty sure they are different steels and it would Crack at the welds. But I don't have one in front of me. I double wrapped mine in dei titanium wrap and my sway bar bushings are fine.
The Following User Says Thank You to Reaper For This Useful Post:
Kiske (12-05-2014)
Old 12-05-2014, 10:47 AM   #2206
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
FYI.. If you race your car and you're using the FBM Turbo/Mocal Oil Cooler kits
The Mocal oil filter sandwich plate WILL AND CAN come loose.
Recommend before and after a racing event and possible in between sessions, you may need to retorque the center thru bolt if you see slight oil residue on the plate. And definitely recommend after each oil change to retorque it regardless since you will have the filter off.
Ironsquid is offline   Reply With Quote
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
blackfireball5 (12-05-2014), Reaper (12-05-2014)
Old 12-05-2014, 04:55 PM   #2207
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Do you know what the torque specs are off the top of your head?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 12-06-2014, 03:43 PM   #2208
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
How far do I need to turbo drain through the oil pan. I have the hole drilled and everything fitted, just not sure if the inside should be flush or if the drain should push through an 0.5-2" or so.
Old 12-06-2014, 04:01 PM   #2209
Dipstik-sportech
Dipstik-sportech's Avatar
I pushed mine in a 1/16" and it's been good.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Kiske (12-06-2014)
Old 12-06-2014, 05:19 PM   #2210
dabocx
dabocx's Avatar
Drives: Scion FRS
Flex fuel from moto east gets here monday, hopefully can get it installed that day so Chris can start working on the tune.
Not sure if I want to keep the car, part of me is really tempted to get a 235, friend got one and it responds crazy to just bolt ons and a tune.
Old 12-10-2014, 12:34 PM   #2211
Choong86
Drives: Toyota GTS 86
About to purchase the stage 1 premium kit w/ GTX2867
aiming for about 400+ whp on e85, what else would i need to purchase to compliment the kit?
catch can, walbro 485 fuel pump, 1000cc injectors are what i have written down so far, did i miss anything?. might just wait until i have enough to buy a radiator+ shroud + fans and a boost gauge, just not sure what i should prioritise and if u guys could help me
Choong86 is offline   Reply With Quote
Old 12-10-2014, 12:52 PM   #2212
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Well you'll need a clutch, possibly flex fuel depending how you want to run your setup. 400whp should be possible on e85, e85 runs a lot cooler, depending on the temperature where you live, you may be able to skip on the radiator stuff for a while
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
